To isolate the cause of the issue, do the following: - 1. Turn off the camera. 2. Remove the lens, battery, and CF card. 3. Allow the camera to sit without power for approximately 20 minutes. 4. Insert only a fully charged battery, and turn on the camera. 5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: - 1. Turn off the camera. 2. Insert the CF card. 3. Turn on the camera. 4. Format the CF card in the camera. 5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: - 1. Turn off the camera. 2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body. 3. Reattach your lens. 4. Turn on the camera. 5. Depress the shutter button as you would to take a picture.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician. If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Was this helpful?
Yes
No
Popular Solutions for Canon EOS 40D Digital SLR
Canon EOS 40D Digital SLR Camera Digital Camera with 17-85mm...
Error message reads CARD ERROR. Said clean card with dry cloth, did that 5 times. tried to format-no...
(More)
Error message reads CARD ERROR. Said clean card with dry cloth, did that 5 times. tried to format-no luck-please help...It is Christmas and I want to take pictures of my 3 girls with the new puupy they got tonite.
just opened it today took a few pictures turned it off, now it wont turn on and just to be sure i...
(More)
just opened it today took a few pictures turned it off, now it wont turn on and just to be sure i replaced the batterys.
My Fuji S-700 camera fell about 14 inches from the coffee table to a carpeted floor....now it will...
(More)
My Fuji S-700 camera fell about 14 inches from the coffee table to a carpeted floor....now it will not respond in any way.I have tried fresh batteries, light tapping with my finger.... no response.
Help!!
Sandra
