Question about Samsung LE40R73BD 40 in. HD-Ready LCD Television
How do i change bulb in tv - Samsung LE40R73BD 40 in. HD-Ready LCD Television
    Top Expert:
  • Samsung Master
  • 74,198 Answers
Hello
Your Samsung tV is LCD type. It has no bulb to replace as in DLP projection televisions. there is CCFL [Cold Cathode Flourocent Lamps] are the lighting devices, which are fitted just behind the LCD screen There will be more than 12 numbers of them, accroding to screen size. If these lamps do not light up; that is; if you do not get any backlight with your LCD TV, the backlight inverter board should be troubleshooted. This is the board that supplies high frequency high voltage to these lamps to light up. Check this inverter baord first. Repalcing backlight CCFL lamps is really a skilled work, as they are fitted inside the panel, and to replace them, you have to disassable the panel itself.
Posted on Feb 24, 2012
  • S Rice Feb 24, 2012
    Thank you for your advice. :)
My Hitachi 43fdx01b has no picture it started to get dimmer and dimmer every day for about a week and then no picture just sound, Any help would be appreciated
Ur tv projection bulb that in ur tv right now?The bulb in the tv right now been in used for 1 1/2 or 2 years in use?The tv been watching like every day like 4 or 5 hours a day?The bulb life span is over,must change the bulb.
May 29, 2010 | Hitachi 43FDX01B TV
Hi I have a jvc dlp hdtv that uses a Bulb jvc CL110u11AA. I understand that if the Tv is going dark that I should replace the Bulb. My Tv is also going Green most images are greener that normal. Is this...
It not the bulb,it still good.Ur tv have a problems known as convergence,"have colors shadows,colors misalinement,picture look like 3D" it dead.This convergence problems it happen to all DLP TVS sooner or later. The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts in the convergence board must be change to fix this.The shop will cost u $300-350 for parts and labors.
May 21, 2010 | JVC HD-52G786 52" Rear Projection HDTV
The tv will not turn on. I need to change the bulb in the tv
Snap-off lower front panel ( about 4" tall x width of TV.) Door behind there with philips screw. Philips screw for lamp itself.
May 02, 2010 | Panasonic PT-50LC13 50" Rear Projection...
61 inch projection tv flashing on and off
The most common problem with JVC LCD rear projection TV is bulb failure. Do not panic, this is normal after 2-5 years of use.
You can change the complete assembly or for less cost just change the bulb. Do not use Osram or other funny brand "rebuilt" or locally made bulb. Use a Philips replacement and all should be good.
Changing the bulb involves removing the lamp assembly and taking it apart like a puzzle and replacing the bulb. JVC are a little more difficult to do than most others because the wires on the original bulb are molded into the glass on the original bulb. Wires must be cut and stripped of insulation before connecting to the new bulb.
All JVC LCD Rear projections TVs use TSCL110 TSCL110U TS-CL110U Lamps.
HD-61FB97 HD-61FC97 HD-61FH96 HD-61FH97 HD-61FN97 HD-61G587 HD-61G657 HD-61G787 HD-61G887 HD-61Z456 HD-61Z575 HD-61Z575AA HD-61Z585 HD-61Z786 HD-61Z886
Check this out for all JVC models to identify the lamp and bulb. JVC Gallery.
easyab
Apr 22, 2010 | JVC Televison & Video
Changing bulb
Changing bulb in Sony KDF-60XBR950 is easy.
Click Sony Support to download lamp replacement instruction manual for your TV.
Please buy Sony original lamp/ bulb for your TV safety.
Thanks.
Dec 29, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Samsung dlp tv: was indicating need a new bulb change. changed bulb and now will not work.
u sure it pluged in all way unplug tv take bulb out look at bulb not broken in side is it re set it in then reset lamp life on tv
Oct 06, 2008 | Televison & Video
Should I change the bulb?
Hi MovieJunkie9,
I would first recommend having a diagnosis done by a Toshiba authorized technician. Bulbs for projection televisions are typically a costly part, so I would not advise replacing it if you are not sure it is needed.
Second, make sure that your product's manual lists the bulb as a user-serviceable part and gives specific instructions for you to change the bulb to make sure you do not do any damage to your unit.
So long as your manual gives you instructions for changing your bulb and the Toshiba authorized technician diagnoses that the bulb is the issue, you should be able to go ahead and change the bulb yourself.
Thank you,
Jason,
Go Ahead. Use Us.
Jul 04, 2008 | Televison & Video
Power on?
im looking for this solution also
Feb 27, 2008 | Toshiba 44NHM84 44" TV
Samsung LE40R73BD 40 in. HD-Ready LCD Television Logo
329 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
