Question about Acer Aspire™ T180 PC Desktop
Add another 250gb hdd
Windows doesn't see the drive, bios does but it is wierd.
  • 2 more comments
  • Paul Watz
    Paul Watz Oct 28, 2008
    internal. Maxtor maxline ii 250gb ata/133 hdd. I can see it in bios when i go into setup, but not in windows.
  • Paul Watz
    I pulled this drive out of a dishnetwork 921 dvr reciver. It was probably formatted for their applications.
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    good approach, amused..only question I have..doesn't it come preformatted, usually?
    so, this drive is external? usb or firewire?
So far so good, now what do I do. I can't seem to format it or assign it a letter...
Posted on Oct 28, 2008
  • Acer Master
  • 787 Answers
Windows does not see it because there is nothing there yet.
You need to partition the drive, format it and assign a drive letter.
To do this, right click on My Computer (or just Computer if this is Vista)
Now click on Manage
Next click on Disk Management
In the botton right hand window you should see Disk 0 and Disk 1
(with Vista you may have more if you have a SD card installed)
You are probably interested in Disk 1 - look fr a drive with unpartitioned space.
Right click on it and activate the drive, then created the partition(s) and frmat the drive.
Finally assign it a drive letter.
Windows should see it now.
  • John Hong
    John Hong Oct 28, 2008
    Right click on that drive again and it should give you a number of different options including the option to format and change drive letter.
    Reply to WeListen2You - most hard drives do not come formatted unless they are specialty models. There are so many different file systems, what would they use to format the drive? NTFS is the most popular for Windows XP and Vista but you could be buying the drive for data and want it compatible with Windows 98 and Linux and would then want to format using FAT32. If you owned an Apple you want HFS. Linux could be any number of different file systems. Take a lok at this list:
    http://en.wikipedia.org/wiki/Comparison_...
HDD NOT WORKING PERFECTLY
I'm confused. Is the maxtor drive 250GB? Have you partition it to 30GB? Or is it that the computer only reads 30GB instead of 250GB? Does this drive have Windows on it? Also you might want to check your BIOS (Motherboard input/output system) by pressing Del key or F12 and see if this drive is the startup Drive. If you don't have Windows on this drive, make sure it is NOT the startup drive. Hope this helps.
Dec 09, 2013 | Maxtor Hard Drive
This drive 250gb hitachi is not being recongnised by my computer.
maybe its in the bios settings that set to first boot was your external hdd,,,open bios settings and set first boot to harddisk drive,to boot your primary hdd so your external will be now detect
Feb 12, 2011 | Hitachi SimpleDrive Mini 250GB USB 20...
Hello .. I have a laptop and the 7520G Aceraspire HDDWD2500BEVS .. Disc HDD does not occur in the BIOS says it NONE .. .. I do not know how to reinstall from the CD, when the disc does not load .....
> HDD does not occur in the BIOS ... says it NONE
This is the first problem that you need to fix, before doing anything else.
Check that the disk-drive is properly "connected" (both "data" and "power" connections).
Enter "BIOS SETUP", and see if the disk-drive is correctly "detected".
Probably, you need to replace the disk-drive, and then reinstall Windows.
Is the current disk-drive still under the manufacturer's warranty?
Dec 22, 2010 | Western Digital WD2500BEVSRTL Scorpio...
On my GT5220-(Athlon X2 64 3800,4G'S RAM)--I HAVE THE STOCK 250GB HDD/IDE THAT IS RUNNING XP-32 BIT,AND I AM TRYING TO ADD 500GB SATA HDD THAT HAS WINDOWS 7 ULTIMATE 32BIT UPGRADED FROM XP VER. EVRYTIME I...
ok get a windows 7 disk and turn of the computer and ad the hard drive switch on the computer and set it to boot from disk (seems windows is broken on the 500gb hdd) then boot from disk and install windows 7 to the 500 gb hard drive and set in the bios the boot select for the hard drive (if you use win xp more then make that boot primary) then go threw all the rigmarol of installing windows 7 to the 500 gb one and your done it will have bootable hard drives and will offer a choice when first switched on
May 15, 2010 | Gateway GT5220 PC Desktop
Can I transfer data from 250GB IDE HDD to a SATA II 500GB HDD
Yes you can. You may have to go in BIOS or and select your SATA as the first drive to boot off of though, else it might try to boot off the old IDE. But once you're in windows, it will appear as another drive in my computer.
Thanks and please take a moment to rate as fixya.
Dec 16, 2008 | ASUS A8N-VM Motherboard
SECOND HARD DRIVE NOT RECOGNIZED
Change the settings of you IDE drives in your BIOS. Set your secondary boot device to HDD1. Also make sure that your primary HDD is set to master and the secondary HDD is slave. The jumper is found at the back of the hard drive where you connect the power and IDE cables. Try this and post back as to how it went..
Nov 11, 2008 | Seagate 250GB Barracuda 7200.10 ATA-100...
Add sata HDD
Make sure the power cable of SATA hard drive is properly plugged in or not.. It is possible.. Try with SATA 0..
Thank you........
Aug 30, 2008 | EliteGroup (ECS 915PL-A2) Motherboard
Acer Aspire™ T180 PC Desktop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
