Question about Korg Pa800 Synthesizer
PCM Ram full
I can not save any sample anymore it sayz pcm memory full what do i need to expand the pcm ram
  • sisou001 Feb 19, 2009
    PCM Ram full" problem,
    Problem Solver:
  • 13 Answers
PCM (or PRAM - Phase-Change memory) is similar to flash memory (NAND) in the respect that it is non-volatile (it doesn't get deleted when you power down). Expandability for PRAM can be proprietary and updating your keyboard may prove difficult, but there may be a better solution for you. Your synth has 3 usb ports. a front and rear high-speed USB2.0 port labeled as HOST, and specifically, a slower, but dedicated DEVICE port on the rear. The device port is a USB1.1 port but you can insert standard USB thumb drives formatted in FAT to this port for added storage for your samples.
Cheers!
-E
Posted on Mar 05, 2009
Why does my recording having a clicking noise
What DAW are you working in? Also.check your buffer size. You may also need more ram,check your ram usage after recording for a while. most DAWs come with a ram usage monitor
Oct 01, 2017 | Behringer XENYX 1202 Premium 12-Input...
Ugrade Ram memory korg i3
Check with Korg for the memory specs
Jun 11, 2013 | Music
Hello, I have a big problem with my korg pa800.i was install os 2.02 my sample ram have been disappaired when i have os 1.01 the sample ram was working.. but when i upate the os 2.02 sample was not saving...
After updating the firmware, you likely must do a factory reset. This is probably required so the keyboard will read and decide how much ram actually exists. At this site do the "factory reset" version:
http://www.korgpa.com/pa_root/en/products/pa800_soft.html
Sep 11, 2011 | Korg Pa800 Synthesizer
Hello, My Pa800 is few years old now has always worked perfectly. I recently combined few sets of rhythms together and loaded it there seemed to be no problem, few days later i was getting glitches in all...
The splicing of rhythms to play seamlessly would be tricky. Also you need to consider if you might be exceeding the number of generators available. If you are splicing external samples, that take great care and a lot of editing. Part of the problem is syncronizing the clocks of individual samples. It is hard to avoid glitches and changing mode of clock and quantizing will expose these glitches.
Sep 07, 2011 | Korg Pa800 Synthesizer
Hallo, I have a Korg pa800 and whenevery I want to load DrumKit or a Sound from another set, I get a warning message (Load Sound Fails: not enought memory fro PCM samples). What should I do to load...
you may have to dump somethings from the memory, the memory is finite and if there is no more room there is no more room. as far as I know there is no expansion memory for this keyboard
Mar 17, 2011 | Korg Pa800 Synthesizer
WHAT KIND OF PCM RAM MEMORY IS USED IN KORG PA800 KEYBOARD.
Here is a site IF you are having problem with the PCM RAM. It sounds like you might even get a free replacemnet part.
http://www.korgpa.com/pa_root/en/products/pa800_faq.html
Nov 19, 2009 | Korg Pa800 Synthesizer
I have noise on ram samples
Korg Pa800 Synthesizer i have noise on ram samples Answer i turned on my pa800 and when i play ram samples there was some noise like cracking and distortion,... (More) i turned on my pa800 and when i play ram samples there was some noise like cracking and distortion, that happened 2 or 3 times, now its normal, but i think it may hapen again??? where is the problem, somebody says it is on motherboard? or its just ram overheating? since i install 2.01 os i noticed that its kinda warm in right display corner, can u help me???
Sep 23, 2009 | Korg Pa800 Synthesizer
Pcm ram problem for korg pa800
http://www.musitronics.org/ Try here but apparently they are on holidays until August 16. There is also an ongoing discussion athttp://www.korgforums.com/forum/phpBB2/viewtopic.php?t=44624 Hope this helps.
Aug 04, 2009 | Korg Pa800 Synthesizer
Korg Pa800 Synthesizer Logo
700 people viewed this question
Top Korg Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Korg Music Expert? Answer questions, earn points and help others
