Question about Refrigerators
GE REFRIGERATOR THAT WONT DISPENSE WATER
Clipped the line under the fridge to see if water was making it past the filter. It is. Put the line back together but water won't come out the dispenser. Replaced dispencer board nothing. So I know for a fact water is makingit all the way to the freezer door but not dispensing. Unfroze freezer thinking hose might be frozen not the problem. Whats left?
  • David Burleson Feb 23, 2012
    Sorry for dismissing the guy who told me to heat up the freezer line. I had already tried that but it did not work. Tried it again and rammed wire down dispenser and
    worked please give him credit for this. Thanks
  • Refrigerators Master
  • 4,654 Answers
What is left? Micro-switch, bad wire conections under front behind kickplateand I know you said you have water but was there pressure when you pressed the dispense water? Or did you only have the water gravity feed water to floor? Dual water control activating properly? Here is a service manual for the PSS25MSRSS S xS Ref If you missed a list of things you did and still not resolved let me know and I will try to assist you. I do have the Monogram Manual on my site left side bar a few lines down, Sea Breeze
http://appliance911seabreeze.com/
http://appliancepartsseabreeze.com/GE_Artica_Technical_Information.html
Posted on Feb 24, 2012
3 Suggested Answers
tech master
  • 120 Answers
SOURCE: Ice will not dispense GE model GSL25IFRF BS
well if you trouble shoot the board at the back to see if you are getting voltage if you are then use a jumper on that conenctor and see if the auger motor runs or remove auger motor and check voltage there while pressing the lever for ice usually 100% of the time that board controls everyhting water and ice
Posted on Nov 18, 2008
MNTECH
  • 1543 Answers
SOURCE: GE GSS25LGMF Water dispenser-no water
Order and install a WR49X10173 water tube heater. It may take 24 hours to then thaw, but it has worked for me on numerous refrigerators. Cost for the part will run about $50.
Posted on Feb 08, 2009
GE Water Dispenser not working
Sounds like the water tank in the fridge section froze and split open causing a leak. Plus, the water feed line to the dispenser has frozen where it runs up through the freezer door- guessing your trimmer line only goes about 5" into the tube?
There is a water line heater kit that GE makes : Refrigerator Heating Element WR49X10173 .
Then, buy two quick disconnects 5/16" and about 10 feet of 5/16" plastic tubing- use the tubing and disconnects to replace the cracked water tank and you should be good to go... Refrigerator Water Line 5210JA3004K
Jul 03, 2016 | GE Refrigerators
Why is my GE (ZFSB23D SS) side by side refrigerator leaking at the back corner, near the rear wheel where the plastic water line goes in?
If the tubing is plastic it could have cracked when you moved the tubing to install the filter. If the tubing is OK then possinly the filter isn't all the way in or is leaking.
Jul 31, 2014 | Refrigerators
My GE Adora side by side makes ice but the water dispenser barely dispenses.
Did you recently move the fridge? One possibility is that the supply line in the back of the fridge is kinked. Usually it is coiled so you can move the fridge out and back damage but if it gets kinked, it would limit the water supply like a hose does when kinked. Also, the supply line is usually tapped from under the sink. Make sure the valve that supplies the line (usually 1/4 inch line) is fully opened. If that fails to help, then you're back to the solenoid valve for water that is not fully opening. Should give a solid clunk when actuated. G
Jan 27, 2014 | GE Adora (DSF25KGTBG) Side by Side...
Fridge is making Ice and will dispense Ice. Fridge will not dispense water at the door.
. Check your water filter first . On some models , only the drinking water is filtered . I don't know which model you have therefore you'll have to check and see if your ice maker water supply is filtered or not . If it is not , that is probably a bad water filter you have . However , if it is , I would check the supply line from the chiller located in the refrigerator compartment usually on the lower right hand side at the back of the compartment . The problem could be a plugged supply line from the chiller to the water valve on the door .
Mar 10, 2011 | GE Refrigerators
Water not dispensing from side by side fridge
check the primary water valve ,does it make a noise when you push the dispenser ?
Mar 29, 2010 | Maytag MTF2156GEW Top Freezer Refrigerator
GE Profile Performance - No water dispensing or ice making
NOT ENOUGH WATER PRESSURE AT WATERLINE OR WATER VALVE IS BAD AND NEEDS REPLACED
Jul 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
About 15 yr. ol GE Profile
YOU MIGHT NOT HAVE ONE ge started puting factory filters on in 1999 . you might have an inline one in the water line behind the fridge . but only if the homeowner or installer put one in , ge has nothing to do with it .... replacements at any hardware store
Feb 14, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Side-By-Side GE Fridge Won't Supply Water
Sounds like a frozen line ... press on the inside door lisen to see if there is ice inside defrost the freezer check if water will flow ... if stainless steel door there is a heater kit you can put in... if plastic you will have to replace the door.
Dec 15, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Water/Ice Dispenser is not working
at the very least replace that water filter.clogged water filter will reduce water pressure to the line.
Feb 24, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
44 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
