Question about Gateway (MD7330u) PC Notebook
Keyboard and trackpad wont respond
Keyboard and trackpad wont work when startup but works in bios
  • 734 Answers
Do you have enough drams for the operating system?
Posted on Feb 24, 2012
Comfort curve keyboard 2000
Have you tried my solution for keys not working here?:
http://www.fixya.com/support/t3015431-microsoft_comfort_curve_2000_v_1_key
Mine is toward the bottom, with the video
Good Luck
Jan 07, 2013 | Microsoft Comfort Curve 2000 Keyboard
Keyboard doesn't work
Does your laptop work when you plug in a USB keyboard? When you startup the machine, do the keys respond (depending on your laptop, push the key to get into the system BIOS). If it allows you to get into the system BIOS, then it maybe a software issue.
Oct 21, 2012 | Sylvania G-Netbook
Presario C714NR gr983UA#ABA ALPS touchpad does not work I have updated the BIOS and uninstalled and reinstalled the drivers but it still does not work
I had a similar issue with my ASUS. Try finding a program on your computer other than the Control Panel that controls the trackpad. For instance mine is Elan Smart-Pad. Usually working with some of the configurations in the program reinitialize the trackpad. If that doesn't work make sure that it isn't turned of due to keyboard interference (hitting a button that turns the trackpad off). Hopefully that isn't the case though.
May 10, 2011 | Compaq Presario 700 470024-192 Notebook
Hi - I have a macbook and seem to have locked the keyboard - if I plug a mouse in at the USB it works but the mouse on the macbook isn't responded, nor are any of the other keys - is there a simple...
Hello sarahscarah,
I've repaired a fair share of Macbooks with the same issue, but just to make sure it is what I think it is I'll need you to do a few things.
This issue is thought to be caused by a bent/warped ribbon cable that is located under the battery. This cable is what connects the trackpad and keyboard to the rest of your computer. To test if this is the problem do the following.
  1. Verify that an external keyboard and mouse will work with your Macbook when plugged in to a USB port.
  2. Connect your Macbook to your power adapter and plug into wall.
  3. Unlock your battery by turning the dial on the bottom of your Macbook with a coin.
  4. Remove the battery and set it aside.
  5. Press down on the exposed trackpad cable with your finger.
  6. While pressing down on this cable try typing on your Macbook's keyboard and moving the cursor with the trackpad.
If this works then you've solved it, you can place a piece of "Kapton Tape" over this cable to hold it down, but this is a temporary fix. You will probably need your trackpad and keyboard replaced. If your macbook is still under warranty take it to an Apple store, show them the problem and have it fixed or replaced. If its out of warranty you'll be looking at a $200-$300 repair to have the trackpad/keyboard replaced by a technician.
Here's a picture of the exposed trackpad cable for reference.
Trackpad Cable Pic
Hope this helps, if so please leave positive feedback. Thank you.
Feb 16, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Keyboard and trackpad got wet
it may work when it dies out...otherwise you will most likely have to take and have the keyboard replaced
Jul 21, 2009 | Apple 13.3 MacBook Intel Core 2 Duo...
Keyboard won't work on startup after installing new msi mobo
A USB KEYBOARD SHOULD RESPOND,THAT IS THE ONLY ALTERNATIVE.
Jul 03, 2009 | MSI P6N SLI PLATINUM Motherboard
ERROR CODE "0210:KEY STUCK 39
I got the 0210 stuck key error on a Lenovo Thinkpad T61, pc would not bootup, made sure keyboard was connected and cleaned with aircan and then went into bios and via F1 on startup, then went to CONFIG then to Keyboard/Mouse then I disabled the TrackPoint. Boots up fine now but the red nipple mouse is disabled due to action mentioned above. Looks like a warranty fix for Lenovo since this is a newer laptop. If it was out of warranty i would just skip using it and leave it disabled. The trackpad works fine.
Apr 27, 2009 | Compaq Presario 1200XL111 Notebook
Keyboard not responding after bio check
THE CONTACT PINS ARE GONE BAD..........
TRY SEE ITS BEND AND U CAN FIX IT WITH CARE....OR ELSE ON OTHER OPTION AS IT LOOKS THE KEYBOARD HAS GONE U/S...........
Apr 28, 2008 | Computers & Internet
Gateway notebook MX6930 trackpad issue
Has the left mouse button ever worked? If so when did it stop working, make a system restore to that date
Nov 17, 2007 | Computers & Internet
Gateway (MD7330u) PC Notebook Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
