Question about Crimestopper SP101 Deluxe 1Way Alarm and Keyless Entry System
Need manual for crimestopper sp-101 - Crimestopper SP101 Deluxe 1Way Alarm and Keyless Entry System
2 Suggested Answers
richroth
  • 9472 Answers
SOURCE: CRIMESTOPPER SP 600 INSTALLTION MANUAL...NEED ASAP
Look at this manual. It is for the sp500-sp600 systems
Posted on Aug 06, 2011
How do I get my crimestopper sp 101 out of silent mode
On your remote press the down left button (mute button) and then the unlock button, top right, then press lock again, top left.
May 27, 2014 | Lands Phones
Crimestopper sp-101 car alarm
First coneckt the power direct to batery
Dec 27, 2013 | SP-101 Car Alarm
I am trying to hook up a crimestopper sp-101 auto alarm in my 88 chevy van, do i need to hook up both purple and green and can i hook it up to the dome wire. This is my first time installing a alarm so...
Is this a new alarm system? Didn't it come with installation directions? The following site lists the system's wire connections; if you want to hook them up differently, do so at your own risk. Good luck.
Oct 11, 2013 | Cars & Trucks
Crimestopper SP501 car alarm/remote starter will not respond. The 2 way one doesn't work, the sidekick does.
You need to program your crimestopper sp-501 key fobs, you need to program both the 2-way and the 1-way key fobs, during the same key fob program session. First find your valet button/switch, when you have found it, turn your ignition on and press the valet button four times, if you have a toggle type switch for a valet switch, toggle it up and down four times, when its in remote key fob program mode, it will honk your horn 4-times followed by 4-parking light flashes. Once your have done this press the lock button on the 2-way key fob, horn will honk and the 2-way will sing a little song to confirm programed, then press the lock button on the 1-way key fob the horn honk will be your confirm programed. turn ignition off this will exit you from program mode. then shut all doors and test key fobs for operation functions....hope this helps you out
Dec 03, 2011 | 2006 Hyundai Sonata
How do i disable a CRIMESTOPPER SP-101 alarm on my 02 subaru wrx, my remote isnt working
look under the dash and you'll probably see the module and wires. Alarm systems are usually modules (box) that splice into the ignition and lock wires with a big harness under the dash. The harness is a group of wires tied together with usually 2-3 connectors. The harness that the alarm is plugged into is aftermarket and you can remove it. one connector goes to the ignition, one goes to main harness, and one goes to your alarm. Just unsplice the module. Unplug the box and harness it connects into. and make sure you replug in the old connectors to each other. there will probably be some other smaller wires spliced into random wires, just unplug them from the alarm system module. your car should still work fine. and again ****make sure you connect the old connectors from which the alarm was spliced into.****
May 02, 2011 | Car Audio & Video
MY ALARM DID NOT COME WITH INSTALLATION MANUAL AND I DON'T KNOW HOW TO INSTALL IT . IT'S A SP-200
You can obtain a copy of the manual from the following link
http://www.crimestopper.com/Templates/2009_manuals/Alarm/sp-200_ins.pdf
Jan 21, 2011 | 4-Button Remote Start/Keyless Entry with...
Light on gba sp is dim
I wish I knew because I have the same problem.
Feb 06, 2010 | Nintendo Game Boy Advance SP Console
Crime Stopper SP-500 problem
try this web site by crime stopper www.crimestopper.com or you can call their tech support at 800.98.6880 ext 210 you may have to program the remote again. you can also find that at the site by choosing support manuals then manuals again and finding the model number of the actual unit not the remote
Dec 06, 2009 | Combo Alarm and Remote Start with One For...
How do I store numbers on the phone system.
From the phone connected to Jack 01 (probably ext 101) press PROG **1234 001. Then press SP PHONE and you should be looking at speed call bin #001.
SP PHONE steps you through the numbers and all numbers you add need to include the trunk access code, be it "9" or "8x" before the number. STORE saves it.
Carl
Mar 25, 2009 | Panasonic KX-T7433B Corded Phone
Crimestopper SP101 Deluxe 1Way Alarm and Keyless Entry System Logo
783 people viewed this question
Top Crime Stopper Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Frank Mangiapane
Level 1 Expert
Steve
Steve
Are you a Crime Stopper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
