SOURCE: i need to know how to convert it to a toddler bed
The front rail just comes off and then the toddler is able to get in and out.
We did this with ours and it worked out great.
SOURCE: converting crib into toddler bed
Call customer support @ 18002951980 and customer support can either email or fax instructions at no charge. I just did it and got the instructions myself. Or you can email me @ [email protected] and I'll foward the instructions to you.
SOURCE: Crib to toddler bed instructions
I need instructions to transform my mama and papas Aspen Cotbed into a bed! We have lost the instructions! Can u help?
SOURCE: No instructions on converting a Ragazzi crib into a toddler bed
This site has instructions for some Ragazzi cribs.
http://www.babyfurnitureplus.net/instructions/index.html
SOURCE: convert crib to toddler bed
I finally found my instructions!! It's actually really easy to convert to a toddler bed:
Step one: Take out four screws (two on each side) of the front railing and top bar. They are the screws holding the front railing and the top bar to the side of the crib and the dresser.
Step two: Lower the mattress to the lowest setting.
Step three: Place the toddler bed railing in place. It can go either way depending on which side of the crib your toddler sleeps. We put the taller part of the toddler railing closest to the dresser because that is where our son's head usually is.
Step four: You'll need 4 1.5 inch hexagonal screws to screw in the toddler railing. After 2.5 years, I could only find two of them, so I used two 1.5 inch regular screws that came with the crib. On the taller part of the toddler railing -- the screws go into the 1st and the fifth holes. On the shorter side of the railing, the screws go into the 3rd and the 5th holes.
That's it.. You've now got a toddler bed!
This is a little tricky to explain; however I found you a
great how-to article that will guide you through this process. Hope you find it helpful!
http://tlc.howstuffworks.com/family/how-to-convert-crib-to-toddler-bed.htm
