Question about Epson TM-T88III Thermal Printer
TM-T88iii SHOWS MESSAGE OF USER INTERVENTION REQUIRED
3 Suggested Answers
SOURCE: User Intervention required on Epson
i am pulling hair trying to install epson tm u220pd on xp and vista for weeks now please help
found some drivers but printer is not responding
Posted on Dec 02, 2008
SOURCE: Epson printer TM U220 (User Intervention Required)
I spent a good week trying to find an answer to this problem... and finally I HAVE THE SOLUTION!!
it's to do with the Port settings.
go to BIOS and change the port settings on your computer.
there are a number of different options that can be selected, just try them one by one, the one that worked for me was "Normal" try that one first, but it may be differnet depending on the printer.
if your LPT port is using it's own driver (not using BIOS to run) you cant change the settings using the BIOS. see if you can change it useing the settings for the dirver. if not try updating the driver. if that doesn't work, and nothing else works, reinstall Windows, that should fix the problem as a last resort.
good luck.
Posted on Jul 23, 2009
How can I fix the issue when my printer says "User intervention required?"
I'd guess you have a paper jam, maybe even tiny piece.
Check error message on printer's panel. try turn off for 10min.
turn back on. Users manual on software install CD may help understand message.
Mar 08, 2015 | HP Office Equipment & Supplies
I am using Epson TM T81 thermal printer and it is showing status USER INTERVENTION REQUIRED , printer is not printing document. I unistall drivers and install it again it works but whenever I restart the...
This is a firmware bug that was resolved after ver 4.13, you may need to contact epson support to request a copy or upgrade as it is not downloadable through standard sources
May 11, 2011 | Epson TM-U220PD Matrix Printer
Need drivers for epson tm-t88111 printer
Epson TM-T88iii Receipt Printer - This product has been discontinued. It is replaced by the Epson TM-T88iv.
Epson TM-T88iii Printer -> Drivers download
Hope it helps.
Nov 09, 2010 | Computers & Internet
User Intervention Required Message Epson TMU375 receipt printer
Got to start/settings/printers and faxes .saelect epson 220 printer go to properties and select ports.Change ESDLPT1 port to lpt1 port and uncheck enable bi directional option .Apply and o.k.printer will work fine
Dec 30, 2008 | Epson TM-U220 Matrix Printer
good luck.
Dec 11, 2008 | Epson TM-U220PD Matrix Printer
User Intervention required on Epson TM-U220PD
I had the same problem with the user intervention required status on the printer. I tries reinstalling it several times through the Epson Driver Utility but got the same message each time. I got it to work after making two change but do not know which one (if either) got it to work. First i uninstalled the printer driver through Add/Remove Programs and not through the Driver Utility. I also set Dip switch 1-1 to on which enables auto line feed with parallel interface, with other interfaces this switch changes other things.
Dec 02, 2008 | Epson TM-U220PD Matrix Printer
My printer doesn't work
http://h20000.www2.hp.com/bizsupport/Tec...
The link above may help you. It applies to HP printers,but
might solve your problem with your Canon printer.
Jun 16, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Epson TM-T88III - Always showing as not avaliable
I had the same with XP .... I had my home inkjet (Parallel port) on LPT1. The Epson TM software and printer worked fine after removing the ink jet from LPT1 and re-installing the TM driver.
May 08, 2008 | Epson TM-T88III Thermal Printer
Epson TM-T88III Thermal Printer Logo
359 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
