Access files i have server 2003. i can not access files from server,when i am in windows xp sp2. but the server access files from xp.i already share the fikes on the server. give me what is the problem?
  • 35 Answers
Sharing is not enough on windows server 2003. You will need to give privilages to the Everyone user on that folder and enable the Guest user from the Computer Management/Users and Groups panel.
You can also create a new user from there. Give it security and sharing privilages on that folder. And login with it from the other computer.
Posted on Oct 28, 2008
Hi, I have two pc running with windows xp operating system. From User 1 i need to access user 2 windows folder and program files folder otherway around also but I can't how? Even if I shared windows folder...
First thing Windows XP Home Edition will give you numerous problems when sharing files, you should consider using windows XP Pro for that sort of operations.
Assuming you have Windows XP Pro installed in both computers:
1 - Create the same user on both computers ( same account name, same password ) blank passwords are not allow between file sharing as per windows xp group policy.
2 - Create a resource to share ( example: C:\)
3 - Disable simple file sharing
* go to control panel
* click on folder options
* click the VIEW tab
* unckeck the use sharing wizard
4 - Make sure that the user that will be used for authenticating between computers have the proper NTFS permissions and the proper access to the shared sources.
5 - Try to connect to the shared sources when asked for username and password type the credentials of the newly created user.
Now you should be able to connect to the shared sources both ways.
Oct 18, 2010 | Computers & Internet
My window xp2 is not installing window installer 3.1 help me
Windows Installer 3.1 Redistributable supports Windows 2000 with Service Pack 3 or later, Windows XP, Windows XP Service Pack 1, Windows XP Service Pack 2 and Windows Server 2003. Windows Server 2003 Service Pack 1 contains Windows Installer 3.1 and therefore can't be installed or upgraded by this redistributable.
Read the above, Windows Installer 3.1 already in in SP2. Why do you need to install it?
Jul 14, 2010 | Microsoft Windows XP Professional
I have a e-studio 282 copier i cant access the smb server through windows 7 but i can through windows XP what shall i do to fix the problem
Sharing on Vista & Window 7 are not as easy as Window XP.
Kindly check below settings on your network connection:
Network Discovery: turn on network discovery
File and printer sharing: turn on
Public folder sharing: Your choice. It can be on or off.
Media Streaming: By default, this is off. You can turn it on if you want, but it is not why we are here, so I'm going to leave it off for now.
Password protected sharing: Turn off password protected sharing
HomeGroup connections: This doesn't really matter, since you already left homegroup. However, I allowed Windows to manage my homegroup connections. It seemed easier than arguing.
Dec 20, 2009 | Computers & Internet
Network Printing Issue. I'm running 2008 Domain Controller 2003 File and Print Server. Cisco 3560G switches No 3rd Party print management software User workstations are all Windows Xp Pro SP2 Printers are...
DNS errors then? can you map to the printer via hostname too? Are you sure you're not using SP3? When we upgraded to SP3, we had to use the new drivers. Try new drivers.Have you tried just rebuilding your print server? try sharing the printer off your computer in the data center and try t print to that. When you ping the data center from the user's computer... what is the delay?
Oct 13, 2009 | HP LaserJet 4250n Printer
Cant configre printer sharing via web on win server 2003
Yes is possible. Use Routing and Remote Access facility from Windows 2003 server to create a VPN Server. Create a VPN connection to Windows server, and thus you get an IP address from windows 2003 server and you can use printer.
Jul 07, 2009 | Microsoft Windows Server 2003 R2...
D-Link Airplus DWL-G520 problem with windows server 2003
D-Link Airplus DWL-G520 on PCI drivers do NOT support Server 2003. It will only support these OS
Windows 98/Me/2000/XP
If you boot your XP is it still working ?
Mar 15, 2009 | Intel D101GGC Motherboard
We have a Windows 2003 Server enterprise edition SP2 & this is our inblr200 (file server of India) located at (IDC) reliance data center. The server hangs up frequently and it doesn?t give access to anyone...
Hi m8,
This sound like a memory problem, if you have dual memory blocks, then try to swoop them around, this might "move" the problem.
IF, this works, you know what to do - new memory block :-)
/Teis
Dec 03, 2008 | Microsoft Windows Server Standard 2003 for...
Internate sharing close in day maximum 5 time or more
Nothing Put ur Client PC' s Default gate. And then DNS IP- Address as server's ip-Address.I thing this method may be already configured on ur Server. Not yet, Try it Now......
Nov 22, 2008 | Microsoft Windows Server Standard 2003 for...
Want to give give security
All you have to do is go to the properties of the folder by highlighting the folder and pressing properties. Look for the Sharing tab and make sure it is set for sharing. There should be a security tab where you can add the users you want to use the file and what they can use the file for. These users must be in the server already. If there not in the server you have to add them. If they haven't logged into the domain (your server yet) they will be asked for a password. Otherwise you will have to create another user id and password for that folder.
Jun 30, 2008 | Microsoft Windows Server Standard 2003 for...
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
