Question about Magellan RoadMate 700 GPS Receiver
Frozen screen when turned on
I bought a second hand magellan 700. It worked twice and it worked fine. This afternoon, when I turned on the unit, it would "freeze" on the section on the (user 1) (user 2) (user 3) option. I touch all the screens, I touched all the buttons.. but it is FROZEN. I turn the unit ON and OFF repeatedly (ie unplug and replug because the on/off button will not work). HELP! TEL ME THAT I DID NOT GET A LEMON MAGELLAN 700. Thanks
  • 1 more comment
  • kevin angelo Sep 03, 2006
    Hello Daniel
    Thank you for your suggestions.
    re: "If you have a program that allows you to update the software, version 4.32 I'm guessing (or 5.14) then at that "secret" menu select NAND Flash Format and re-load the software..."
    The software version of my magellan is 5.14. Yes, I was able
    to go to the secret menu and I did select the NAND FLASH FORMAT.
    How do I re-load the software? I did not get any CD when I bought this unit. I only got a USB connector.
    I am willing to pay if you can make me a copy.
  • kevin angelo Sep 17, 2006
    Hello Daniel
    '....Your NAND flash is cleared and you now have no way of loading the software back into your unit. What is your unit doing now? Does it say no map data/software? Is it still frozen at the user menu? let me know....'
    It is still doing the same thing.. freezing at the user manu (even though the NAND flash is cleared. What do I do now?
    So frustrated.
    Kevin
  • Anonymous Feb 02, 2008
    went 250 miles before it would start, good thing i knew where i was going. i call her "HILLARY" (GO FIGURE WHY IT DOESN,T WORK RIGHT)
    Novelist:
    Scholar:
  • 86 Answers
Kevin, Hmm... it worked fine the first two times you ran it, then all of a sudden it freezes at the user screen?? I'm not sure if your able to do this, but at the user menu, try pressing the (-)zoom out key and the repeat button a the same time. -If it does bring up the "secret" menu, try clearing user data. -If you have a program that allows you to update the software, version 4.32 I'm guessing (or 5.14) then at that "secret" menu select NAND Flash Format and re-load the software. If you can't access the "secret" menu and it locks up hard at the user menu w/out any responsiveness, I would suspect the hard drive is either bad or has corrupt data. I'm not sure if you can order just the hard drive from magellan/thales/tomtom/shaw but if you can then just replace the hard drive, nand flash format (above) and re-install your software via usb. Additionally, not that it helps your problem, but atleast you would know the pwr and keypad work if this works, press Enter, Cancel and power button at the same time, as this SHOULD power off your unit. Let me know if any new symptoms/problems come up or if you need further instructions. -Daniel
Posted on Aug 31, 2006
  • 1 more comment
  • Daniel daniel
    Daniel daniel Sep 15, 2006
    Kevin,
    I personally do not have a program that allows you to upload software. "If you have a program that allows you to update the software, version 4.32 I'm guessing (or 5.14) THEN"...etc..etc..
  • Daniel daniel
    Daniel daniel Feb 10, 2007
    Kevin.. did you ever find a cure for this unit?
  • bkoch940 Jan 18, 2012
    Wow!! My screen just totally froze up. I turned off and on 3 times.. nothing. Googled magellan roadmate and it took me to their website, which was a totally waste of time and to another website that charges $30 for live chat with a technican. I googled magellan touch screen frozen... And here we are. I don't have the same model as above mentioned, but I did push menu and - at same time... TOTALLY FIXED IT!!! thank you so much!!
My gps is frozen since ysdtay night.I t shows no movement n its frozen stating univeristy bld.What do I do??I just got it last month & did not buy the protection plan for it..What is the problem
mine was frozen 2. i called support and they helped. first hold the button 2 turn it off for 10 sec. reboot if u had trip ie. address programed in cancel it. That worked. Also not sure if this had anything to do w/ it but my battery was low and the gps powered off. I then plugged it in to the car charger this may have rebooted my gps. It now works fine.
Jan 17, 2011 | Magellan Roadmate 5045 3065 3055 3045-LM...
Maestro 4250 frozen after incomplete 2009 map up date
I had same problem on 3/28/09.
According to Magellan and other people who have experienced the same problem, this is terminal to the unit. It can be caused by downloading the 08/09 Magellan map upgrade, which can cause the unit to permanently lock up. Magellan is well aware of the problem, and should offer to replace your unit if you have the problem. If you elect to have it repaired, Magellan can download the map upgrade for you in the repair process. Here is a site noting the same problem: http://74.125.93.104/search?q=cache:pNLjGT-i4-sJ:forums.gpsreview.net/viewtopic.php%3Ft%3D8958+magellan+4250+gps+stays+on+blue+screen&cd=8&hl=en&ct=clnk&gl=us
Questions for Magellan: 1) why would they sell, in 2009, gps units with old 2007 maps loaded in them, requiring the purchaser to buy a current map, and 2) if there is a problem with downloading the current maps, why is there not an advisement or warning to the installer.
Other than replacing the unit, there appears to be no "fix".
Mar 29, 2009 | Magellan Maestro 4250 GPS
Blue magellan screen-frozen
sissey05,
Thanks for coming back, although I'm starting to believe I am the last resort for tech support on these models.
This screen as with computers, is the blue screen of death. Unless you can still sync up with your computer and attempt to reload 3.56. If that didn't work, I would replace the hard drive which I'm sure you don't have lying around.
You could try opening the unit up (very gently), removing the hard drive (ribbon) cable, making sure the contacts are clean and re-inserting it.. other then that sissey.. in the shop we would format HDD & re-load the software. Does your computer recognize it?
-Daniel
Nov 19, 2008 | Magellan RoadMate 700 GPS Receiver
Magellan 700 sound problem
1. Search for the file ENG_F.SND sound on google or yahoo or any search engine.
2. Connect RM 700 to PC, and create folder name SOUND_EU on RM 700.
3. Copy the ENG_F.SND to SOUND_EU folder.
4. Disconnect RM 700 from PC.
5. Turn on RM 700, and go to Option, configuration, language, and choose English.
6. RM 700 will load sound file and turn off.
7. Turn on RM 700, if it keeps showing the initial screen, then connect the RM 700 to PC, and DELETE the ENG_F.SND from SOUND_EU. It should be OK after you disconnect RM 700 from PC and turn it on again.
GOOD LUCK!
NOTES: My screen indeed locked at first as covered in the last step, so expect that to happen. Don't worry if you never get to do step 5 and 6. Connecting the USB, deleting the SND file and restarting it works and the sound is back even without the file there.
This only fixes the Female voice along with the beeps and clicks. The unit goes silent again if you select the male voice but switching back to the female fixed that. I assume "_F" in the file name must mean female.
Aug 18, 2008 | Magellan RoadMate 700 GPS Receiver
Lost sound and audio
i use to own a 700, i advise you to get the new magellan mastreo 4000 or higher,i did my research and the magellan700 roadmate is no longer being serviced.that is what the magellan website has had showed and someone on here also has said it and they start to have alot of problems.i own now a mastreo 4000 so far so good no problems.your choice
Jan 22, 2008 | Magellan RoadMate 700 GPS Receiver
Screen Freezes
register your unit on the magellan website and there is a firmware update and it will solve your problem
Dec 18, 2007 | Magellan RoadMate 700 GPS Receiver
Road mate 700
The flash card hole is supposed to be empty - all you need should be on the hard disk BUT the first Roadmate 700 I purchased was empty i.e. no software loaded. The second failed due to bad power connection, the third worked but was factory refurbished! what a crass organisation Magellan is!!!
Try fiddling with the power connection that goes into the cradle that the unit sits on. The power connection is ultra sensitive. BUT, if you've only just bought the unit then you are in luck - return it and get your money - back Magellan Support is extremely poor.
I am binning my Roadmate and getting a Tomtom720 Go series with maps and cameras preloaded - it auto updates when it is on its cradle attached to my PC/internet.
Bin the Magella - 4 years of problems!!!!
Oct 24, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan Roadmate 700 can't power up 2nd time in car
Are you willing to part with it, I may be able to use it for parts denisdsouza@hotmail.com
Jun 19, 2007 | Magellan RoadMate 700 GPS Receiver
Message: the tempature is to low
hah.. yes that is a strange coincedence. When this error appears, you can try to find someone else's unit and use it for spare parts. If you can find another unit to salvage from, then first change out the LCD w/attached thermometer wires. next to change is the hard drive. which, without having the software DVD can't be completed. I'm sorry Jerome but. there's not too much you can do with this error. -Daniel
Apr 24, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan Roadmate 700 GPS
If everything else is working fine, specifically the touch screen, then it's probably your speaker. open unit and check your speaker for anything stuck to the back of the magnet (on the speaker). make sure the cable going from your speaker to the keypad PCB (board) is pushed in all the way. you may want to even pull it out and re-connect it. make sure the unit is off while you do this and try to ground yourself with something. good luck and let me know how it turns out.
Mar 04, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan RoadMate 700 GPS Receiver Logo
530 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Steve
Steve
Are you a Magellan GPS Expert? Answer questions, earn points and help others
