Question about Whirlpool 8579123A DUET DRYER DR REVERSAL KIT
Control panel blinking and beeps, dryer not working?
Dryer turns on, when I hit "start" it "beep, beep, beeps" and blinks but will not start the drying cycle?
  • k2dolan
    k2dolan Feb 25, 2012
    First the circuit blew for my dryer, after I flipped it - dryer would turn on, but when I hit the start button it made a "beep, beep, beep" sound, the panel would blink but the dryer would not actually start and would just continue to blink. Is it a malfunction with the panel? Is their a way to reset it? (I've tried holding the 'control' button for 4 seconds and that did not work? any suggestions?
4 Suggested Answers
  • 36 Answers
SOURCE: Duet Dryer will not start, Press control on, Start, then it beeps
try tripping your circet breakers dont assume that just because it lights up both lines are working you can have a partial tripped breaker and just be getting 110 to the drier its easy enough to just go ahead and reset the breakere if that dont work get back to me
Posted on Dec 28, 2007
richroth
  • 9472 Answers
SOURCE: my dryer is stuck on "Control Lock"
See if you can get into the diagnostic mode. If not, you will need to replace the "user interface" on the machine. Here is a link to the part if you should need it.
ACTIVATING THE DIAGNOSTIC TEST MODE 1. Make sure that the dryer is in the "Standby" mode (plugged in and all of the indicators are off). 2. Press the following control panel keypad sequence all within 5 seconds: More Time-Less Time-More Time- Less Time. 3. All indicators on the console should now be illuminated with "88" showing in the "Estimated Time Remaining" display, if this test mode has been entered successfully.
Posted on Dec 26, 2010
techbuster
  • 5081 Answers
SOURCE: My duet dryer control lock
It is not related to moisture directly by any chance. If END OF CYCLE does not work. it can be short circuit inside which can cause this. Moisture can cause short circuit or the whole control board may be faulty.
Posted on Aug 27, 2011
Frigidaire Dryer model # LEQ1442ES0. The lights come on and beep at us like normal when I change settings but when I press start, they just blink and beep but wont turn on.
Thank you for your post, friend!
From my understanding your Frigidaire dryer is not starting and the lights just blink. It sounds like a faulty door switch or control panel. I would check to make sure the latch or door strike is not cracked or broken if the door is not closing properly that could be the cause of your dryer not starting.
You could also perform a reset on your dryer and that could help clear any faulty error codes within your dryer. To reset your dryer you would unplug the power cord for ten minutes. I hope this has been beneficial. -Matt
Oct 17, 2014 | Frigidaire Dryers
Good Afternoon Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, will not start. I also see that when you press the start button, the lights above the Control button blink and your dryer beeps. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try running any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 24, 2014 | Frigidaire FEQ1442ES Electric Dryer
Dryer will not start: when I hit the start button, dryer beeps and lights blink above Control button
-Best Regards-
WP
Dsxh47eg0ww
I would replace parts. It still is cheaper than a new unit. So get the new control panel and do it yourself and save money. The average life of a dyer is dependant only on when the owner gives up. I just serviced on last week that was 25 years old.
Jul 08, 2013 | GE DSXH47EGWW Electric Dryer
My duet dryer control lock is blinking and beeping....tried pushing the end of cycle button, but still is blinking and beeping. Any other suggestions??? We have had lots of humidity this summer and...
Aug 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Dryer won't start. Lights come but when I hit the start button the lights blink and it beeps 3x and then nothing.
There's usually a paper behind the panel in the back that has a wiring diagram and descriptions of what the beep codes mean. If you pull the back off of the control panel you should find it folded up in there.
Feb 14, 2011 | Electrolux Dryers
GEW92509W0 will not start. When you hold start button, it beeps like door is open. Tried many settings. It will only blink "sensing light" . No error code is blinking in the display. Plugged...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 19, 2010 | Whirlpool GEW9250P Electric Dryer
Dryer not drying
MAYBE CHECK UR GAS VALVE
Aug 18, 2009 | Frigidaire FGQ1442ES Gas Dryer
Malber Dryer won't start (sine-wave light flashing)
The dryer is easy: turn it on and turn the control to 0. It will beep. Then turn it to the desired program (20, 40, 60 minutes or a pre-programmed cycle), it will beep again and start. If there's a red light you have to empty the water tank at the front on the left. The washer is a normal washer. Just pick your program and press start (be patient as it takes a while to get cranking). Sometimes you have to really push the door closed very hard. Try and turn the control to 12 o'clock before setting it again.
May 30, 2009 | Malber TD800 Electric Dryer
Whirlpool 8579123A DUET DRYER DR REVERSAL KIT Logo
Dan Webster
Dan Webster
Sal De
