Question about Breville BES860XL
Two-Cup Button is Making A Strange Noise
My Breville Barista Express is under 1 year old and I have been taking the recommended measures to take care of it. Yesterday I decalcified it, just like I have done in the past. However all of a sudden it just started making a high-pitched buzzing noise when I press the two-cup button? Should I panic? Does this need to be taken in for repairs or is there a simpler solution?
  • caylahache
    caylahache Feb 27, 2012
    Thanks for the suggestion to fix my problem, but I have no idea how to 'back flush' my machine or where to find 'back flushing powder'. Perhaps some more details about that process would help?
    As well, the machine's buzzing and crackling noise seems to get worse if I brew more than 1 shot at a time. Then again, the problem seems intermittent -any chance that there is a connection issue with the electrical panel and the button> would re-programming the automatic settings help?
    Any suggestions are greatly appreciated!
  • caylahache
    caylahache Feb 28, 2012
    Thanks for lengthy explanation Mark.
    I completely understand what you mean now in regards to the back flushing. In my Breville manual cleaning guide it references the same process you are describing, it's just a Breville brand cleaning tablet (not described as flushing powder) that gets placed into the rubber disc and then you carry out the cleaning. I think it's a good idea, so I will try it.
    I also understand what you mean about the back valve. (I am just apprehensive to start poking around too much with the components on my machine). It does seem to be struggling with bringing water through to the group head. The steaming process isn't affected. I have tried running water through with and without the portafilter in place and it always makes the buzzing noise.
    I will try cleaning the machine and hopefully that will help.
    Again, thanks for your tips. It's most appreciated.
    Cayla
    Problem Solver:
  • 7 Answers
Machine my need a new exshust valve try back flushing the machine with only a pinch of back flushing powder.
Posted on Feb 25, 2012
  • mark lett Feb 28, 2012
    Hi There,
    back flushing - with your machine there should of been a rubber or plastic disc(sometimes they strap them to the machineor inside a pannel ) , you place the disc into the coffee handle with a product called coffee clear but I'm from New Zealand and maybe called something else where you are from. Press the espresso button let the machine run for about 15sec and stop repeat the process three to for times, once completed repeat the process again with no product to rinse group head and to remove any left over product.I suggest trying a department store for the product.
    I believe the buzzing noise is the valve that opens to allow water to flow through the group head this may not happen all the time. I dont think the buttons on the front would cause this as this would be low voltage.
    Re-programming would not fix this fault.
    Does the the noise appar when running hot water or steaming?.
    Kind regards
    Mark
SOURCE: after using coffee that was too small, I can't make coffee with one of the filters
I'm not sure you can. I did exactly the same thing, the very first time I used it -- I phoned Breville support and they told me to try soaking the filter in 2 tsp of baking soda dissolved in a cup of warm water. Which kinda seemed to work, although it was bit occasionally reluctant to give me my damned coffee.
I struggled on with it for maybe a year, but then the rubber seal around the bit the filter connects to blew out (with rather dramatic results). I think the extra pressure of the blocked filter did more damage that I suspected.
I got it serviced and they replaced both the seal and the filter. Worked great after that...
...until last week, when water started pouring out where no water should pour. Turns out that the black lock block that the filter holder goes into has developed a crack.
Looks like another trip to the service agent for me.
In short, you could try cleaning the 1-cup filter, but I would reccommend giving it up as a bad job and just buying another.
Before It Is Too Late.
(Signed, The Harbinger of Doom. Sorry about that.)
Posted on Feb 02, 2008
SOURCE: to buy replacement parts
Need the mesh filter for grind coffee
Posted on Mar 24, 2009
SOURCE: Breville Cafe Roma ESP8XL - cup is moving during the process
Once you've got the tamp right: no more rattles! The perfect tamp also makes a better cup of espresso.
The single hole is not a cheapo, lazy manufacturing defect.  The Cafe Roma has a "double walled" basket which is to produce a thicker crema.  The single hole is designed to allow pressure to build up behind it thus forcing a jet effect in the basket, giving the the coffee its crema.  This, by the way, is why it is also a sloppy/wet puck rather than a dry one.
The thump during steaming just gives me something to dance to in the morning.  "When the saints go marching in" always seems to come to mind;  perfect timing.
I am very happy with my Cafe Roma.  Just took some practice.
Happy espresso to you,
Posted on Jan 18, 2009
cmccune04
  • 213 Answers
SOURCE: Lost the K-Cup holder and cannot find where to buy the part
http://iwantsweetdeals.com/Keurig-B30-B40-B50-B60-B66-B70-B77-Replacement-K-cup-Holder-Assembly-Part-J-P1208231.aspx
This part fits your brewer too!
Posted on May 26, 2010
SOURCE: My Breville Cafe Roma Espresso
A dirty grinder or plunger will make your coffee dirty. Try mixing some vinagar and water (2 parts water and 1 part white vinegar) and then run it through your machine to clean out the inside. (Repeat this three times) Click on the link below to view more detailed instructions on how to properly clean your Breville:
http://www.ehow.co.uk/how_7498086_clean-breville-espresso-machine.html
Posted on Nov 29, 2010
What are the features of Breville BES870XL Barista Express Coffee maker for my home. Where can I buy it in good discounted rate?
FEATURES OF bes870xl_barista is as follows -
  • 15 Bar Italian Pump and 1600W Thermo coil heating system
  • Purge Function: Automatically adjusts water temperature after steam for optimal espresso extraction temperature
  • Stainless steel conical burr grinder with 1/2 lb. sealed bean hopper
  • 67 fl.oz (2L) removable water tank with handle
  • Newer model of the Breville BES860XL Barista Express
It has stainless steel color. And you can order it great discounted rate from where I purchased it after comparing all the other brands and prices also. Best Espresso Machine is one of the best site to compare and get best detailed knowledge of every brand....
Oct 07, 2016 | Breville Coffee Makers & Espresso Machines
Wont go through start up, it stops and light flash
Espresso Makers FAQs at MrCoffee.com.
www.mrcoffee.com/.../espresso-makers/espresso-makers-faqs....
Mr. CoffeeBrowse our Espresso Makers FAQs to find answers to common questions about Mr. Coffee products. ... Why is the espresso running out of the sides or top of the filter holder during brewing? ... Why is my espresso maker not making espresso?
[PDF]Getting to know your machine - Breville
https://www.brevilleusa.com/media/.../BES860XL.pdf
Translate this page Programmable Espresso Machine with Grinder ... to persons. Do not attempt tooperate The Barista Express ... Do not operate the grinder without the hopper.
Espresso Machines 101 - Home-Barista.com
www.home-barista.com/espresso-machines/espresso-machines-101-t368....
Jul 22, 2005 - This is a short summary of how these different machines operate under... You do not purchase a lever espresso machine to produce a hassle ...
CoffeeGeek - Choosing a Manual Machine
coffeegeek.com/guides/howtobuyanespressomachine/man
Dec 19, 2015 | Coffee Makers & Espresso Machines
Water is leaking from my Breville Barista Express Espresso machine's water tank valve.
u r is the 4th problem with the same unit. take it bak to the store and git another 1.
Feb 23, 2015 | Breville The Barista Express BES860XL Open...
My bes870 will not create enough pressure to form a good crema ,grind setting is 2-3 .Amount of ground coffee is correct but the pressure does not go much past the pre fusion pressure .The machine has...
For an 8 month old machine it should still be under warranty unless commercial use. (similar unresolved Q posted http://www.fixya.com/support/t20409606-get_pressure_up).
Jul 20, 2014 | Breville Barista Express Espresso Machine...
Breville making really loud noise when push espresso button
My machine started making a buzzing noise after the cleaning and descaling. It was still under warranty and I was planning to have it fixed by the manufacture but after a couple weeks of using it the noise stopped.
Feb 02, 2014 | Breville The Barista Express BES870XL...
I just bout the 870 barista i pulged it and the filter size led keep flashing i cherthe hopper and its properly seated
As it is new I suggest that you contact the store where you bought it - may be simple fix or a fault under warranty. Maybe a small sensor that needs to be contacted by when the filter is in the right position.
Aug 24, 2013 | Breville Barista Express Espresso Machine...
Grinder jam on breville barista express
Only way to know for sure is by taking it completely apart and expose all the internal parts
Popping is not a good sign If it is electrical arcing you are playing with fire
or electrocution
If you are mechanically inclined they are not that hard to take apart as long as they have no security screws on it and you have to remember you might be voiding your warranty
But it is fun taking things apart No?
Feb 06, 2012 | Breville Coffee Makers & Espresso Machines
How many oz of expresso when making a 2 cup with the machine in a measuring glass . i bought two measure shot glass to make a perfect cup of latte. i know it says 24 seconds
For every cup of espresso we mean about 25cc to 30 cc and you have to use from 7 to 8 gr of groud coffee per cup according to the coffee blend and how strong you wand the aroma of your coffee. The running time for making either one cup or two cup with apropriate filter is about 24 to 30 sec maximum.
Good luck
Apr 18, 2010 | Breville ESP8XL Espresso Machine
No steam or pump noise
get a used starbucks barista by saeco for a couple hundred...you'll be pleased. (know i am-and i only paid $25 for my year old breville esp8xl POS). verify it works-it will probably last longer & perform better. if inclined/capable, maybe you can replace the pump yourself (a new one's prob in $35-$40 range; if more, scrap the machine or sell it "as is" for parts & put the money toward a better machine. good luck!
Oct 07, 2008 | Breville ESP8XL Espresso Machine
Breville BES860XL Logo
2,720 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Steve
Colin Stickland
Colin Stickland
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
