Question about Kitchen Ranges
Gaggenau AH 180-190 kitchen hood light glows dim and will not switch on properly
Model AH180 - tube light stopped working. Replaced with new tube. Light glows dim at one end of the tube (old and new). It will not switch on properly. The problem feels similar to a fluorescent light tube when the starter needs repacing but I can't see a starter.
  • 833 Answers
SOURCE: kitchen aid stove problem
Peter,
First...be sure you cut power to the stove before you do anything. This is 220 volts and it can kill you. 220 Volts is based on two different lines of power coming to the stove, each of which is 110 volts...but opposite each other in phase. This may mean that some power to the stove is on and some is not. Let's go on.
I suspect a few things: First, the coil control for the burner is probably finished. What I also suspect is that it opened one of the two breakers (they are usually tied together in the panel and are either 40/50/60 amp units) causing some lights but no action.
What to do: Reset the breakers as a pair by turning them off and on. If one snaps off, you have a problem at the stove. If not,...which I doubt...you're in business.
Let's look at replacing the control. Shut the breakers. Now, take the burned control and remove it. Note the wiring positions if they are not on a plug. If they are terminals, tape the ends. Now, reset those breakers. If the other burners work, replace the control. Take the old one to the parts store. If it doesn't work, look around the burned area for broken wires. Repair and tape them up. Try again. Oh, and don't let anyone touch the stove while you're working with those breakers.
Posted on Dec 03, 2007
SOURCE: Fluorescent light that keeps flickering
The ballast is a device that utilises and expanding/contracting electromagnetic field to create the high voltage which is needed to run fluorescent lights.
It is normally found behind the front cover or reflector part of the fitting and looks like a small box.
Replacement should normally be done by a person qualified in this field.
Posted on Dec 06, 2007
  • 139 Answers
SOURCE: Light doesn't work on Kenmore Model 55022 Range hood...
If you have 120VAC on the center contact of the light socket, and a working fan, but the bulb won't light...the most likely cause would be a disconnected neutral wire (white) in the light wiring inside the hood....assuming everything else is wired correctly.
If you're comfortable with further electrical testing...let me know, and I can describe a detailed procedure to check the status of the neutral wire. Otherwise, you may need the assistance of someone familiar with electrical troubleshooting or appliance repair.
Posted on Jan 27, 2008
SOURCE: Fan and light not working where is fuse box?
Hi - I have a neff extractor fan and have the same problem. The light and fan have both stopped working. Does anybody know where I can find the fuse as I suspect that this may be the problem too?
Posted on Feb 16, 2008
  • 171 Answers
SOURCE: WS3 Broan Allure Range Hood Premier 36 inch
Hi shealy,
I'm Harvey the Master Plumber.
Your problem is: This hood worked fine until a light bulb blew out. Put in a new light bulb, but the lights will not turn off. Is the light switch bad or is there a problem with the control panel? The fan still works fine but the lights will not turn off or adjust dim or bright.
You're on the right track. The light control switch needs replacing. You might try utilizing the Repair Directory to find a repairman. If you have the tools and ability just remember to turn off the electric first.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
Cold air is coming in from outside, didn't do this before.
Look up into the duct if possible. There should be a damper in the duct called a "backdraft damper" that closes and prevents cold air from entering the duct when the fan shuts off. The damper could also be located near the outlet of the fan which could be a wall or near the roof level (maybe in the attic if it goes through there).
Dec 17, 2009 | Gaggenau AH 600 Kitchen Hood
Recently moved in and I have a Gaggenau exhaust/light hood that slides out over cooktop. I don't know model but controls are on right vertical side of unit. I don't have a manual and the light and exhast...
I have the same probelm. My control board is blown. You can see that easily if you open upm the case on top of unit in tehh cabinet in a smaller metal box. If it is blown like mine it will be very obvious.
Aug 05, 2009 | Gaggenau AH 900-761 Kitchen Hood
Dimmer light won't work.
you are using incandescent bulbs because most dimmer will not work with Fluorescent otherwise sound like a bad switch, if it new return it. They are fairly easy to replace. Hope this Helps Paul
Jun 17, 2009 | Kenmore 51840 Kitchen Hood
Gaggenau AH 250-760
I repair them in nyc all the time. unit will work for years after repairs. 1-888-nyc-1055
Jan 27, 2009 | Gaggenau AH 900-761 Kitchen Hood
Hi shealy,
Thank you,
Sep 08, 2008 | Broan-NuTone WS330 Kitchen Hood
The lights dont turn off anymore
On line....sound control board to me...
Dec 29, 2007 | Jenn-Air JXT8136ADS Kitchen Hood
No Power - Problem locating fuse
I have repaired many Gaggenau extractors before. On this model you were correct to remove two top screws from duct. The top and lower duct slide inside each other, and should be removed as 1 unit, by lifting the lower duct UP and then away from the wall. Sometimes there are two further screws holding the bottom duct to the canopy. Remove the filters and check for screws from inside canopy. Once ducts are removed you will see the a box, metal or plastic. Remove lid and you will see the pc board. There is a 10A fuse on there. Some models do not have fuses, and the whole board should be replaced! Good luck! C.
Nov 26, 2006 | Gaggenau AH 400-701 Kitchen Hood
Kitchen Ranges Logo
90 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
