Question about Infinity BU-120 Subwoofer
Need to know frequency of capacitor on in location c6
Red blink 2x
Good day,
I am reading that this is a circuit failure. I would refer you to a technician to repair/replace the board.
Good luck...
Jul 15, 2014 | Panasonic TC-32LX60 32 in. LCD Television
JLB PSW-D110 Subwoofer Issues
Hummmm is from Output amplifier and you need to replace it because power supply blow it too.
Sep 09, 2008 | JBL PSW-D110 Speaker
I live in Spain, just bought Nokia C6 smartphone,,,need English users guide.
You can download and print the instruction manual(English) for Nokia C6 in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Apr 11, 2011 | Nokia C6 Smartphone
I forget my Nokia C6 phone lock code. please help meeeee :((
Hello and Welcome on FixYa!
The Default phone lock code of Nokia is 12345 or
00000.
If you have changed then to get your Master code. Type *#06# at the mobile screen to know IMEI no of your mobile or you can also see the IMEI no after pulling out the battery, It is mention at back side of the mobile Then Go Here.
Give your IMEI No there and calculate your master code and try it.
It will work as your security code If it doesn't work too then you can get online paid security code for your cell. If you want to then you can Go Here.
After getting your Cell info and charges, they will send you code.
If you don't want to then you can contact to NOKIA SERVICE PROVIDER to get your phone lock code
Anymore help, I am here to help
If it is HELPFUL, Your Rating as FOUR THUMBS (Given below to this solution) and testimonial will be esteemed.
THANKS and Keep Visiting FixYa
Mar 28, 2011 | Nokia C6 Smartphone
The led panel on the indoor unit shows a C6 error code the air con is a split system plasma inverter
C6 - compressor run current high
- check [resistance of] compressor windings all equal 1 to 4 ohms
- check [resistance] to earth 50 Mohm minimum
- check run current
I'd also check the motor capacitor(s) , In maximum, it is due to weak capacitor. Replace and try.
Dec 16, 2010 | Heating & Cooling
Wii balance board bottom left sensor not working
Most likley a bad capacitor on the sensor input located on the board. Unsolder the problem sensor, measure accross each individual capacitors (3). Should measure infinity. If not remove capacitor and solder back the sensor. These are high frequency filter capacitors which is not critical to the operation of the board.robicham.pngrobicham.jpg
Mar 21, 2010 | Nintendo CTA Digital WI-BBP Wii Fit...
Hello have a inverter LG Airconditioner and it keeps turning itself off and showing the letters C6? Any ideas
Error Code: C6 Problem: Inverter compressor run current high
SOLUTIONS:
- check run current
Probably best to explain/print out and give to authorised serviceman
Mat
Jul 14, 2009 | LG Heating & Cooling
C6 Polarity?
Hi CALSunbelt
There is no polarity to be conscious of when you are using a BiPolar cap. They can be used in either direction.
regards
Graeme
Apr 06, 2008 | JBL PSW-D110 Speaker
Kyocera Mita KM 1500
Still sounds like there is a problem with the fuser unit. The technician that replaced the parts should be able to troubleshoot the problem.
C6 = Fuser error. The unit is not heating up due to a bad Fuser lamp, fuse, or thermostat, or bad thermistor.
The circuit is open, and the machine won't work til the problem is repaired. Once open circuit is repaired/closed, the machine should reset on it's own after you power the machine down and back up.
Does the machine flash the C6 right away as soon as you turn it on OR, does the C6 show up after about 3-5 minutes?
If you get the C6 right away, then the circuit is open, and that needs to be fixed.
If you get a c6 after 3-5 minutes, then there is a good chance the lamp is bad.
Hope this helps.
Good luck
Feb 08, 2008 | Video Cameras
Lines in AG-dp800h
Hello all!!
I found the solution!!
3 electro chemical capacity in the 3700 series on the camera head board.
change the chemical rear the DAC and above the ADC for process digital signal.
The name of the capacity: c3 c6 c9 in the 3700 section on process board.
The capacity is a part of filter the reference signal out of the DAC for ADC reference for ic1 ic2 ic3...
If the capacity is dead a sinusoidal signal appear for the red blue and green reference voltage and the result is a parasit signal into all camera.
You can measure a 50khz signal on the composite video signal.
Best regards
Phil_F
Jan 13, 2008 | Panasonic AG-DP800H Camcorder
Infinity BU-120 Subwoofer Logo
Top Infinity Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you an Infinity Audio Player and Recorder Expert? Answer questions, earn points and help others
