Question about Sansui VRDVD4005 DVD Player/VCR
Dvd player get a real good one that starts cleaning when you put it in there , because if its not reading dvd's , then it won't read the cheap ones unless your dvd player can still read music cd's here is an example of a lens cleaning disk http://www.youtube.com/watch?v=F38GcWUoTPM
Program DVD player to TV
Posted on Nov 04, 2008
Won't read the dc
First, Try another DVD to be sure its not just a scratched disk. Make sure the disk is spinning (you will hear and feel it spin up). If its spinning but still wont read you can clean the lens inside the DVD player with a air compressor or can of compressed air. The better solution would be to use a CD designed for cleaning the lens that read the DVD. They are quite cheap and are very nice to have around. If it still will not read then you are much much better off just junking that DVD player and buying another. They do not make replacement parts for DVD players and they are getting very cheap to replace. Good Luck. Thank You
~Kyle~
Aug 16, 2012 | Coby Televison & Video
I have a Matsui M19DVDB19 TV/DVD/Freeview and the DVD has stopped working
What it means is the unit is reading the disc and is unable to do so.
Either the optical pickup in the DVD unit is dirty (you can attempt to clean with either a cleaning disc or by hand if you know how)
If cleaning does not resolve this the optical unit is bad--it happens---just buy a DVD player and hook it up to the set---DVD players here are dirt cheap.
Cost to repair one is several times more than replacing it with a separate unit.
Apr 04, 2012 | Televison & Video
I put Windows 7 Ultimate on my computer, now windows media player won't read from my cd/dvd, but real player will play from it. It says I have 14 tracks all the same length and time.
on system start up time press F8 key for no of times.you can see some option from that you can select repair and continue with options given
Mar 12, 2012 | Computers & Internet
The dvd player will not read the disc
If it won't read any disc you put in, consider getting a new DVD player, the eye is most likely gone bad. If it is only one disc that you can't read i would suggest a Scotch DVD Cleaner kit. Cleans and Repairs discs, helps prevent skipping and mistracking, and repairs minor surface scratches improving disc audio and image quality.
Jul 28, 2011 | Cyberhome CH-LDV1010A Portable DVD Player
My portable dvd player will not read any dvds
  • I would give it a good cleaning with a disk player cleaning. Those disks have little bristles on them that "sweep" the lens and clean it real well. Remember that if the lens is so dirty that it won't play any DVD you may need to run that cleaner disk a few times to get the lens back to normal working condition.
  • A lens cleaner disk should be ran one time a week to avoid problems with playing disks be it CD or DVD or Computer.
  • Sometimes players go bad so keep in mind this could be the problem as well but I have had the DVD player in my garage get so dirty I had to clean it a few times to get it to work normal.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 11, 2011 | Sylvania SDVD8732 Player
Dvd player won't play disc
The DVD read head may need to be cleaned. Sometimes perfectly OK drives also fail to read certain discs. If the problem is persistent, i.e. the notebook won't read any discs, then clean the head (with a head cleaner) and try again. If it starts working, fine.. If not, then you may have to replace the DVD drive. If the problem is only related to playing one particular DVD, then its the DVD that is faulty.
Hope this helps.
May 25, 2011 | Toshiba Satellite P505D-S8935 Notebook
We have a 23" Toshiba with a internal DVD player.
No,tv internal DVD player are not on sale by itself as a seperate unit,only can buy it from the tv corporations themselves and it not cheap and have to have experience to putting it in into the tv internal tv itself.The tv internal DVD player now,could be the laser eye data reader have problems reading mp3 and mp4 files on the DVD disc,which are video files.Now tries to play more than one DVD movies dic,tries like to play like 5 to 6 original DVD movies.One disc don't play tries another DVD disc.Tries this might forcing the laser eye reader to read DVD dics again and than might fix it to read video files again.Or just buy an external DVD player hook it up to the tv and play DVD disc on to the tv video modes.DVD players external devices are really cheap these day,like can buy new one for $40.
Mar 25, 2011 | Toshiba 23HLV84 23 in. TV/DVD Combo
Not reading and playing dvds
You can try cleaning the DVD lens.
DVD just says loading--
This can be as simple as a dirty DVD lens. CAUTION!! The lens is delicate! I wipe DVD lenses with ONE drop of glasses cleaner on a Q-tip and, starting in the center, wipe in circles to the outside. Do not press down! Do not force the lens side to side. It will move while cleaning but don't put more pressure than needed to move the lens 3/4 way down!
Its a cheap test to see if there is a fingerprint on the lens. (You won't be able to see it - does not take much)
If this does not help, it means it needs a laser or worse. Probably just replace the player.
Apr 16, 2010 | Durabrand DVD-1002 DVD Player
Will not read DVD it says incorrect disc. I can put it in laptop and it will read the DVD but not the DVD player. It won't read any DVD's.
Clean the dirty optical drive with one of those commerical DVD cleaning kits they sell at the box stores. Also, could be the DVD is region specific. Region 1 is USA meaning the DVDs will only play on Region 1 DVD players. You can buy region free DVD players on e-bay for cheap.
Theres a reason they call these DVD players Broksonic. Because they are always Brok. Spend a few dollars and get a name brand next time, because they last longer since those companies invest more in R&D and quality control.
Jan 31, 2010 | Broksonic Televison & Video
Sansui VRDVD4005 DVD Player/VCR Logo
41 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
