Question about Hitachi Air Tools & Compressors
Bostitch piston/driver replacement.
I am replacing the piston driver in a Bostitch SX1838 that snapped. Does the 180462 driver guide just sit in the nose of the stapler? The old one is just floating around down there.
  • Hitachi Master
  • 885 Answers
The driver guide just sits in the bottom of the head, the bumper sits on top of it and holds it in place.
Posted on Feb 29, 2012
2 Suggested Answers
puertobori
  • 7733 Answers
SOURCE: spring on the finish nailer
Try here ->link.
Posted on Oct 14, 2010
Bostitch MIII FN drive pin is broken
The driver is held on the piston stem by a steel dowel/pin. There are nylon inserts on either side of the dowel to hold it in place. Pry the inserts out and press the pin out to seperate the driver from the piston stem. If you don't damage the inserts, you can reuse them. Bostitch recommends replacing them any time they are removed.
Feb 25, 2013 | Stanley Bostitch MIIIFN Flooring Nailers
Stanley Bostitch N60FN finish nailer only pops when the trigger is pulled.
replace broken driver, or if driver is not broken replace the oring on the driver piston
Sep 10, 2012 | Stanley Air Tools & Compressors
My bostitch n88rh framing nailer will fire when pointed down but wont fire pointed horizontal.
Nailers are made to use in any position so must be something simple to fix. Most likely safety contact foot, to test, remove the nails, remove the trigger to expose the firing button on the trigger valve. Connect air and dry fire onto wood or old coiled rubber hose in various positions. If the gun tests ok then carefully examine safety foot mech. and trigger for loose components missing guide or roll pin. The contact foot must push firmly up on the lever within the trigger thus pushing on the firing button. If the safety foot and trigger are in good conditon and working ok, then problem is within the headvalve and piston orings. To test piston oring, remove airline and nails, point nailer up then down again. The piston should stay in the top position. If the piston moves up /down with movement of gun, replace piston oring. If piston oring ok, remove the head and pull out the headvalve. Apply plenty of silicone paste or white grease to orings on headvalve and reinstall and test. If tests ok, then problem is worn orings in the head /headvalve. You can keep lubing or replace orings. Examine the surface within the head where headvalve orings make contact. If there are many fine scratches, even new orings will not work very well. Try to remove scratches with very fine sandpaper. Good luck
Apr 29, 2012 | Stanley Bostitch N88rh Framing Nailer...
Air is streaming out of the trigger mechanism.
I dont think it is your piston assembly, there is an o ring on the trigger valve assembly that is broken and would need to be replaced, If you need help getting it out let me know and I will guide you thru it. But while you have it apart look for worn o rings and now might be the time to replace them.
Feb 20, 2011 | Stanley Piston Driver Assy Bostitch N60fn...
My bostitch compressor staple gun is not working. The compressor itself works fine, the other two guns work, but the staple gun-when you depress the safety and pull the trigger, the air comes out from...
If its the stapler I believe it is (SX1838) it has a broken driver. These staplers have a factory flaw in them, the drivers are faulty. Bostitch has since repaired the problem from the factory but their are still nailers out there that have this problem. Sounds like you have one of them, its an easy 5 min fix but you need to go to a Bostitch cervice center in your area and get a fresh driver installed. Your stapler has a 7 years warranty so it won't cost you anything. As a Bostitch service center I have done hundreds of those staplers, once the driver is changed ou shouldn't have this problem anymore.
Jan 04, 2011 | Stanley Air Tools & Compressors
Stanley Bostitch N89C-Piston will not retract. Forgot to oil today-used ,yesterday and today, perhaps 200 nails. If I have to disassemble do I open from top or bottom?
Lack of oil usually will not prevent driver from retracting (bent driver /debris / worn piston oring / cracked lower bumper / loose check valve ) . Remove nails and push driver up. It should not require much force to move driver / nor be so easy that driver fall back down under its own weight. If driver feels loose, replace piston oring. If it feels about right, most likely problem is the check valve. Remove head and pull cylinder. Look for band around cylinder covering series of holes. It should fit snuggly. If loose replace with new part or use any rubber available or series or orings to fit space. If check seal looks ok then examine lower bumper for missing pieces or cracked. Lube with silicone paste lube sold at Lowes. Parts are available at www.toolpartsdirect.com . Good holidays
Dec 28, 2010 | Stanley Bostitch N88rh Framing Nailer...
Looking operators manual for stanley bostitch rn45b
Look here for manual and parts:http://www.bostitch.com/default.asp?TYPE=STATICLEFT&PAGE=tooldoc_results.htm&Left=left_tooldoc_results.htm&partNum=WM45B&serialNum=
The two lines of address above should be all one line in the address bar. If it does not work, go to www.bostitch.com , service parts and find wm45b. Good luck
Sep 18, 2010 | Stanley Pneu Roof Stapler
Nail is jammed in my Bostitch power finish nailer and partially sticking out. When pull on nail with pliers, it won't come out.
Remove driver guide nose peice, should be a couple of alan screws, remove nail, check driver to make sure it is not bent, re assemble. Make sure you are using the correct Nails!
Aug 27, 2010 | Stanley Bostitch N88rh Framing Nailer...
Replacing driver unit in bostitch 23 gauge pin nailer model hp118k access through top of frame unit or bottom
Access is via the head cap. Remove the 4 screws and carefully take off the top. Be careful the head plunger does not fall out and keep it upside down.this way you are sure how to put head back on.
tap top of body against your hand to drive piston up and remove and replace piston assembly.
good luck
Apr 14, 2009 | Stanley Bostitch HP118K 23 Gauge Headless...
Bostitch Framing Nailer fails in colder weather
the prblem may lie with the oil that you are using
[too thick] or the guide is worn
Nov 17, 2008 | Stanley Bostitch N88rh Framing Nailer...
Air Tools & Compressors Logo
90 people viewed this question
Top Hitachi Air Tools & Compressors Experts
John Trevino
Jim Thurston
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Hitachi Air Tool and Compressor Expert? Answer questions, earn points and help others
