Question about D-Link DFM 562E (dfm-562e) Modem
Fax modem hi im just new here this is the first time im asking help true fixya im hoping you can help me. want to fax by my computer using a fax modem is it posible? what are the thing that i have to know
Thanks for the great tip. i really appreciate it.
but what about my modem?
i really want to use it.
what would be the requirement for it.
hope you can help me. thanks
Posted on Oct 29, 2008
    Sergeant:
  • 359 Answers
The best solution is not to need a fax/modem. Send and receive faxes via internet.
This program was PC Magazines editors Choice:
http://home.efax.com/s/r/efax-brand9?VID=33675&gclid=CL_th9ybypYCFQOIFQod1iRdyg
This way you don't need a phone line/ tying up your phone line etc..
Posted on Oct 28, 2008
How I can receive fax through computer with HP1312?
Hi a barati75
A fax transmission is an analogue communication that was possible on a computer with the old technology of Dial up Modems, which accessed the internet by dialling like a landline telephone. The Broadband Modems (or Modem/Routers) in widespread use today have an 'always on' internet connection and, therefore, no dialling is involved in internet access using them.
You can send a fax by dialling out on the All-in-one printer's telephone number pad. Receiving a fax automatically requires you to have the All-in-one printer's Transmission/Reception Settings set to 'Automatic'.
This fax setup requires the printer's fax cable to plugged directly into an empty Telephone Line Socket on the ADSL filter that plugs into your Telephone Wall Socket and has inputs for your Modem (or Modem/Router) and a Telephone line. If, as is common, your ADSL Filter only has a single Telephone Line Socket and you also require a telephone to be plugged into the same socket as well as the Fax Machine component of your printer, then a Telephone Line Socket Doubler must first be plugged into the Telephone Line Socket of the ADSL Filter which then receives the Fax Line into one socket and the Telephone Line into the other. Please note that every Telephone Socket in the building sharing the same circuit/telephone number must also have an ADSL filter between it and any telephonic device (Telephone/Fax Machine/Answering Machine/Stock Control linked EPOS (Electronic Point of Sale) System/Card Payment Processing Machine, etc.), in order to enable both Computer Internet Data and Telecommunications Data to share the same line without conflict.
Your question asks whether a fax can be received "through" the computer. The above description enables your printer to send and receive faxes 'independently' of the computer while simultaneously providing the computer with printing, scanning and copying functions. For faxes to be sent and received via the computer, software is required. The simplest and most efficient of which is Efax (Electronic Fax (available from www.efax.com) and other similar software available from a variety of suppliers. This software enables the user to send any document or image stored on the computer by fax (without first having to print it) and to receive faxes, at any time, in the form of attachments to e-mails that the software opens, usually as a non-editable PDF or other similar secure Document Format. Faxing a physical document via Efax requires the user to scan the document and save it on the computer first, before sending it.
A combination of a Standalone Fax function setup using ADSL Filters and Socket Doublers + Efax gives the user optimum flexibility in sending and receiving faxes.
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it.
Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can.
If you need further help, please do not hesitate to post another Question or add a Comment/Clarification Request to this Question.
Thanks for using FixYa
Sep 15, 2011 | HP LaserJet CM1312 All-In-One Printer
How to receive fax documents
You cannot receive fax using this printer, because this printer doesn't support fax sending/receiving. Only fax supported printers can receive fax documents. You will know if a printer is fax support if you see a Fax button there or if you can see a numpad buttons where you can dial numbers.
These are the photo examples of fax printers
Hope my solution helps. Thanks for using Fixya!
Jul 11, 2011 | Canon PIXMA iP4000 InkJet Photo Printer
I have an HP 2510 printer. I cannot use it to fax because once I plug the phone jack into the printer I get a busy signal. If I plug the jack into a phone, it works fine. How do I get the printer to...
Hi irwinbadin,
HP fax products are designed so that other telephone equipment can be connected on the same line as the fax. The unit must be connected first using a two-conductor fax/phone cable like the one that shipped with the HP product. Using a four-conductor telephone cable may cause problems receiving faxes or calls.
There are two different types of phone cables. There are two-conductor phone cables like what originally shipped with the HP fax product and there are four-conductor cables. HP fax products are designed to work with a two-conductor phone cable. Look at the end of the cable and verify that it has only two copper leads or wires. Replace any four-conductor cables with a two-conductor cable. Only two-conductor phone cables should be used to connect the all-in-one to the phone line.
Figure 1: The difference between a two-conductor phone cable and a four-conductor phone cable
Step one: Connect the phone line to the fax
The fax will have two or three sockets (or jacks) for phone lines. Some of these may have a removable plastic plug in them. These sockets will be labeled with text, To Wall Jack , or with a graphic of the wall jack. See Figure 1 below.
Plug the two-conductor telephone cable that came with the HP product into the telephone wall jack. Then, plug it into this socket as shown below.
In areas with above ground telephone lines and electrical storms (lightning), it is a good idea to purchase a telephone line surge suppressor and connect it between the telephone wall jack and the fax. This will help prevent damage to the fax from a lightning-caused power surge on the phone line.
Step two: Add other phone-line devices
To connect other telephone devices, use the other socket (or sockets) on the fax. These are identified by text or with a graphic of a telephone and/or computer.
Connect a caller ID unit between the fax and the telephone.
Use the information below that matches the devices you need to connect.
Fax and telephone
Connect a single-line telephone to one of the added sockets on the fax. The telephone will share the same phone line as the fax. See the illustration below.
Fax, answering machine, and telephone
When a telephone answering machine and telephone are connected, connect the answering machine to the fax and then connect the telephone to the answering machine as shown below.
Fax and computer modem
To use a fax and a computer modem on the same phone line, connect the fax to the computer modem. The modem socket on the computer may be labeled Line or Wall jack .
Fax, computer modem, and telephone
To use a computer modem and a telephone with the fax, connect the computer modem to the fax. Then, connect the telephone into the second phone line connector on the computer modem or the third fax socket (if it is available). The image below shows how to connect a computer and a telephone to a fax with two sockets.
Fax, modem, answering machine, and telephone
The image below shows how to connect a computer modem, answering machine, and telephone to a fax. Connect the computer modem to the fax, then connect the answering machine to the computer, and finally, connect the telephone to the answering machine.
If the fax has three phone line sockets instead of two, some of the devices can be connected to the other phone socket on the fax.
Hope it helps.
Thank you for using FixYa.
Jun 27, 2011 | Office Equipment & Supplies
Im trying to hook up to the internet to my old thinkpad X32 i used a modem didnt work and i noticed that its wireless its at the points when it says activate windows plzzzz help.
When Windows starts asking for it to be activated, some of the functions of the computer are being disabled. What you need to do is to reinstall Windows by using your IBM ThinkPad X32 Recovery Disk. The Recovery Disk for your computer has a pre-registered and pre-activated Windows. Call IBM/Lenovo at 18774536686 to hopefully further widen your options. You might spend $40~$60 to resolve this issue.
I hope this works for you. Kindly reply/comment for further assistance. Good Luck!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Apr 08, 2011 | IBM ThinkPad X32 Notebook
I cannot receive faxes using my fax console in WinXP. There is no dial tone. When I query the modem, the log reveals this command in the frame: AT#CLS=? COMMAND NOT SUPPORTED. I used to be able to...
Hi:
I have'nt used computer modems to fax in a long time, but will try to help, If you can edit the command line enter ATDT this command means Attention Dial Tone. Enter this command to see if you hear a Dial tone. I also suggest you try taking out the modem to reset it. let windows load without the modem in the computer then shut down windows compeletly and reinstall the modem so windows can reinstall the drivers for the hardware, if you have upgraded windows to a different version since you last faxed, then it would be wise to look for updated drivers.
May 14, 2010 | Computers & Internet
IM CHECK THE 72-F OF A CLIENT AND ALL WIRING IN THE EVAPORATOR ARE DISCONECT.I NEED A DIAGRAM
i think the best thing to do is call true mgf. and ask them to fax or email the diagram for you they might want a serial number as well
Toll Free: 800-325-6152
hope this helps
Mar 29, 2010 | True 72 cu. ft. / 2039 liter Commercial...
I can not Receive a Fax, says I have no caller ID
This behavior occurs because the program that you use to access the modem or fax does not use Telephony. For example, this behavior may occur if you use the Windows XP Fax service, and all the following conditions are true:
  • You use a PCI Modem/Fax card.
  • The modem uses one of your computer's COM ports.
  • Your computer is Windows XP Media Center 2004-based
  • You have turned on the CallerID feature.
Jul 09, 2009 | HP Officejet 4315v All-In-One InkJet...
Do I need a 56K PCI Data Fax Modem for my new computer? If yes, why? If not, why? Thxs.
You only need a modem if you are going to be on a on a dail up internet connection or want to use your computer for faxing.
If you are using a broadband internet connection like cable or DSL, then the modem is not needed.
Hope this helps
May 02, 2009 | Intel PC TEL 56K (pctel56k) Modem
FAx & modem config
hi kababayan!
i think it's on VoIP feature...
please visit this site for more info:
http://www.microsoft.com/windowsxp/using/setup/learnmore/crawford_02october21.mspx
hey, what company do you work for?
Apr 23, 2008 | 2wire 2700HG-B Router (2700HGB)
NetoDragon voice-fax 56k modem - i need a driver for this
You can download the driver from HERE
This link will expire, if it does:
HERE is the link to the driver, although, you have to signup, or go through the ad option
Apr 10, 2008 | Conexant Cnet 5614RV V.92 56K Internal...
D-Link DFM 562E (dfm-562e) Modem Logo
196 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
