Question about Prince Lionheart Premium Wipe Warmer
My wipe warmer isnt keeping the wipes warm any more only used it for 3 weeks and the lid is on tight
Make sure the "pillow" is quite damp (we put ours in dripping wet) and, if you're using cloth wipes, make sure they are damp enough before putting them in the warmer.
Posted on Mar 01, 2012
  • ken mondshine Apr 02, 2012
    sounds like the heating element is broken.
Tip
How to keep your fridge clean
Everytime you are waiting for the kettle to boil or waiting for something to warm up in the microwave, even if it is only 1 or 2 minutes, use this time to open your fridge and wipe the bits of the shelf that you can see with a damp cloth or piece of kitchen towel. Just one shelf. Just one minute.
At the end of the week, notice how clean your fridge is looking and wipe down the inside of the fridge door too.
on Sep 12, 2010 | Refrigerators
Not warming up
Some devices can take a while to heat up. Try leaving it turned on for 10 minutes. If it is still not warming up, than it is the heating coil in side the Warmer that is not working. You can get a replacement from the manufacturer. The coil is soldered underneath the baby wipe compartment, it is large and shaped like a doughnut that goes around the outside of the baby wipe compartment.
There are 6 pins holding the coil to the circuit board, The coil is polarity sensitive, the +sign on the bottom of the coil goes in the hole in the board with the + sign.
Apr 26, 2011 | Munchkin No More Dry Wipes Deluxe Baby...
Wipes warmer will not turn on. It is brand new tried itmin several different plugs.
The HV Electrolytic Capacitor between the Resonance Transformer and the Resistor Bank (all of which are located in the power supply) is most likely blown. If this is the case, there will be light brown or dark yellow discoloration on the surface of the capacitor. Since it is new I would recommend taking it back and getting the entire thing replaced.
Apr 16, 2011 | Prince Lionheart Travel Wipes Warmer -...
Wipes dry out even when cartridge is full of water in deluxe wipe warmer
All baby wipes will do this over time, in a warm environment they dry out even quicker. Only turn on the Wipe Warmer when you need to use it. When baby wipes are not in use they should be kept in a cool dry place.
Nov 20, 2010 | Munchkin Deluxe Wipe Warmer
How do you clean the baby pro bottle warmer?
Ice container, measuring containers, and baskets: Dishwasher-safe (top rack only).
Measuring containers should be placed in a dishwasher basket. Or wash in warm water
using mild liquid soap. Rinse with clear water.
Bottle Warmer unit and removable cooler: Always turn OFF and unplug before cleaning.
Wipe surface of unit as well as inside of cooler and cooler lid, and inside of warming
chamber with a damp cloth or sponge using mild liquid soap. Wipe with clear water. Air dry.
Do not immerse in water. Do not use scouring pads, solvents, or abrasive cleaners, as
these could damage the unit.
Warming chamber (optional): Mineral deposits (usually white in color) may form on the
inner surfaces of the warming chamber and can cause damage to the unit. To remove them:
1. Unplug the unit.
2. Remove the basket, and wash separately as indicated above.
3. Pour 2 oz. vinegar into the warming chamber and let it stand for an hour or two (longer if
necessary).
4. Pour out the vinegar and rinse the chamber two or three times by pouring in, then
emptying out, 3 or 4 oz. of plain tap water. Do not immerse the Bottle Warmer in water.
Wipe dry or air dry.
Aug 21, 2010 | Avent Philips iQ Bottle Warmer without...
HOW TO DE SCALE THE Philips AVENT Digital Bottle
Mix one sachet of citric acid* (10g) with 200ml/7oz of water. Pour solution into the
empty warmer. DO NOT place a bottle, jar or cup into the warmer when de-scaling.
Close the lid of the warmer and programme the warmer to run with 310ml/11oz of
milk from frozen. After the warming cycle has ended, leave the solution to cool for
30 minutes before emptying the warmer and rinsing with tap water. Wipe the inside
and outside of the warmer with a damp cloth only.
OR:
Pour 100ml/3.5oz of vinegar mixed with 200ml/7oz of cold water into the warmer.
Allow liquid to stand in the unit until any limescale has dissolved. DO NOT place a
bottle, jar or cup into the warmer when de-scaling. DO NOT start the warming cycle.
Empty the unit and rinse thoroughly. Wipe the inside and outside of the warmer with
a damp cloth only.
Jan 30, 2010 | Avent Philips iQ Bottle Warmer without...
HP 7410 Scanner mirror dirty
you can go tru this extract ON HOW TO FIX IT
clean the glass
Dirty glass, from fingerprints, smudges, hair, and so on, slows down
performance and affects the accuracy of special features such as Fit to Page and
Copy.
1 Turn off the unit, unplug the power cord, and raise the lid.
2 Clean the glass with a soft cloth or sponge slightly moistened with a
nonabrasive glass cleaner.
Caution! Do not use abrasives, acetone, benzene, or carbon
tetrachloride on the glass; these can damage it. Do not place
liquids directly on the glass. They may seep under it and damage
the unit.
3 Dry the glass with a chamois or cellulose sponge to prevent spotting.
clean the lid backing
Minor debris can accumulate on the white document-backing located
underneath the unit’s lid.
2 Clean the white document-backing with a soft cloth or sponge slightly
moistened with a mild soap and warm water.
3 Wash the backing gently to loosen debris; do not scrub the backing.
4 Dry the backing with a chamois or soft cloth.
Caution! Do not use paper-based wipes as these may scratch the
backing.
5 If this does not clean the backing well enough, repeat the previous steps
using isopropyl (rubbing) alcohol, and wipe the backing thoroughly with a
damp cloth to remove any residual alcohol.
clean the exterior
Use a soft, damp, lint-free cloth to wipe dust, smudges, and stains off the case.
The interior of the unit does not require cleaning. Keep fluids away from the
interior of the unit as well as the front panel.
May 14, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Prince Lionheart Premium Wipe Warmer Logo
121 people viewed this question
Top Prince Lionheart Baby Care Experts
masud
masud
Tom Chichester
Bill Boyd
Are you a Prince Lionheart Baby Care Expert? Answer questions, earn points and help others
