Question about Infinity BU-120 Subwoofer
Infinity bu120 skegmatic of electrical board
I have an Infiniti G 35 2003 and I cannot adjust the temperature settings or airflow nor does the audio equipment work
Common issue with the 2003 Model G35. The culprit is the radio/HVAC circuit board. Unfortunately, since the OEM radio and HVAC system is integrated, it means replacing the entire circuit board which can be pricey. Google "Infiniti ITB03-007" for more information.
Oct 09, 2015 | Infiniti Cars & Trucks
Infinity TSS1200, sub woofer
Check ebay - Edwards Electronics - fixes Infinity and JBL amps :) including the tss series
Mar 16, 2013 | Infinity Audio Players & Recorders
What does fault code po304 mean and how do I fix it?
P0304 INFINITI - Number 4 Cylinder Misfire Detected
Possible causes- Faulty spark plug 4
- Faulty ignition coil 4
- Ignition coil 4 harness is open or shorted
- Ignition coil 4 poor electrical connection
- Clogged or faulty fuel injector 4
- Injector 4 harness is open or shorted
- Injector 4 poor electrical connection
- Improper spark plug 4
- Insufficient cylinder 4 compression
- Incorrect fuel pressure
- Intake air leak
Jun 25, 2012 | Infiniti J30 Cars & Trucks
What does "vso" mean on
Click on the link below to download the Infinity FX35 owners manual, Inside this manual will show you what VSO means:
http://www.infiniti-techinfo.com/deptog.aspx?dept_id=58
Feb 04, 2011 | 2004 Infiniti FX35
The board inside the woofer box is burnt where can i find a replacement
Contact Infinity. There is a known problem with these boards and it may be covered under an extended warranty....
Mar 19, 2010 | Infinity TSS-1100 System
Describe your Infinity RS-12 Subwoofer parts Problem. I have a Buzzing sound, I believe that one of the RCA input jacks is bad from the use of a POS Monster Cable that was hard to plug in. Broken the RCA...
Do you know for certain it is broke?
Could you have just damaged the soldering to it. RCA jack sockets are easy to get hold of at electrical parts shops such as Maplin (UK) or Radioshack (USA) or the like... You might just need to take it out to show them at the shop.
Feb 21, 2010 | Infinity PS-12 Subwoofer
Infiniti G35 speakers don't work
03 and 04 G35 vehicles had a Technical Service Bulletin issued regarding the audio circuit board. No sound was one of the symptoms of a faulty circuit board. There was a design flaw with the boards on the early model G35's that was corrected in 05.The audio units on those cars consisted of three pieces, the radio itself, which is just a silver box, a circuit board that attaches to the front of the radio and then the outer display. I would suggest contacting a dealership service dept. with your VIN number in hand, and ask if the circuit board has been replaced. Even if it has, It will still more than likely be the problem. It's either that or the radio
Apr 27, 2009 | 2004 Infiniti G35 Sport Coupe
I have a 2004 infiniti g35 and the speakers don't work... howevr the cd and radio console works just fine i just don't hear any sound at all? does any one have the same problem?
03 and 04 G35's had a Technical Service Bulletin regarding the audio system circuit board. I would suggest calling your nearest dealer with your VIN number in hand and ask if the Circuit board has been replaced. If it has it could still be the issue. The radio unit itself could be bad too. I worked for an Infiniti dealer for 10 years and we replaced a lot of circuit boards, and quite a few radio units. On those vehicles, however the radio is not like the radio on most cars. The display is one part, connected to the console, behind that is the circuit board and behind the board is the radio, which is nothing more than a square silver box. More than likely this is going to be a dealer only repair as is the case with most of the newer Infiniti models.
Infinity BU-120 Subwoofer Logo
54 people viewed this question
Top Infinity Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you an Infinity Audio Player and Recorder Expert? Answer questions, earn points and help others
