Question about Dell OptiPlex 170L PC Desktop
Noisy fan when my pc has been on for a while it produces noise from the fan.the noise is loud and disturbing.i formated my pc because of this and other error messages but still the noise is still there.what can i do and whats causing this
  • 488 Answers
Its because of heat build up inside the pc..you may need to clean the dust off the fan and give the pc air to breathe!check your pc's temperature using http://www.almico.com/speedfan.php hope it helps!
Posted on Oct 28, 2008
Fan noise loud and always present
If the fan is very dusty that an cause a lot of noise as it will be unbalanced. If the fan is on all of the time, maybe the bios requires updating. There may be a GPU issue and that will make the cpu run hot.
Jan 03, 2014 | Toshiba Portege R400-S4831 - Core Duo...
Disturbing sound
Check for dust in the fan, The fan in my old Toshiba was noisy too at the start but once up to speed it was quiet. I bought a replacement fan and fitted it. Easy to do as the noise was starting to irritate me.
Dec 22, 2013 | Toshiba Satellite A205-S4617 Notebook
Noisy computer fan
If its a loud "whirring" noise almost grindy...you need to replace that fan...it's about to fail. if it's a vibration type of noise, you should try tightening the screws first...if it's coming from processor fan, replace it before you fry your processor...
Jul 03, 2012 | Computers & Internet
Fan is noisy -loud wheezing sound.No dust. Banging on case sometimes stops the noise.
The fan has a noisy/worn bearing, I recommend replace the fan.
Banging the laptop base is not recommended, you could damage the hard disk.
Oct 16, 2010 | HP Mini 1000 Netbook
Air conditioner fan is making a loud noise
1. Could be a caught foreign object between A/C (air conditioning) fan and cooling radiator, producing this loud noise.
2. Could be a damaged fan blade, mowing the cooling radiator.
3. Could be a loud noise comming from the fan's electrical motor.
4. Could be a broken off fin (small wing) of the cooling radiator, striking the A/C fan, producing this loud noise.
Jun 14, 2010 | Dodge Grand Caravan Cars & Trucks
The fan of dell gx280 producing a loud sound, how I fix it ?
Sometimes something is stuck in the grill and the blades keep touching it, other times the bearings have worn down and the fan or entire power supply needs replacing.  I used to hit my PCs noisy fan with the palm of my hand and the loud noise stopped!
Mar 11, 2010 | Dell OptiPlex GX280 PC Desktop
Fan of VAIO CS-118E makes loud sounds
That is definitely a problem from the fan. What you can do is to call sony and check if they still cover Fan replacement for this specific mode.
Oct 15, 2009 | Sony VAIO VGN-CS118E/P NoteBook
Hi, we have a humming sound that is really loud,
Yes, its fan noise and you need to replace noisy fan.
Let me know exact model of your Sony TV and need to know what fan is producing noise to provide you part number and parts shop info to buy that fan.
Jul 31, 2009 | Sony Grand WEGA KF-50WE620 Television
Hp laptop dv9500 noisy and loud fan ...
The sound you are hearing is probably the fan, This fan has a noisy bearing and will eventually lock up and the fan will stop spinning and therefore the CPU will overheat and shutdown.
The fan needs to be replaced.
Feb 13, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Fan Noise
The best solution is that you have to buy another new Fan for your pc before it move out of hand.
The fan is faulty and the little checking you have done is some how recommended for the fan to have work better but since then you have to change it for a better one before it have anything to do with your processor Malfunction.
bye.
rate this solution .
Oct 06, 2008 | Ultra ThinkCentre M51 SFF P4 541 3.2GHz...
Dell OptiPlex 170L PC Desktop Logo
374 people viewed this question
Alun Cox
