Question about Whirlpool Duet GHW9150P Front Load Washer
Replace the bellow on a wfw9150ww01 - Whirlpool Duet GHW9150P Front Load Washer
Whirlpool WFW9150WW01 will not drain
New drain pump impeller maybe?otherwise complete pump i think
Jan 10, 2014 | Whirlpool Washing Machines
Whirlpool deluxe WFW9150ww01
Replace the analog level pressure switch, it sounds like it is bad, and the machine's overflow switch is the only thing stopping the fill from flooding your house... Whirlpool Washing Machine Pressure Switch WPW10239066
Jun 04, 2013 | Washing Machines
Whirlpool washer model wfw9150ww01 code f2e3
Watch this video:
http://www.youtube.com/watch?v=W1ceH7TKkoE
Jan 20, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Wfw9150ww01
Check the filter for any blockage.
Nov 23, 2012 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Questions about the Bellow?
If the door bellow is twisted, it may just be a simple matter of a clamp that has come loose allowing the bellow to shift. If its the front clamp located around the door opening, this can easily be resolved by removing the clamp, repositioning the bellow and reinserting the clamp. If its the rear clamp, however, you may have to remove the front of the washer to gain full access to it. There is an aligment mark (arrow) on the bellow at the 12 o'clock postion where it meets the wash tub. You need to make sure the arrow is pointing straight up. The following link explains how to replace a bellow:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Use this link even if you do not decide to replace the bellow. It provides good information on how the bellow is installed. Bottom line, if the bellow is not leaking, and you can resolve the twist, you do not need to replace it. Make sure you inspect for cracks or tears. As far as the additional components are concerned, inspect the clamps that you have before buying new ones. I've only had to replace these clamps on rare occasion. Last of all, "Yes", this is a job for a do-it-yourselfer. Its a little time consuming, but can be accomplished easily by following the link I provided. If you have questions, please let me know. I hope this helps you.
PS You may check repairclinic.com to see if they carry the bellow at a lower price. They offer competitive pricing and often carry the SAME part for less.
Aug 21, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Worn out bellows
The bellow definitely should not deform in the manner that you describe. When you replaced the bellow, did you line it up correctly? There are alignment marks (Arrows) on the tub and the bellow to ensure it is installed correctly? If the bellow is not aligned correctly, it will twist when the tub spins. If the shocks are worn, the bellow could also deform, but you would probably experience excessive vibrating during the final spin. If you are sure the bellow is installed correctly, and wish to replace the shocks, let me know. There are four of them on your washer. I believe they are sold in pairs. If you post your complete model number (located around the door opening), I can assist you in locating parts.
Jun 20, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
109 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
