Question about Lands Phones
How to install cj5e88tor Jack - Lands Phones
How can I install passenger side motor mount?
Jack and support the car.
Use a jack with a piece of wood on it and jack it up to the oil pan. when it touchs then pump the jack one more time to raise engine a little
remove the motor mount bolt and remove and install new one and lowerr engine and car.
you may have to jack the engine up or down a little to get it out or in. You may also have to move other parts that are in the way
Hope this helps Mike
Apr 05, 2016 | 1999 Buick Park Avenue Ultra
How do you repair a sennheiser sk100 jack socket
I assume you mean the mic plug/jack. Bent pins or broken connectors will require a new jack and/or plug installed and they are not easy to do. These 3.5 mm jack connectors require both a light touch during install and soldering. If you're a pro then start shopping for a replacement 3.5 mm mono jack but be warned. The jack may solder directly to the PC board....which reminds me. Look for broken connections from jack to PC board..a common failure point and resolder as needed.
May 01, 2014 | Sennheiser Audio Players & Recorders
Old majic jack want to start new program
If you have an old Magic Jack, my 4 unit are 6 years old the company just really wants you to upgrade to a newer product no need to. Try removing Magic Jack completely from your tablet, restart unit, make sure to clean out all junk on tablet from Magic Jack you could try a program that cleans your tablet for you, but unless you know what to remove don't get technical just a standard clean up of old files, this is usually under apps, Magic Jack, then there will be a clear cash button, clear data, and uninstall.
Restart unit then do a fresh install of Magic Jacks new app for your type of tablet from Googles sight or Magic Jacks make sure if you have a Mac to install the Mac App and if you have an android tablet you install the Android App. This has been working for me. With the old Magic Jack you will need to do a fresh install when you get errors and crashes. I do it 2 or 3 times a year. Good Luck!!
Jan 06, 2014 | magicJack Two, 2 Magic Jack Plus Voip...
How to install motor mounts on 2000 Nisan Quest?
Safely jack the car up, use jack stands, then using your jack and a piece of 2x4 wood between the jack and the engine block raise the jack until you just touch the engine. then loosen the motor mount bolts, before you remove the bolts raise the engine up slightly to take the weight off the mounts. then remove motor mount bolts and install new mount, install bolts tighten per torque spec by manufacturer and lower engine, remove jack and jack stands. done.
Oct 14, 2013 | 2001 Ford Focus
I have my magic jack right now. want to install it by i forhgot to bring the installation disc. can i install it through the magic jack website?website
Magic jack doesn't need an install disk. When you insert it into a USP port it should download and install what it needs. :-)
Jun 02, 2011 | Computers & Internet
How to install magic jack
Click on the link below to learn how to install Magic Jack onto your computer:
http://voip2u.org/how-to-install-your-magic-jack-setup
Feb 04, 2011 | Heating & Cooling
I have malfunctioning electric-driven exterior towing mirrors on a 1999 ford f-350. How to diagnose/fix? Mirrors respond only to right adjust; no response on up/down or left adjust.
there is a separate motor for up/down and another for left/right adjust. The glass is serviceable but not the motors, built into the frame of the mirror body.
SECTION 501-09: Rear View Mirrors 2000 F-Super Duty/Excursion/Motorhome Chassis Workshop Manual
REMOVAL AND INSTALLATION Exterior Mirror Glass Removal
NOTE: Left-hand dual arm mirror with heat shown, non-heated and aero mirrors similar.
  1. Position the exterior rear view mirror glass in the full down position.
  1. Grasp the top and carefully pull the mirror glass away from the mirror housing.
  1. Disconnect the electrical terminals (if equipped) and remove the exterior rear view mirror glass.
Installation
  1. Remove the jack pins from the mirror glass back.
  1. Remove the sealing boots.
  1. Install the jack pins in the sealing boots.
  1. Install the jack pins and sealing boots.
    1. Install the jack pins in the mirror housing.
    1. Install the sealing boots so the boot shoulder is under the mirror collar.
  1. Loosely install the glass.
    1. Connect the electrical wiring to the electrical terminals (if equipped).
    1. Position the friction pins in the mirror housing.
    1. Align the jack pin locating tabs to match with the mirror glass back.
  1. Using a flat hand, press on the center of the mirror glass until seated on the center pivot of the mirror housing.
    • Press the mirror glass toward one of the jack pins until snapped in place.
    • Repeat for second jack pin.
Jan 13, 2011 | Ford F-350 Cars & Trucks
How do I install a headphone jack?
well it depends on space and if you want the speakers off when using the headset.
you will need a headphone jack and a 470 ohm resistor for each channel to connect to the audio source.
May 28, 2009 | Audio Players & Recorders
How to remove mirror glass 2008 ford f350
here's 2003, don't have 2008
Removal
All exterior mirrors
  1. Position the exterior mirror glass in the full down position.
  1. Grasp the top and carefully pull the exterior mirror glass away from the mirror housing.
  1. Disconnect the electrical terminals (if equipped) and remove the exterior mirror glass.
Power exterior mirrors
  1. Remove the jack pins from the exterior mirror glass backing plate.
    • Use pliers to grasp the jack pins at the base to remove.
Installation
  1. Remove the sealing boots from the exterior mirror motor.
    1. Hold the legs of the jack pins and push the jack pins back into the exterior mirror housing.
    1. Install the sealing boots so the boot shoulder is under the mirror collar and turn each jack pin until the head of the jack pin is aligned with the slots in the sockets on the backing glass plate.
  1. Place the new exterior mirror glass assembly down on a smooth firm surface.
  1. Align the friction pins vertically to the exterior mirror glass backing plate socket and push down to snap the pivot ball into the socket.
  1. s3o~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not over heat the exterior mirror glass backing plate. Heat only until backing plate is warm to the touch.
    Using the special tool, warm the main pivot sockets in exterior mirror glass backing plate.
NOTE: If the jack pins do not engage, they may not be aligned correctly. Remove the exterior mirror glass, align the jack pins to the slots in the sockets and repeat the installation procedure.
  1. NOTE: The jack pin should click while manually adjusting the exterior mirror glass.
    Tilt the exterior mirror glass to the full outboard position and then press on the outer side of the class until the in/out jack pin snaps into the socket on the exterior mirror backing plate.
    Tilt the exterior mirror glass to the full down position and then press on the outer side of the class until the up/down jack pin snaps into the socket on the exterior mirror backing plate.
Nov 14, 2008 | 2008 Ford F-350
FRONT MOTOR MOUNTS
with motor in car undo mounting bolts place jack under motor gently jack up until mounts can be moved out of way replace mounts drop jack install nuts and washers simple
Nov 05, 2008 | 1991 Acura Legend
Lands Phones Logo
37 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
