Question about LG Flatron F700P 17" CRT Monitor
Monitor my computer runs on xp professional, now for two days , colour of monitor changes to deep blue and it is blinling continiously.
Drives
Posted on Apr 19, 2008
    President:
  • 2,022 Answers
Fix your vga data cable if it is still not work then show it monitor repair service personnel bye
Posted on Sep 25, 2007
Will not cme on
Hi
Firstly - Is the cabling, mains and data cable, securely attached at both ends and the power turned on at the mains?
Secondly - If so when you press the monitor power button, does a light come on? (often orange coloured) If yes does this change colour when the computer starts its boot sequence? (often to green or blue)?
If no light can be obtained it is likely that the monitor is faulty.
If a light comes up on power up, but doesn't change colour during the computer boot sequence then it is more likely to be the graphics card that is faulty, or sometimes the computer PSU.
The easiest way to find out whether the computer or monitor is at fault is to replace the existing monitor with a monitor that is known to be in full working order, for example from another computer. (Or connecting your monitor to a computer that is known to be working)
Having isolated the faulty component it can be replaced and you should be up and running again.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 18, 2014 | GNR TS902D Monitor
I a having a laptop-HP pavillion dv6000,RAM 1gb and OS-32bit with window 7 ultimate,a problem of colourisation.i mean the display colour has change like a spray a of colours(green,deep blue)on the normal...
Try plugging in an external monitor and see how the display shows on it. If the display is ok on the external then your LCD Screen is going bad. If it shows the same colors on the external monitor then your video graphics card has issues.
Apr 21, 2012 | HP Computers & Internet
My monitor resolution colour is changed to pink.
Check the data-cable between the computer and the monitor, and try a different cable.
Or, try connecting the monitor to a different computer, to see if the video-card in your computer is not working correctly.
If necessary, replace the video-card.
Colours on your monitor are produced by "mixing" the 3 "primary" colours: red/green/blue in various proportions.
Or, if part of the monitor that produces one of those 3 primary colours has stopped working, then the resulting "mix" will have too much RED/PINK. Fix/replace the monitor.
May 29, 2010 | SAMTRON 55V 15" CRT Monitor
ADI GD-166G SCREEN HAS GREEN COLOUR DISPLAY
hope u r a professional..as u r handling chip-level repairing of monitor, knowing itz hazardous n dangerous..
however, check thoroughly for dry soulderings..(esp. at the crt base)..[this chance is maximum]..
see if the base is loose or faulty..
yes, it can b the 'chroma ic'..but don't ignore the associated components..(esp around the base)..
check video amplifier n sub section..
the colour diodes, transistors n resistances at the base..
for better supervision contact ur system admin/vendor....
Nov 11, 2009 | ADI Corporation MicroScan 5P (White) 17"...
Red colour problem in compaq 7540
Check to see whether monitor terminal has a broken pin. Otherwise change the VGA card.
Sep 07, 2009 | Compaq CV 7500 17" CRT Monitor
Hp pro b8350 will not print colours seen in pictures
discovered print cartridge was faulty. no yellow was coming through.New cartridge solved problem
May 01, 2009 | HP Photosmart Pro B8350 InkJet Printer
My moniter screen has turned to blue screen and i am not able to
On your CRT back PCB thers three transistor on for red green and blue its possible that your blue transister is faulty. Try moving your cable see if the colour changes it can also be a faulty 15pin plug
Have a nice day
Dec 24, 2008 | HP Compaq FS7600 17" CRT Monitor
LG 17'' LCD Monitor VGA 15 pin connector pin diagram
pin no 1 - Red colour signal (Red colour wire)
pin no 2 - Green colour signal (Green colour wire)
pin no 3 - Blue colour signal (Blue colour wire)
4&5 Not connected
pin no 6&7&8 are (Grounds)RGB Returns
9&10 NC
pin 13 Hohizontal sync signal
pin no 14 vertical sync signal
Not nessasry other pins
Nov 17, 2008 | LG Studioworks 700S 17" CRT Monitor
Screen colour error
Recommend to go to the color settings and change it to the use settings and adjust accordingly.
Oct 17, 2007 | ViewSonic VA1930WM LCD Monitor
My monitor changes color on it's own.
I doubt if this is related to the software you installed. Check the video lead that runs from the PC to the monitor. Sometimes the insulation becomes damaged or the wires break. With the computer on gently wiggle the lead around at one end or the other while watching the monitor, if the colour flickers then you have found the location of the fault. Also check the plugs are in firmly.
Sep 22, 2007 | Microsoft Windows XP Media Center Edition...
LG Flatron F700P 17" CRT Monitor Logo
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
