Question about Dishwashers
Kenmore dishwasher model 587-14349690 will not cycle properly
Will not cycle - interupts all cycles, though continues to drrying cycle, without completing emtying cycle. Dishes remain dirty.
bigg t
  • 640 Answers
SOURCE: Kenmore model 665 dishwasher
the timer is bad.the 42 min cycle and the 6 min cycle share the same timeline.try northernparts.com for the part number and price.installing the timer isnt that difficult.
Posted on Jan 05, 2008
SOURCE: Kenmore Ultra Wash Dishwasher; Model 665.17539
I have a Kenmore 665 about 3 years old
Over the last couple months the touch pads have stopped working and I am now down to one control the water miser!
Do I need a new control pad and is that easy to install ?
Thank you for any sudgetstions
KC
Posted on Feb 08, 2008
  • 276 Answers
SOURCE: water in the dishwasher after the the cycle is complete
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Posted on Nov 19, 2008
rockfixya
  • 679 Answers
SOURCE: Frigidaire dishwasher not completing cycle.
hi,
The cycle doesn't complete
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle
Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
On some units, the pause is timed and the unit continues after the allotted time.
On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
I see an error code
If your dishwasher has a digital readout and you see an error code, it may indicate a problem with the unit. If this happens, look up the error code in your owner's manual to find out what the problem is.
Good Luck
Thanks for using FixYa
Posted on Jan 03, 2009
  • 848 Answers
SOURCE: Our Whirlpool KUDP01ILBS2 dishwasher isn't
Heat that is retained in the dishes is largely responsible for drying in this dishwasher. Since plastics do not retain heat very well, they will not dry as well as glasses, ceramics or metal dishes. Rinse aid must be used so that the final rinse water will sheen off of the dishes to accommodate this drying process. The heater element at the bottom of the tub is used to add heat during the drying cycle to aid in this process as well. This model of dishwasher does not have any forced air circulation system. Here are some tips that may help you resolve your drying problem:
  • Make sure that you are using rinse aid. Failure to properly use rinse aid can prevent proper drying. Adjust the amount that is dispensed if necessary. Also, check to make sure that rinse aid level decreases over time indicating that it is being dispensed properly.
  • The NORMAL WASH and POT & PANS cycles heat the final rinse water up to 140 degrees F. Use these cycles to help the drying process.
  • Do not choose the air dry option. This option cuts off the heater element during the drying process. NOTE: The heater element is not turned on during the first 6 minutes of the drying portion of the cycle.
  • Do not overload the dishwasher. Load the dishes to allow for proper water drainage.
This dishwasher has a heater fault detection circuit. If the heater is not working, the control will detect the lack of increase in water temperature. The dishwasher will stop and the CLEAN light will blink seven times repeatedly. The dishwasher would not be able to be used until the problem is corrected and the control is reset.
Posted on Feb 10, 2009
Why do soap suds remain in the bottom of my Kenmore, model #665.13113K701, dishwasher at the end of a cycle? I have run several cycles without soap and there still are suds remaining.
My guess being I have not physically seen it:
A.Improper install and the system is not draining properly.
B.Clogging in the drain pipe at the sink to the sewage system.
C.Failing draining pump.
D.Water softener issues.
E.Someone you have over is pranking you.
Aug 06, 2014 | Kenmore Dishwashers
My dishwasher does not clean the dishes even though it completed the full cycle
is it a film or spots? if so its your water and not the dishwasher actually. go to www.dishwasherfilter.com and check out their filter system. it works great and should solve your problem.
Jun 24, 2013 | Dishwashers
Dishes remain dirty
Use a cap of white vinigar in the bottom of the washer before you use it.
May 02, 2012 | Baumatic 23 in. BDW13 Built-in Dishwasher
The dishes coming out dirty on my Whirlpool Gold Quiet Partner IV. Cycle seems to complete. The soap is being used. Not sure how old it is ... it came with a house I just bought. Any suggestions?
Clean the jets on the unit. Jets are the small openings the water comes out of. Contact Whirlpool, follow their recomondations, or add some CLR or Lime Away to the washer without a load of dishes. Both products remove Calcium Lime and Rust deposits which impede the flow of water, causing your dishes to come out dirty
May 16, 2010 | Dishwashers
Red light continues to blinkafter wash cycle is
try adding salt to the resovior in the bottom of your dishwasher.. machine will not run without salt so as not to cause damage
Dec 14, 2009 | Kenmore Dishwashers
Kenmore Dishwasher 587.15163401 knob stuck mid-cycle
See if it is stuck on a water heat cycle. if the heater circuit or the thermostat is not working properly it will continue to run looking for a rise in temperature. If these are in working order the timer it self could be sticking and not advancing.
Eric
Oct 23, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwashers Logo
Top Dishwashers Experts
