No sound Recently move tv from upstairs to downstairs. Hooked everything back up, now there is no sound, all else is fine. Using S-Video connection, tried new cable, cable hook up, no help.
    Master:
  • 483 Answers
The s video is only for video, you must also have a red and white rca cable connected also
Posted on Mar 07, 2013
SOURCE: Component Video Problem
The problem is not with your tv it's with your dvd player. You have to go into the setup on the dvd player and change your output setting to component.
Posted on Feb 05, 2007
ttech
  • 139 Answers
SOURCE: Picture seems to fall off the screen.
Julie,Did you by Chance have a Projection tv down stairs,If so Contact you Cable Company for Proper Settings......
Posted on Jul 19, 2007
SOURCE: Might not be my exact TV
If you have No Channels at all, try your TV from a known good cable feed, (upstairs) or try using a VCR to check the TV's function  If it works upstairs, try entering the Menu, and make sure Cable is selected, it sounds like it may be on the TV or Antenae setting.  This setting is usually in the Channel Select or similar menu.  Change it to Cable and it may help.
Posted on Oct 17, 2007
  • 10865 Answers
SOURCE: We have a tv upstairs and one down stairs, they
Since the antenna is on the roof the signal has further to travel to get to the downstairs antenna and as a result the signal is weaker. Install a device on the antenna line before the first TV called a signal booster. This unit plugs into the wall and gets connected to the antenna wire too. It will improve the signal for both televisions.
Posted on Aug 14, 2009
barbu51
  • 566 Answers
SOURCE: hi,
Hi Fiona
Somewhere along the line from the aerial there must be a signal splitter that feeds the upstair and downstair terminals.
Try to find that splitter and switch the output to see if the problem goes from up to downstair.
If it does switch then you know the problem is with the splitter block, and if it stays the same then the problem is with the cable and/or the connectors that run downstairs.
Also the reason you get a pixellated(snowy) picture is because of signal loss during the length of the cable you ran downstair.
If running a cable downstair becomes the best option to fix your problem , then you could buy a cheap 10db signal booster/r.f amplifier to correct the signal loss and a cable splitter to feed both tv`s
That booster would be installed upstair in your case(near the source of the signal to be amplified).
I could send you a small diagram if need be. Hope this will help and Merry Chrismas
Posted on Dec 14, 2009
I have Netflix on my upstairs Vizio smart TV, but for some reason will not connect on my downstairs Vizio smart TV? Please help.
First thing I would check is Internet connection on the smart tv that won't connect. If that doesn't work try downloading new software for Netflix. Try those and see what happens.
Oct 14, 2014 | Netflix
We have a wireless router connected to two computers upstairs and have tried to connect our Wii to the Internet which is downstairs, it is picking up the access point but will not connect, is it too far...
Well the only solution that would help you out in this case would be to either keep your Wii where it currently is downstairs, or move it closer to the router. Besides that you could also purchase yourself a better, more upgraded router, or purchase a wifi extension for your router and/or Wii.
Jan 08, 2011 | Nintendo Wii Console
Hi, I have a digital tv plugged into an extension cable in an upstairs (Toshiba) bedroom; it works perfectly - receiving all channels. I have a digital tv downstairs (Samsung) where it seems the wall...
Hi Fiona
Dec 14, 2009 | Televison & Video
I moved our computyer from downstairs to upstairs.
Power supply is bad,,
You can try to unplug the main motherboard plug, then plug back in,, It should last as long as it stays pluged into the wall.
Keep it pluged in when you do this,,
Nov 30, 2009 | HP Compaq Presario SR1410NX PC Desktop
Crackling noise / loud static when tv is attached to antenna
Pick one:
RFI (Radio Frequency Interference) from nearby electrical/ electronic device.
Antenna misaligned to transmitter.
Antenna coax impedance mismatch.
Faulty connections.
Faulty antenna.
TV tuning.
If the OLD TV worked OK on same antenna it sounds like TV tuning or ANT socket/wiring loose.
Try:
Auto-tune TV with ant plugged in.
Get TVF (TV fundi) or friend to help align antenna.
Maybe a large bird sat on it.
Check coax for sunburn / deterioration. Renew if XX.
Oct 11, 2017 | Televison & Video
Problem connecting to my network
What I would do is replace the wireless router with a 4 or 5 port switch to control computers (devices) downstairs. Or, if you need wireless access, purchase only an access point to cover downstairs.
This way the wire from upstairs goes directly into the access point and you have wireless access downstairs.
And yet another way would be to purchase Airlink 101 PowerEthernet boxes ($54.99 each) and use those to connect an access point anywhere in your home that has an outlet.
Nov 19, 2008 | Linksys Wireless-G WUSB54G 802.11g/b
PS3 problems
Sounds like you turned the power off with the hdd still spinning. try replacing the hdd
Mar 26, 2008 | Video Game Consoles & Games
No audio
try to reprogram the channel. it seems that your tv's sound circuit is fine.
Jan 09, 2007 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
