Question about Sharp Office Equipment & Supplies
How do I replace Ink on Sharp EL-1801V
I can no longer read my numbers on my tape when I print on my calculator. What do I need to do?
ginko
  • 19396 Answers
SOURCE: Sharp EL-1801V Calculator
The manual for 1801v is not distributed from Sharp anymore.
You can download the manual for EL-1801PIII Operation Manual (240K) , It is the same model with some cosmetic difference.
Regards
Posted on Apr 02, 2008
SOURCE: Sharp EL-1801V 12 Digit 2 Color Printer
SHARP EL-1801V DON'T KNOW HOW TO SET THE DATE AND TIME
Posted on Jun 12, 2008
SOURCE: how do I set the
Push the button at the top over from GT to SET.
type the date in using the decimal as a spacer.
Then press the date/time key.
for the time...
Press the date/time key until the date shows,
then enter the time in military time and press the date/time key again.
Posted on Dec 02, 2008
SOURCE: EL 1801V - how to set time/date?
To change the date, enter the date in MM.DD.YY format, pressing the decimal key between the month and day (will show as a decimal on the display) and the day and year (will show as a dash on the display). Then, press the Time/Date key (the one that looks like a clock and a calendar). The new date will show on the display. Note that if the month is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. To change the time, enter the time in 24-hour HH.MM format, pressing the decimal key between the hour and minute. Then, press the Time/Date key. The new time will show on the display. Note that if the hour is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. Hope this helps! :)
Posted on Dec 04, 2008
  • 20 Answers
SOURCE: how do you put the adding machine tape into the
Put the leading edge of the tape into the the opening on the back of the machine. Turn the machine on and press the button with the up arrow, then lift the little metal paper holder and insert the roll.
Posted on Mar 08, 2010
Trying to put in a new paper roll
Turn off the Sharp EL-1801V.
  • 2 Cut the end of the replacement paper roll for a fresh edge and to ensure a smooth feed. Do not tear the paper roll, as feeding a torn paper roll can cause a paper jam.
  • 3 Insert the cut edge into the paper opening on the back of the Sharp EL-1801V. Hold the paper roll so that the edge being fed into the machine is coming from the bottom of the roll. Turn the power on.
  • 4 Press the "Feed" button until the paper is fed through the unit. Lift the metal paper roll holder up. Slide the paper roll onto the paper-roll holder.
  • Read more: Directions for Replacing the Paper Roll on a Sharp EL-1801V ' eHow.com http://www.ehow.com/how_7294657_directions-paper-roll-sharp-el_1801v.html#ixzz1eNqkJA8g
    Nov 21, 2011 | Sharp EL1801V Scientific Calculator
    Trying to replace the paper roll on a sharp EL1801V
    1 Turn off the Sharp EL-1801V.
    How do you put the adding machine tape into the Sharp EL-1801V Adding machine?
    Mar 08, 2010 | Sharp EL-2630P Calculator
    After changing the ink roller, the machine is printing nonsensical characters.
    You have a IR 40T replacement cartridge instead of a 40T
    These are sold under the NR42-2 number as replacements for the Sharp 1801P but they do not fit. IF you look closely at the Sharp Models it lists on the package, it will say Sharp EL-1801V. I have not found a working replacement yet.
    Dec 02, 2009 | Sharp EL-1801P Calculator
    WHAT KIND OF RIBBON DOES THE SHARP EL-1801V USE AND WERE DO I FIND IT?
    Ink roller type EA-772R
    You can find it in any good (refer your machine make and model). There are compatible roller with different references. Also check online (do a gGoogle search or check Amazon.com and you will find several links fopr different seller.
    Note that the same type of ribbon is use by diffrent calculators, evem from different brands, so lok for the image of the print roller to see if it looks like t he roller of your machine)
    Jul 16, 2009 | Sharp EL-1801P Calculator
    if your trouble is repeated after you switch the calculator off and on again your printer needs service in workshop.
    Nov 01, 2007 | Sharp EL-2630P Calculator
    I know i know
    Had the same problem. The tape does not feed through the top of the machine but instead through the slot at the back of the machine. It looks odd, but that is where it goes.
    Oct 01, 2007 | Sharp EL-2630P Calculator
    140 people viewed this question
    Top Sharp Office Equipment & Supplies Experts
    Anthony Karuku
    k24674
    CheckitRight
    CheckitRight
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
