Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
Ryobi Grass Scorpion Petrol lines from tank to primer to carby where to where
The petrol lines on my Grass Scorpion have aged (12 years) and broken. I need to know the circuitry from Fuel Tank to Primer to Carby. TWO lines go from Fuel Tank, NO.1 from Internal Fuel Filter in Tank to ??? and No.2 from Fuel Tank to ???
These lines obviously go to the Primer Pump and the Carby. But which goes to which???"
The replacement of all these fuel lines is quite simple but I cannot find anywhere a Fuel Flow Circuit Diagram.
The Ryobi Grass Scorp[ion has worked perfectly for 12 years and I am loathe to put it to rest. It has become a member of the family
  • John Wilford Oct 30, 2008
    You have just saved me over A$100. My wife said "After 12 years good service, just buy a new one".
    The Ryobi is just as good a workmate as our two border collies are.I just couldn't take it to the tip.
    Two years ago I had two stents put into my heart so I know how the old Ryobi feels.
    Thanks for your help.
    John Wilford.
    Guru:
  • 859 Answers
Thanks to doityourself.com.
The line off the top of the primer bulb goes to the top of the carburetor.
The line on the bottom of the primer bulb goes to the fitting on the center of the fuel tank and the line off the side of the fuel tank goes to the bottom of the carburetor.
Regards,
Worldvet
Posted on Oct 28, 2008
    Sergeant:
  • 306 Answers
The line from the tank goes into the longer inlet, and the line into the carbie goes into the shorter inlet
  • AbdulRahiman S Oct 28, 2008
    your outlet from feul tank goes to primer inlet (shorter one)
    and other hose one end should be connected to the free end of primer(longer one ) and the other end to the spigot (brass color one) on top of carby and the other one end connecte to
    spigot at the buttom of carby and other end goes to fuel tank
I have a troybuilt weed eater. I just put a new carbeutor on and its not running right. It has compression but will not start?
check the position of the fuel lines to the primer or if part of the carby from the tank to the carby
the way it works is that the primer bulb sucks fuel through the carby to prime it so the tank line goes to the carby and the line from the primer back to the tank
could be flooded or the metering screws have to be adjusted
Jul 22, 2017 | Garden
Which fuel line goes where on Colibri Partner strimmer
the carby to tank
use the primer button to check lines are correct
once you get fuel in the primer
Flymo Partner Colibri SST250
trial and error
the longest hose
in tank filter line through the tank grommet to carby
short single hose
the other outlet goes from the carby back through the grommet into the upper part of the tank
Sep 08, 2016 | Garden
2004 40hp mercury 4 stroke
pull the carby and clean out all of the jets
the problem most likely is not bad fuel but failing rubber components that is leaving bits of rubber in the carby and pump valves
the rubber in the hoses, primer bulb, pump diaphragm breaks down internally and lodges small particles in the filter and carby and with the age of the motor ( 12 years) now would be a good time to replace all of the rubber
unless you are familiar with the motor and carby I suggest from a safety point of view that you have the carby and work done at a service center for the make of outboard
Sep 04, 2016 | Boating
.comWhat is fuel to oil
I believe it should be 25:1 which is (say) 40ml oil to 1L of petrol. I have seen this ratio on a sticker on my grass scorpion.
Sep 13, 2011 | Ryobi Garden
I have an older model ryobi petrol grass scorpion, have changed carby gaskets. need to tune carby. but what is the process
Turn the sping loaded screw in tight then slacken off one and a half turn.That is the right process.
Jul 31, 2009 | Garden
LOOKING FOR INFORMATION ON FUEL LINE ROUTING CONNECTIONS. FROM FILTER TO PRIMER BULB, TO CARB CONNECTIONS AND THEN TO RETURN BACK TO FUEL TANK.
most trimmer fuel lines run from line in tank with pick up filter to bottom of carby then out of top of carby to inlet on primer usually the smaller tube then out of the longer tube on the primer and back to the tank.
Jul 21, 2009 | Poulan Pro Pp125 25cc Gas Straight Shaft...
The fuel lines have rotted out of the edger gas tank. How do I fix or do I need to replace entire tank with new fuel lines?Since there are no male fuel line connections exiting the fuel tank and just two...
no you can buy replacement fuel line but you must reconnect the filter in the tank that line goes to the bottom of the carby then out the top of the carby to the inlet on the primer then out of the primer and back to the tank.
Jul 12, 2009 | Poulan Pe550 Gas Edger
On my craftsman gas edger, the fuel tank has 2 holes on bottom, my fuel lines broke. i bought new lines but how do you install the lines do you put a fuel line in each hole or do you use tine same line and...
Hi ken If your machine has 2 holes in the tank it must have a primer first of all you you must fish out the pick up filter from the tank feed your new fuel line into one hole and out the filler hole connect the filter & put it back in that line goes to the bottom of the carby the next one from the top of the carby to the primer then from the primer back to the tank.
Jul 10, 2009 | Garden
Featherlite FL 20 fuel line assembly
1 from filter in tank to carby 2 out of carby to primer 3 from primer back to tank
Jul 06, 2009 | Garden
Manual for Ryobi Grass Scorpion Line Trimmer
my ryobi scorpion only has twofuel lines but two on primer can you help
Mar 13, 2009 | Ryobi Garden
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
1,566 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
