Question about Sewing Machines
Somebody have an electrical drawing of the power supply?
I wanna fix it..... It does'nt set on.......
Machine runs as soon as power turned on and there is a smell. What could it be? And how to fix it!
Is it a hot electrical smell, or more like rubber? if rubber, it is probably the "cogged" drive belt. If it is electrical and the older
style speed controller it needs to be repaired. And it most likely
that device has a catch internally supplying more power than normal.
Mar 15, 2015 | Sewing Machines
Husqvarna Viking Designer I won't start up. The light works so it's getting power. I have taken it in to get fixed 3 times, but when I get there it starts right up. They are thinking I am c
I would be willing to bet it is your electricity or your outlets. First try your machine in a different room in your home. If it still does it then take it to a friends across town. If it works at her house but not yours, you know you have an electricity problem in your house... or the lines coming into your house. Remember these machines need a certain amperes or voltage to work. If they don't get what they need it won't power up.
It could be that your sewing machine just saved your life by pointing out a problem with your electricity... listen to it. ;)
Dec 14, 2012 | Husqvarna Designer I
I had to order a new bobbin case for my singer 7028 but, cant get it in.
http://www.singerco.com/uploads/download/444_5_8_10_16_22_dial.pdf
Dec 11, 2012 | Sewing Machines
How do i fix my machine, it's breaking the top thread all the time
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Nov 28, 2012 | Sewing Machines
Bobbin pops out and needle thread and bobbin thread bird nest
here's my suggestions
change the needle-make sure the needle is inserted correctly
into the needle holder & also turned the right way
make sure when sewing on the machine that the top thread does
not come off the thread take up lever
check the top thread tension it may be too tight,, usually 4 is good
or if the machine has automatic tension set it there
make sure it's the right needle for the machine & make sure it's the
right needle for the fabric & thread.
some thread is knotty ,,, make sure the thread is good quality
Sep 10, 2012 | Singer Inspiration 4210 Mechanical Sewing...
LS-1520 Brother sewing machine hook pick thread up takes it around half way and gets stuck...any ideas. the timing seems to be right??!!
try changing needles
clean under the needle plate & in the bobbin area for loose thread or lint
make sure the bobbin is inserted into the bobbin case correctly--if the
machine won't pick the thread up from the bobbin correctly take the bobbin
out of the case & turn it around & try it that way.
Apr 13, 2012 | Brother LS-1520 Mechanical Sewing Machine
My Bernina 1230 won't shut off. I need to unplug it each time.
I agree about the on & off switch, it could be going out or have a short in it
Apr 05, 2012 | Bernina Sewing Machines
Brocken both needles and power went off the machine
I guessing that from what you say broken both needles you are talking about a serger, unless you are using twin needles in a sewing machine
if the power has gone off, have you tried turning off the machine & turning it back on, if that doesn't work then it's possible that the power cord may have gone out, or the on & off switch may have gone out.
the only things broken needles will do is knock the machine out of time or jam it up
Mar 27, 2012 | Sewing Machines
Sewing Machines Logo
29 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
