Question about The First Years Everywhere Gate
How do i open a first year everywhere gate
How do i slide it open
You grab the grey handle and pull upward to release. Then slide the gate open.
Posted on Feb 23, 2012
  • carolyn rhaly
    carolyn rhaly Jun 24, 2014
    agter opening the gray handle how do I get the gate to slide out wider to fit an opening.
  • carolyn rhaly
    After pulling gray handle up to release I cannot pull the gate to open wider to fit my door way. what can I do.
Cannot find motor for sunroof in 1998 lincoln towncar limo
Before removing the motor ,check for B+ at the switch , in an out of the switch . Lincoln calls this a moon roof an there is a relay that powers it up . The location of relay an the motor is in the same place ,center of headliner behind the roof .
  • Sliding Roof Panel Does Not Open or Close
  • Damaged circuit breaker.
  • Circuitry open/shorted.
  • Damaged roof sliding panel switch.
  • Damaged sliding roof panel motor.
  • GO to Pinpoint Test E .
PINPOINT TEST E: SLIDING ROOF PANEL DOES NOT OPEN OR CLOSE E1 CHECK WINDOW OPERATION
  • Operate window.
Does window operate? Yes No GO to E2 . SERVICE safety relay circuits. REFER to Section 01-11 . E2 CHECK SUPPLY TO SLIDING ROOF PANEL MOTOR
  • Remove roof sliding panel switch as described.
  • Turn ignition switch to the RUN position.
  • Using a voltmeter connected to a known good ground, check Circuit 400 (LB/BK) at roof sliding panel switch connector C900 for voltage.
Is B+ present? Yes No GO to E3 . SERVICE open Circuit 400 (LB/BK). E3 CHECK SLIDING ROOF PANEL SWITCH GROUND
  • Using an ohmmeter connected to a known good ground, connect second lead to Circuit 57 (BK) at roof sliding panel switch connector C900 . Measure resistance.
Is resistance 5 ohms or less? Yes No INSTALL roof sliding panel switch. GO to E4 . SERVICE Circuit 57 (BK) for open circuit. RESTORE vehicle. RETEST system. E4 CHECK CIRCUIT 692 (R)
  • Using voltmeter connected to ground, back probe Circuit 692 (R) at roof sliding panel switch connector C901 .
  • Toggle roof sliding panel switch to the open position.
Is B+ present? Yes No GO to E5 . REPLACE damaged roof sliding panel switch. RESTORE vehicle. RETEST system. E5 CHECK ROOF SLIDING PANEL SWITCH
  • Using voltmeter connected to ground, back probe Circuit 691 (DB) at roof sliding panel switch connector C901 .
  • Toggle roof sliding panel switch to the closed position.
Is B+ present? Yes No GO to E6 . REPLACE damaged roof sliding panel switch. RESTORE vehicle. RETEST system. E6 CHECK SLIDING ROOF PANEL MOTOR
  • Gain access to sliding roof panel motor as described.
  • Using voltmeter, back probe sliding roof panel motor Circuit (DB) at connector C903 .
Is B+ present? Yes No GO to E7 . SERVICE Circuit (DB) for open. RESTORE vehicle. RETEST system. E7 CHECK CIRCUIT 692 (R/Y)
  • Using voltmeter, back probe sliding roof panel motor Circuit (R/Y) at connector C903 .
Is B+ present? Yes No REPLACE damaged sliding roof panel motor. RESTORE vehicle. RETEST system. SERVICE Circuit (R/Y) for open. RESTORE vehicle. RETEST system.
Sep 20, 2015 | Lincoln Cars & Trucks
The door on the inside of my projector in front of the slide wont open when a slide is in ???
The shutter ("door" you refer to) should be spring loaded - the spring will snap the door open when a slide enters the gate. Usually, if the shutter fails to open, it is because the spring that tensions the shutter has either fallen off or somehow unhooked.
Sep 23, 2014 | Kodak Carousel 4600 Slide Projector
The door won't open and the screen says illegal open
try sliding the door by hand to the right. If you can slide if, lift up on the left side while sliding it all the way to the right and the doot should slide off. Then try sliding it back on. One of the door switches is probably out of place and just needs to be realigned.
Nov 06, 2013 | Panasonic SC-HC30 Audio Shelf System
How to reset automatic sliding door on chevy venture van
The rear side door actuator control modules monitor the power sliding door positions at all times. Whenever the battery positive voltage supply to a rear side door actuator control module has been removed or the on-board diagnostics have been activated the power sliding door system(s) must be re-initialized. Re-initialize the right or left power sliding door systems using the following steps:
  1. Turn the ON/OFF switch for the power sliding door system to be re-initialized to the OFF position.
  2. Manually open the power sliding door completely.
  3. Manually close and latch the power sliding door.
  4. Turn the power sliding door ON/OFF switch to the ON position.
  5. Open the power sliding door completely using the B-pillar or overhead console OPEN/CLOSE switch.
  6. Close the power sliding door completely using the B-pillar or overhead console OPEN/CLOSE switch.
Sep 30, 2012 | Chevrolet Vehicle Parts & Accessories
2007 dodge caravan automatic sliding doors open when keys are in pocket
Keep the keys out of your pocket. Something is touching the open switch in your pocket.
Jun 13, 2012 | 2007 Dodge Caravan SXT Minivan New Cars
DOES IT SLIDE OPEN
Motorolla L71 do not slide open, it is a flat phone that has all its function keys and screen on the front casing.
Motorolla L71 does not slide open., It is not a flip phone or slide phone.
Take care.
Jul 19, 2010 | Motorola Mobility L7I Cellular Phone
The moonroof on my 2002 lincoln towncar is stuck open. I can hear the motor when I push the open button, but the motor sounds dead when I try to push the button to close. Could it be jammed? Is there a...
Temporary Fix: unsnap off the access door in the overhead ceiling liner behind the sunroof opening;
Use a 4mm hexagon Allen wrench to wind it closed.
Sep 12, 2009 | 1999 Lincoln Town Car
Sunroof doesn"t open or close
Section 01-17: Roof Panel, Sliding—Electric 1996 Taurus, Sable Workshop Manual DESCRIPTION AND OPERATION Electric Operation The sliding roof panel (502B98):
  • is available as an option.
  • is electrically operated through the accessory delay relay (controlled by generic electronic module (GEM)).
  • is of self-storing design.
  • requires a specific headliner.
  • utilizes a unique roof console and dome lamp.
  • has an air deflector.
The electrical system operates in the following manner:
  • Two switches control movement of the roof panel.
  • When the SLIDE roof sliding panel switch (15B691) is rocked rearward, the roof sliding outer glass panel (502A82) slides into the storage space between the roof trim panel (51968) and the roof panel, exposing an opening over the front seats.
  • When the SLIDE roof sliding panel switch is rocked forward with the roof sliding outer glass panel fully back in the storage space, the roof sliding outer glass panel moves forward from the storage position.
  • The rear portion of the roof sliding outer glass panel moves upward on two lifter arms near the end of the forward travel, allowing a weather-tight seal when the roof sliding outer glass panel is closed.
  • An AUTO feature allows the SLIDE roof sliding panel switch to be touched momentarily to cause the roof panel to automatically move to the fully open position.
  • When the TILT roof sliding panel switch is rocked forward with the roof sliding outer glass panel fully forward, the rear of the roof sliding outer glass panel pops up to the VENT position.
  • With the roof sliding outer glass panel in the VENT position, rocking the TILT roof sliding panel switch rearward closes the roof sliding outer glass panel.
  • Open power feed fuse.
VISUAL INSPECTION CHART Mechanical Electrical
  • Damaged roof panel
  • Obstructed roof panel
  • Guide
  • Damaged drive cable(s)
  • Open Power Distribution Box Fuses 1 (40A) or 4 (30A)
Apr 19, 2009 | 1996 Ford Taurus
Hyperlinks in PowerPoint
it is because the compatible MS Office for windows vista is MS Office 2007. if you got a lower version, it is doesn't really work. try to get the latest version of MS Office.
Feb 26, 2008 | Microsoft Windows Vista Ultimate Edition
The First Years Everywhere Gate Logo
974 people viewed this question
Top The First Years Baby Gear Experts
Alan Matzke
Dorel UK
Dorel UK
Tom Chichester
Are you a The First Years Baby Gear Expert? Answer questions, earn points and help others
