Question about Kitchen Ranges
GE oven glow bar
I just changed my first oven glow bar and it seems to work fine(?). This is a GE range #183D8077G018 (Part changed was a Norton glow bar #WB13K21). The oven ignites fine after about a minute but the glow bar remains on for the whole oven cycle until turned off. Is this normal???? The only reason that I ask is that it seems that would make the glow bar age and fail quicker. It should be simple to have the glow bar turned off after the gas is ignited. Maybe my range isn't working right????
  • 67 Answers
SOURCE: Bosch HGS442UC Gas Oven won't light
Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself.
The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame.
Other causes Other reasons that your oven may not bake are:
  • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
  • The thermostat is defective.
  • The safety valve that prevents accidental gas flow is defective.
  • The selector switch is defective.
if this helps please vote me a fix ya
Posted on Jul 18, 2008
SOURCE: Hotpoint Gas oven doesn't light
Is the gas valve easy to replace on a gas oven?
Posted on Nov 19, 2008
protek480
  • 1714 Answers
SOURCE: Gas Oven - no flame at Bake Baffle - Glow Bar glows fine
If the glow bar is working (glowing) it is the gas valve. BUT, the glow bar can also actually glow and still not be working 100% and letting enough current through to the valve. You could swap an identical valve out to check it, if you don't have a meter. It's more than likely the valve though.
Posted on Jul 23, 2009
marka19
  • 1430 Answers
SOURCE: My GE Profile gas oven will not ignite. The
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Posted on May 13, 2010
oldTech2332
  • 2341 Answers
SOURCE: whirlpool range glow bar glows
iHello,
The problem beleive it or not is that the bake igniter is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake igniter(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of igniter make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake igniter. I know it seems improbable that if the igniter comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the igniter comes on yet the oven won't heat that a weak igniter is the cause 100% of the time
The part number for that igniter is 98005652 it could be purchased from your local appliance parts store or online at;
repairclinic.com
apdepot.com
searspartsdirect.com
apwagner.com
midwestapplianceparts.com
Gene
Posted on Aug 22, 2011
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by amps.it takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
May 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a GE Kitchen range XL44, stove top burners work fine, but oven won't light??? HELP please
Unplug the range.
Remove the oven racks.
remove the oven base pan.
remove the flame spreader pan.
remove the glow bar ignitor on the left hand side of the gas burner and replace it with a good ignitor.
Jan 25, 2010 | GE Kitchen Ranges
Xl44 oven burner pulses, doesnt properly heat up.
it seems the burner in the oven is clogged, by grease, carbon or corrosion, it may need replacing, specialy if this is an older unit
Jul 30, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Jul 23, 2009 | Kitchen Ranges
GE Profile Gas Range oven light doesn't work even after changing
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
The oven doesn't work ,the ignator doesn't light up. no gas coming oven doesnt work. it wont ignite. i smell no gas coming in. burners work fine
ok try your broiler if it lights change the glow bar in the lower oven the glow bar acts as a safty if it doesnt reach a certain temp the safty valve wont alow gas to enter the broiler and bake are on seperate ignighters if neither work change the safty valve
Feb 11, 2009 | Amana ARGS7650SS Gas Kitchen Range
Hotpoint oven glowbar not working
My oven glowbar stopped working christmas morning. Yesterday we bought a whirlpool brand (igntr-oven #4342528) because it is twenty something dollars cheaper then GE. My husband installed it today. The only difference is you have to splice the wires (it comes with everthing you need) The first time he put it in it did not work because he had the wires backwards. He switched the wires and now its working fine.
My oven is two years old also.
Dec 27, 2008 | Ovens
Ligthing the oven glow bar
you need to replace the oven glow bar take out the oven racks in the bottom of the range you will see two screws remove them remove the bottom oven pan under that is the flame spreader shield under that under it you will se the ignighter at the back of the burner bar just follow the instruct sheet with the ignighter to install and reverse just because the old bar glow-es don't mean its good just replace it
Jul 16, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Can i swap the broiler glow bar for the oven glow bar
changing glow bars are not recommend the bake and the broil have different ohm values and probably wont work
Jan 01, 2008 | GE Profile JGS968 Gas Kitchen Range
GE XL 44 GAS OVEN
there is an ignitor called a glow bar in the oven if its gone bad or just gotten weak the saftey valve wont open to let gas in so it wont be able to light. replaced the glow bar
Nov 26, 2007 | GE JGBP28 Gas Kitchen Range
Kitchen Ranges Logo
37 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
