Question about Audiovox SMP3332 MP3 Player
Problem playing certain tracks
On alot of my songs, it says "plz sync to listen tracks" i have no idea what it means and it wont let me play these songs.
0 characters
1 Points
My ipod touch will not play in shuffle mode plays a couple of tracks then stops
you might have reset to shuffle again
The iPod's shuffle feature lets you randomize playback of albums, songs or even your entire music library. You may also find this feature useful if you want to listen to forgotten tracks in your library or discover songs you haven't listened to yet. Disabling the shuffle feature will return playback of a song list to its standard consecutive order. You can enable and disable the shuffle feature at any time.
Navigate to the main menu. Select "Settings." Scroll to the "Shuffle" option. Select "Songs" or "Albums." If you select "Songs," the iPod Classic will shuffle the songs on whatever song list you listen to. If you select "Albums," the iPod Classic will play all songs of an album you select in order and then randomly select another album. Navigate to the playlist or album to which you want to listen. Play a song to initiate the shuffle. b> iPod Nano and iPod Touch Tap the "Songs" icon on your nano home screen. If you are using an iPod Touch, open the "iPod" application. Navigate to the song list, playlist or album you want to play. Tap the "Shuffle" icon at the top of the list to activate the feature.
Feb 11, 2013 | Apple iPod touch
My iriver t7 starts on the same song when powered
normally when you go to the setting and then go to music then power up song you can change what song plays when the ipod turns on. hope this helps. if it doesnt im sorry :(
Feb 06, 2010 | iRiver 1t072pnk T7 Volcano 2 Gb MP3...
"Bad Track" Messages on e260
You have songs that may be protected or the wrong format for your device.
delete the bad song and download another copy from a different source and try it.
This is not to uncommon due to different file formats and protection in the song files
When you rip songs from another device often some won't load or play in another device
especially if they are paid for songs.
May 12, 2009 | SanDisk Sansa e260 MP3 Player
Sync Notice
hook it up to your computer and allow windows media player to sync your mp3 player to the computer.
Apr 16, 2009 | SanDisk Sansa m230 MP3 Player
Sync Notice
This usually indicates that the content you are trying to listen to has digital rights associated with the media. This woud normally be the case if the content was downloaded via a subscrition service such as Napster or Rapsody, which means you are basically "renting" the song instead of buying it. In order to validate that the subscription for that media is still valid (i.e. you have paid for the subscription) you must sync the device with the service on a periodic basis. For example, with NapsterToGo you must sync a device at least every 30 days to validate the subscription.
Jan 05, 2009 | SanDisk Sansa m240 MP3 Player
The songs are in the wrong format - they need to be stripped of their DRM license (illegal) or converted to mp3 format.  The best, most legal way to do this is to redownload the songs as an Mp3 file, or re-rip your CD's in Windows Media Player in Mp3 format.
these problems occur because the user is trying to download a song format that the player does not recognize. Every music file is in a certain format. The most common music file formats are Mp3, WMA, AAC (iTunes), WAV, RA, etc.  In addition, every file format type is in a certain bitrate, size, etc.  By far the most common issue is that the music file contains a license or copyright (especially with WMA or AAC file formats).  Each Mp3 player only recognizes a certain number of these formats. Every Mp3 Player is different. You will have to check your Mp3 player’s product specifications (specs) or user’s manual to find out which formats your particular Mp3 player recognizes. When you try to download or sync the wrong file format, you will get one of the errors that I mentioned above.   If you want to know what file type you have, then you must find the location of the individual music file on your computer, right click the title of the song, and select the option “Properties” from the menu.
Mp3 player product documentation is not straightforward.  If a player supports only non-protected WMA files, it will merely say that it supports WMA – it will not tell which type of WMA it supports.  A player that supports DRM-protected WMA’s will usually indicate such on the box (usually with a Windows Plays For Sure logo – which is actually an ironic misnomer).  DRM stands for Digital Rights Management, and it is a type of licensing system for WMA files.  It is used extensively by mp3 player music services such as Bearshare, LeapFrog, Napster, and others.  Not all DRM licenses are created equal – there are licenses with “play rights,” burn rights,” and “transfer rights.”  Play rights mean that you can only play the song on your PC – it will play fine on your computer, but it will not play in your mp3 player even though it appears to transfer.  Burn rights mean that the song can be burned to CD.  Transfer rights mean that the song can be transferred onto an mp3 player that supports DRM-protected files.  Then, there are unlimited licenses and limited licenses.  Limited licenses only allow you to play a song for a certain length of time. You would have to pay extra to continue using the song after that trial period is over – the time length ranges from a few days to several months or longer.
-Tha Mp3 Doctor
Sep 12, 2008 | SanDisk Sansa e260 MP3 Player
No license to play track
That means you will have to sync your devicce in oder to play the songs on the device..what you will have to do is to transfer one new track that you download to your device...then once you finish transfer it the tracks, it should update every single tracks on the device...if that doesnt solve the problem you are having..what you will have to do is to format the player using windows media player then once you format it transfer the tracks over and the should be playing...
Hope that helps
Thank You
P.S...Please rate accordingly..
Dec 20, 2007 | Dell Pocket DJ MP3 Player
Player wont play certain albums when getting close to being full.
There is a maximum number of songs allowed (1000 for 4 GB) so you are probably over this magic number - they are still listed just don't play. I don't have solution for you - just a reason why.
Nov 22, 2007 | iRiver T60 MP3 Player
Syncing songs
i solved my problem, i think, by reformatting the player. the iriver tech help offered several methods to reformat, which didn't work. but this did: settings,--advanced,--format device. this will delete everything on the player, but now it can sync successfully.
Sep 06, 2007 | iRiver Clix Digital Media Player
Sync notice
you just go into ur mp3 and in your setings it will ask u to deleat all songs and u say yes then u just put the songs u want back in
Aug 12, 2007 | Insignia NS-DA2G MP3 Player
MP3 & Digital Media Players Logo
16 people viewed this question
Top Audiovox MP3 & Digital Media Players Experts
aliasger yq
Are you an Audiovox MP3 and Digital Media Player Expert? Answer questions, earn points and help others
