Question about Lexmark T630 Laser Printer
922 SERVICE FUSER ERROR - Lexmark T630 Laser Printer
    Problem Solver:
  • 35 Answers
922 means the fuser did not reach operating tempture. most likely the bulb in the fuser has gone out. Depending on how old your printer is, the fuser could need either rebuilt or replaced.
Posted on Aug 05, 2014
  • 300 Answers
SOURCE: I have a Lexmark X422 It
This means Fuser failed to reach
standby temperature.
The only answer is to replace the fuser, part number 56P0648 110 VOLTS, 56P0671 220 VOLTS.
Please advise if you require instructions
Posted on Aug 04, 2008
SOURCE: Fuser Error
bought a new HP printer!
Posted on Nov 05, 2008
  • 3 Answers
SOURCE: Lexmark T642 Laser Printer error message922 02
Service fuser error requires a maintenance kit, this is approx $1000 + installed, if this is new, I would be taking it back because it shouldnt have this error. You possibly might be able tto fix it by replacing the fan in the back but thats only worked for me in approx 1 out of every 10 times.
Posted on Jan 30, 2009
don_farr
  • 1011 Answers
SOURCE: "922 SERVICE FUSER ERROR"
920, 921, or 922 Fuser Error:
The printer thinks the fuser unit is not heating up to the correct operating temperature. This can be due to a bad fuser lamp or possibly no power getting to the fuser unit. As a customer, the only other thing you can do is to check the connections on both the fuser unit and where it goes into the printer. Make sure neither connection is damaged. If you are a technician working on the printer, you can check the voltage coming off the system board and Low Voltage Power Supply (LVPS) to make sure power is getting to the fuser unit.
Don
Posted on Jun 04, 2009
  • 320 Answers
SOURCE: 922 service fuser error
a 922 error is created by an open ac circuit(lamp circuit) on the fuser. the t520 t 522's have lamp holder problems that allow arching from the ill fitting metal contact to the end of the heating bulb. it is not uncommon for the end of this contact to be cut completely in half by the arching causing the 922 error. there are 4 components making up this circuit #2 lamp holders a thermal fuse and the bulb it self. percentage wise for this arching causing this failure is really close to 99.5% of the time. this damage is clearly visable if you remove one of the lamp holders and look at the contact
Posted on Jul 08, 2010
Marca error 922 service fuser lexmark t520
922 Fuser Error messages indicate that the fuser unit failed to reach the standby temperature.
  • If this is the first time you have seen the error, turn the printer off and on. Leave the printer off for at least 10 seconds before turning it back on. This gives the printer's engine board a chance to reset.
  • If this is an intermittent error, you may want to check how the printer is plugged in, even if it has worked on this surge device for months. Make sure the printer is plugged straight to the wall and not through a surge device or power strip. Power strips and uninterrupted power supplies can cause a low amperage problem in your printer which can trigger a false fuser error.
  • If this does not help or if this error appears every time the printer is powered on, you will probably need service on the machine. I suggest you contact Lexmark Technical Support.
  • Aug 23, 2011 | Lexmark T520 Laser Printer
  • 921 Fuser Error and 922 Fuser Error messages indicate that the fuser unit failed to reach the standby temperature.
    Nov 10, 2010 | Lexmark T522 Laser Printer
    I am getting a 922 service fuser error on my lexmark optra s 1855
    922 Fuser Error message indicates that the fuser unit failed to reach the standby temperature. This usually requires a service call but try to turn off the printer for 30 seconds before turning it back on to give the engine board a chance to reset. Make sure the printer is plugged in straight to the power outlet in the wall. Bypass any surge device or power strip as they can cause low amperage. If the problem continues or if the error appears every time the printer is powered on, you will probably need service on the machine.
    Aug 26, 2010 | Lexmark Optra S 1855 Laser Printer
    922 Fuser Error indicates that the fuser unit failed to reach the standby temperature. Leave the printer off for at least 10-15 seconds before turning it back on. This gives the printer's engine board a chance to reset. Make sure printer is plugged in straight to the wall, bypass any surge device or power strips as this can cause a low amperage problem in your printer which can trigger a false fuser error. If this does not help, you'll probably need service on the machine. A replacement might be needed for LVPS, the fuser or worse the system board.
    Jun 28, 2010 | Lexmark T522 Laser Printer
    E 352dn Mono Laser Printer: error 922 service fuser error...
    Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model T632, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
    If the printer is out of warranty, your next option is to change the fuser which costs around $90 on Ebay.
    May 18, 2010 | Lexmark E 352dn Mono Laser Printer
    I am getting a 922 Service Fuser Error what does that mean?
    a 922 error means that the ac circuit is open. this is the heat lamp circuit. a burned out bulb, blown thermal fuse, or pitted contacts will be the cause. replace the fuser and your back up and running
    Oct 06, 2009 | Lexmark Optra T610 Laser Printer
    Don
    Jun 04, 2009 | Lexmark T520 Laser Printer
    922 Server fuser error
    922 fuser errors is a bad fuser - you might try turning off printer - holding the select and return button down at the same time - turn on printer - HOLD buttons until it starts inting (about 15 sec) and the arrow over to print test pages - if the error doesn't return - repeat a few times.... this may by pass the error.. then power off - ON and see if problem is gone. replace fuser if not
    Apr 08, 2009 | IBM Infoprint 1120 Laser Printer
    ERROR
    921 Fuser Error Indicates that the fuser is below standby temperature when the printer is idle.
    Error codes 920, 921, and 922 may display for a cold fuser failure. A 920 error caused by low line voltage can sometimes be cleared by turning the machine off and then on again.
    Service Tip: Set the Fuser Temperature to NORMAL before starting this service check.
    Manually spin the fan and check that
    it rotates freely. Check the cable
    connection to the engine board, J13
    for correct installation.
    Jan 23, 2008 | Lexmark Optra M410 Laser Printer
    Lexmark T630 Laser Printer Logo
    352 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
