Question about Kohler Plumbing
Unable to remove valve from Kohler faucet K-T15880-4K
There is water leak from the faucet handle on the hot side. I can open the handle and able to see the valve. I can get to using a deep set 5/8" socket wrench. But the valve seems stuck and can't open it. Appreciate any help regarding this.
  • 148 Answers
SOURCE: Kohler Forte Single Handle Faucet Leaks
you will have to replace the ball assembly with a repair kit
1 turn the water off under the sink (hot and cold)
remove the handle ( you may need an allen head wrench to remove a hex screw or you may have to take a channel lock pliar and unscrew achrome
nut over the ball mechanism
after the handle comes off there is usually some type of lock nut that you must remove to remove the ball mechanism
remove the ball (usually chrome or brass(ther are usually little springs and rubber washers under ball
take ball and washer to ACe or lowes and match the pieces (usually sold as a kit
follow directions and installl
turn water on and pat yo!ur self on the back !
Posted on Jan 05, 2009
  • 659 Answers
SOURCE: Adjusting single leaver faucet handle
The little wrench tightens the tension ring that fits on the inside of the retaining nut right under the handle. You fit the little "arms" in the notches.
Posted on Apr 06, 2009
  • 4 Answers
SOURCE: Leaking Delta kitchen faucet dual handle
Pry the hot/cold button off the top of the handle. Make sure the water is turned off below the sink.
Under the button should be screws. Remove the screws. Pry the handle off. Remove the stems by lifting then out.
That should give you access to the washers you need to change.
Posted on Jun 13, 2009
  • 297 Answers
SOURCE: Replacing the ceramic valve in the handle, how do you remove it?
it has a screw down cap on top of the valve.counterclock wise.then pull straight up on valve. if you twist the supply line while doing this disconnect the line first then work on valve.
Posted on Jul 15, 2009
bearsfan7538
  • 119 Answers
SOURCE: kohler k19774-4 faucet single control valve is
You need to call 1-800-4-KOHLER and get a replacement cartridge
Posted on Nov 15, 2009
Kohler single handle kitchen sink replaced valve kit cartridge turned water on but no hot water replaced hot water angle stop valve turned hot water on and get nothing hot vale is open no water help
-Only at the sink has no hot water...?
If yes then:
-Make sure the valve on the wall is Turn On.
-If not sure which way then turn faucet on and then turn the vale on to either side to find out.
Good luck
Mai
Nov 01, 2017 | Kohler Plumbing
Why does my kohler 78061aa limit the amount of hot water coming out of faucet
Blocked inlet.
Supply shutoff not open all the way.
Debris in shutoff valve. This happens in older valves with washers.
Jul 06, 2014 | Kohler K-10430-VS Fort½ Single Lever...
Leaking hot water seal
leaking around handle?Turn water off under sink.remove handle,cover plate,unscrew valve stem assembly,and turn the two pieces apart to expose o ring,and replace
Jan 27, 2011 | Kohler K-16109-4-CP Revival Kitchen Sink...
Kohler K-16109-4 Revival Kitchen faucets (two handle): When I turn on the HOT water handle and let it run, I get a small leak out of the COLD water handle. When I run cold, no leak. Does this just...
There is definitely a problem with the cold valve if it is leaking, but it seems odd that it doesn't leak when it is on. If I was doing this, I would replace both valves.
Nov 14, 2017 | Kohler K-16109-4-CP Revival Kitchen Sink...
Cannot remove Kohler ceramic valve
is this a single handle faucet. If not the part goes in under the handle
Nov 02, 2017 | Kohler Model 10433: Fort® Single-control...
My Kohler Fairfax faucet pressure /flow has dropped (cold)
Verify the cold water outlet has equal pressure as the hot side outlet at the wall. Check the inlet screen on the cold side water line where it attatches to cold water pipe. The screen could be plugged. Then check the cold side hose for any restrictions. Also check if there is a screen on the outlet side of the cold water hose and see if it is plugged. Otherwise the faucet valve is mis-aligned and will need to be rotated and re-tightened to align the valve to the center so both sides have equal water flow.
Nov 08, 2009 | Kohler K-12176-PB Fairfax Single Handle...
Unable to pull spout to replace O'Ring in Kohler Faucet F10416
They just pull out, sometimes things get stuck and I cant get them lose as a plumber and you just have to buy a new one...dont feel bad
Jan 31, 2009 | Kohler K-10416-BN Fort½ Single Control...
No water coming out of my Kohler Forte R10275-4-BN shower valve
This is a pressure balancing valve that needs both cold and hot water pressure to operated. It is an anti-scald safety operation.
Good Luck, Phil
Dec 25, 2008 | Plumbing
Nov 12, 2008 | Kohler Forte entertainment remote valve...
Plumbing Logo
Top Kohler Plumbing Experts
Mike
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
