1993 Honda Accord Logo
Posted on Feb 23, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No fire to the spark plugs - 1993 Honda Accord
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jul 15, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1614
Points
No current to spark plugs
raj somaiya
Level 3:
  • Honda Master 5,370 Answers
  • Posted on Feb 26, 2012
raj somaiya
Honda Master
Level 3:
Answers
5370
Questions
0
Helped
3570760
Points
14579
For spark plug problem,click the help links provided below :---Car has no spark?http://schematicsdiagram.blogspot.com/2011/06/car-has-no-spark.html
------------How to Replace Spark Plugs?http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-spark-plugs.html
-------------Car cranks, has spark but will not start?
http://howtobyme.blogspot.com/2011/12/car-crankshas-spark-but-will-not-start.html
The spark plug firing order for car?http://schematicsdiagram.blogspot.com/2011/06/spark-plug-firing-order-for-car.html
----------How to gap spark plug ?http://technoanswers.blogspot.in/2012/02/how-to-gap-spark-plug-on-chevy-impala.html-----------Spark plug Replacing for?http://technoanswers.blogspot.in/2012/02/spark-plug-replacing-for-chevy-impala.html
-----------How to identify number one spark plug on the distributor cap?http://schematicsdiagram.blogspot.com/2011/12/how-to-identify-number-one-spark-plug.html
---------How does the spark plug wire go on the distributor cap?http://schematicsdiagram.blogspot.com/2011/12/how-does-spark-plug-wires-go-on.html
---------Spark plug Firing Order Diagram?http://schematicsdiagram.blogspot.com/2011/12/2006-suzuki-forenza-spark-plug-firing.html
-----------This will help.Thanks.
2answers
No spark to engine 1991 ford pickup
It can be faulty or dirty spark plug itselfd.Also for reference get the fuel level checked.Is the fuel tank is empty or near to empty.
Try cleaning the spark plugs and then see if that is helpin.On some cases the black carbon layer gets collected on the spark plugs and that causes the problem,so cleaning the plugs help.But if its not helping,then spark plug has to be replaced.Spark plugs get power from ignition coil to ignite sparks.If ignitioncoils are faulty then also there will no spark.--------------
To troubleshot and confirm the issue,i suggest you to go through the help links provided below,check the procedure and it will help you to confirm the issue in your case.
Click the link below:------
Car cranks, has spark but will not ?
How to Perform a Basic Engine Tune Up-Spark Plug and Wire Change
http://schematicsdiagram.blogspot.com/2011/08/how-to-perform-basic-engine-tune-up_01.html
Car has no spark?
How does the spark plug wire go on the distributor cap in 1991 Mitsubishi Mighty?
No spark on 2008 Chevy Avalanche?
http://schematicsdiagram.blogspot.in/2012/04/no-spark-on-2008-chevy-avalanche.html
How does the spark plug wire go on the distributor cap in 1985 Pontiac sunbird?
http://schematicsdiagram.blogspot.com/2011/12/how-does-spark-plug-wire-go-on.html
Ford Plug Wires Not Coming out?
http://whoisbyme.blogspot.in/2012/06/ford-plug-wires-not-coming-out.html
Ford explorer has no spark?
http://schematicsdiagram.blogspot.com/2011/12/ford-explorer-has-no-spark.html
Chevy impala spark plug firing order diagrams?
http://technoanswers.blogspot.in/2012/02/chevy-impala-spark-plug-firing-order.html
How to gap spark plug on Chevy Impala?
Spark plug Replacing for chevy impala?
Chevy s-10 blazer 4.3l Spark Plug Firing Order?
http://howtobyme.blogspot.com/2011/12/chevy-s-10-blazer-43l-spark-plug-firing.html
1982 dodge rampage Spark plugs Firing Order Diagram?
http://schematicsdiagram.blogspot.com/2011/12/1982-dodge-rampage-spark-plug-firing.html
2006 Suzuki Forenza Spark plug Firing Order Diagram?
1983 Ford Ranger Spark plug firing order?
http://schematicsdiagram.blogspot.com/2011/12/1983-ford-ranger-spark-plug-firing.html
Firing Order for 1991 Lexus ES 250?
http://schematicsdiagram.blogspot.com/2011/12/firing-order-for-1991-lexus-es-250.html
Firing order for 1992 Chevrolet 5.0 engine?
http://schematicsdiagram.blogspot.com/2011/12/firing-order-for-1992-chevrolet-50.html
How to remove rear spark plugs on 1991 Buick Regal?
http://howtobyme.blogspot.in/2012/02/how-to-remove-rear-spark-plugs-on-1991.html
These details will help.
Thanks.
Not getting spark out of spark plugs
For spark plug problem, click the help links provided below: ---
Car has no spark?
How to gap spark plug ? http://technoanswers.blogspot.in/2012/02/how-to-gap-spark-plug-on-chevy-impala.html
This will help.
Thanks.
8helpful
Firing Order diagram for 2006 Ford Explorer
Hope this helps. The ignition coil:
  • changes low-voltage pulses from the PCM to high-voltage pulses.
  • fires 2 spark plugs simultaneously.
  • has 3 transformers.
    • One transformer fires the spark plugs for cylinders 1 and 5
    • One transformer fires the spark plugs for cylinders 2 and 6
    • One transformer fires the spark plugs for cylinders 3 and 4
Spark plug wires:
  • carry high-voltage pulses from the ignition coil to the spark plugs.
The spark plugs:
  • change high-voltage pulses to spark at the gap, which ignites the fuel and air mixture.
The firing order is 1-4-2-5-3-6.
11helpful
I need the diagram to put the spark plug cables
2003 Chevrolet Malibu 3.1L SFI OHV 6cyl
Spark Plug Wires - Removal & Installation
3.5L Engine
  1. Before servicing the vehicle, refer to the Precautions Section.
    NOTE Twist the spark plug boot one-half turn in order to release the boot. Pull on the spark plug boot only. Do not pull on the spark plug wire or the wire could be damaged.
  2. Remove the intake manifold cover, if required.
  3. Disconnect the left side spark plug wires from the spark plugs.
  4. Disconnect the left side spark plug wires from the ignition coil.
  5. Remove the spark plug wire clips from the Manifold Absolute Pressure (MAP) sensor bracket and the heater inlet and outlet pipe tab.
  6. Remove the spark plug wire assembly.
  7. If replacing only one plug wire, open the retaining clips and remove the appropriate spark plug wire.
  8. Disconnect the right side spark plug wires from the spark plugs.
  9. Disconnect the right side spark plugs from the ignition coils.
  10. Remove the spark plug wire assembly.
  11. If replacing only one plug wire, open the retaining clip and remove the appropriate spark plug wire.
To install:
  1. Install the spark plug wire assembly.
  2. Connect the right side spark plugs to the ignition coils.
  3. Connect the right side spark plug wires to the spark plugs.
  4. If replacing only one plug wire, open the retaining clip and install the appropriate spark plug wire.
  5. Install the spark plug wire assembly.
  6. Connect the left side spark plug wires to the spark plugs.
  7. Connect the left side spark plug wires to the ignition coil.
  8. Install the spark plug wire clips to the MAP sensor bracket and the heater inlet and outlet pipe tab.
  9. If replacing only one plug wire, open the retaining clips and install the appropriate spark plug wire.
  10. Install the intake manifold cover, if required.
Fig. 2.2L Engine Firing Order: 1-3-4-2 Distributorless ignition system
Fig. 3.1L Engine Firing order: 1-2-3-4-5-6 Distributorless ignition system
Fig. 3.5L Engine Firing order: 1-2-3-4-5-6 Distributorless ignition system
Fig. 2.4L Engine Firing order: 1-3-4-2 Distributorless ignition system
Fig. 3.5L & 3.9L Engines Firing order: 1-2-3-4-5-6 Distributorless ignition system
I really hope help you with this (remember rated this help) Good luck.
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
