ACCESS DOS MENU
I need to acces the dos screen so i can fix the "MBR" ! which "F" key dpes this for an emachine ?
metroice
  • 105 Answers
SOURCE: My AOC 17" CRT monitor displays large veiw on DOS & some PC DOS games where the top portion is displayed at the bottom of the screen.
sounds like you need to run a screen config wizard. If you have a true Nvidia driver you can do this. Otherwise, re-download the driver from the main website http://www.nvidia.com/page/home.html
and it'll work for you
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/stephen_171aeeebef53a898
Posted on Nov 01, 2007
SOURCE: PSP turned on, black screen, cannot access recovery menu
Your psp screen may have broke you can buy a repair or get it fixed at ebay.com.Type in psp repair and you will see people will fix them for a low cost.
Posted on Nov 11, 2008
  • 565 Answers
SOURCE: Dos mode not supported on Acer LCD
use run from startmenu and there write cmd then u can also use the command prompt
Posted on Dec 26, 2008
rockitman187
  • 2559 Answers
SOURCE: where is tab key & alt key does not work in dos programs
Tab key is located on the lefthand side of the keyboard just above the Capslock key and says TAB on it,It should also have two arrows,One facing left and one facing right.
Try the other Alt key located at the other end of the space bar
Posted on Jan 07, 2009
rylee_smith
  • 8619 Answers
SOURCE: touch screen dos not work on garmin GPS street pilot 7200
Try resetting the unit by using a ball point pen or other sharp thing and press it for more than 10 seconds. It would be on the left/right/back side of your unit.
Also, try to hold your finger on the power key for approximately 15 seconds until you see a message "This operation will erase all waypoints, do you want to continue?"
Tap yes and the unit should reboot then attempt to acquire satellites. You will lose any favorites you have saved but it may save you a trip to the factory.
Please ask for further clarifications.
Please rate this solution as FixYa if found useful.
Thanks
Rylee
Posted on Mar 08, 2009
It's impossible install MBR, How I can get install?
If this MBR mean, Master Boot Record, it's a DOS-alike thing.
You require a DOS or Windows 95 / 98 bootflop, containing the program FDISK (forgot if it was .com or .exe)
After booting you get the DOS-prompt which is text-based and looks like :
"A:>_" or "C:>_"
Now, in this case you enter the following: "fdisk /mbr"
So the DOS-prompt will look like :
"A:>fdisk /mbr" or "C:>fdisk /mbr"
Then you hit the ENTER-button at your keyboard and if DOS can find this fdisk-program, it will rewrite the master boot record of your harddisk.
Oct 11, 2013 | Toshiba Computers & Internet
Tip
Creating a bootable flash drive
<p><b>Resolution:</b><br /> <p>The USB Flash Drive must be configured with an active primary MS-DOS partition. It must also contain the boot files. Follow the steps below to create a bootable USB Flash Drive. <br /> <p><b>Requirements:</b><br /> <ul> <li> Motherboard with BIOS that supports USB boot. <li> USB Flash Drive that may be erased. <li> Bootable floppy disk or CD with Fdisk and Format commands. </li></ul> <p><b>Directions:</b><br /> <ol> <li> Plug in the USB Flash Drive. <li> Make the USB drive the only bootable hard drive. <b>Method 1:</b><br />If available, change the BIOS settings for the hard drive sequence, making sure the USB device is at the top of the list above all other hard drives. Not all BIOS Setup Utilities have this option. <b> Method 2:</b><br /> Disable all hard drives in the BIOS. In some BIOS Setup Utilities you can disable the individual hard drives, while in others you will need to disable the controller. <b> Method 3:</b><br /> Unplug all hard drive cables inside the case. If the cables are unplugged the computer cannot detect and boot to the hard drive. <li> Insert the bootable floppy disk or CD into the appropriate drive. <li> Restart the computer to the bootable floppy disk or CD. <li> At the command prompt, type: FDisk. <li> Delete and create a new active primary DOS partition. <li> Use FDisk to delete all partitions from the USB Flash Drive. <ul> <li> In FDisk, press the 3 key to Delete partition or Logical DOS Drive. <li> If there is just one partition on the drive, choose 1 to delete the primary DOS partition. If there are several partitions, the extended and logical partitions must be deleted before the primary partition. <li> After choosing option 1, the screen appears with partition information and a prompt for the partition to delete. Choose which primary DOS partition to delete, and then press ENTER. <li> A prompt appears to enter the volume label of the hard drive. Enter the label exactly as it appears on the top of the screen in the partition information. If the volume label contains gibberish or lowercase letters, the partition will have to be deleted as a non-DOS partition. Try using the option to delete a non-DOS partition in FDISK. After entering the volume label, press ENTER. <li> You are prompted if it should delete the partition. Press Y for Yes, and then press ENTER. <li> The screen changes to show only the total disk space and a line near the bottom that prompts that the primary DOS partition has been deleted. Press the ESC key to return to the main menu. </li></ul> <li> Use FDisk to create a primary partition on the USB Flash Drive. The drive letter will be C:, since all other hard drives were disabled in step 2. <ul> <li> In FDisk, press 1 to Create DOS partition or Logical DOS drive. <li> Press 1 to Create a Primary DOS Partition. <li> The next screen prompts if the maximum hard disk size should be made into one partition. Press the Y key, and then press ENTER. <li> The next screen prompts that the computer will now reboot. Press ENTER to continue. </li></ul> <li> Exit FDisk and restart the computer. <li> Start the computer from the bootable floppy disk or CD with the USB Flash Drive still connected. <li> At the command prompt, run Format by typing the following command: Format c: /s. Press ENTER. <li> At the command prompt, run FDisk by typing following command: Fdisk /mbr. Press ENTER. <li> Restart the computer without the bootable floppy disk or CD, and attempt to boot to the USB Flash Drive. If it works, it should go to a C:\&gt; command prompt. <li> Change the settings made in step 2 back so that the computer operates normally again. </li></ol>
on Mar 14, 2011 | Computers & Internet
Tip
Creating Bootable USB Flash Drive.
Requirements:
  • Motherboard with BIOS that supports USB boot.
  • USB Flash Drive that may be erased.
  • Bootable floppy disk or CD with Fdisk and Format commands.
Directions:
  1. Plug in the USB Flash Drive.
  2. Make the USB drive the only bootable hard drive. Method 1:
    If available, change the BIOS settings for the hard drive sequence, making sure the USB device is at the top of the list above all other hard drives. Not all BIOS Setup Utilities have this option. Method 2:
    Disable all hard drives in the BIOS. In some BIOS Setup Utilities you can disable the individual hard drives, while in others you will need to disable the controller. Method 3:
  3. Insert the bootable floppy disk or CD into the appropriate drive.
  4. Restart the computer to the bootable floppy disk or CD.
  5. At the command prompt, type: FDisk.
  6. Delete and create a new active primary DOS partition.
  7. Use FDisk to delete all partitions from the USB Flash Drive.
    • In FDisk, press the 3 key to Delete partition or Logical DOS Drive.
    • If there is just one partition on the drive, choose 1 to delete the primary DOS partition. If there are several partitions, the extended and logical partitions must be deleted before the primary partition.
    • After choosing option 1, the screen appears with partition information and a prompt for the partition to delete. Choose which primary DOS partition to delete, and then press ENTER.
    • A prompt appears to enter the volume label of the hard drive. Enter the label exactly as it appears on the top of the screen in the partition information. If the volume label contains gibberish or lowercase letters, the partition will have to be deleted as a non-DOS partition. Try using the option to delete a non-DOS partition in FDISK. After entering the volume label, press ENTER.
    • You are prompted if it should delete the partition. Press Y for Yes, and then press ENTER.
    • The screen changes to show only the total disk space and a line near the bottom that prompts that the primary DOS partition has been deleted. Press the ESC key to return to the main menu.
  8. Use FDisk to create a primary partition on the USB Flash Drive. The drive letter will be C:, since all other hard drives were disabled in step 2.
    • In FDisk, press 1 to Create DOS partition or Logical DOS drive.
    • Press 1 to Create a Primary DOS Partition.
    • The next screen prompts if the maximum hard disk size should be made into one partition. Press the Y key, and then press ENTER.
    • The next screen prompts that the computer will now reboot. Press ENTER to continue.
  9. Exit FDisk and restart the computer.
  10. Start the computer from the bootable floppy disk or CD with the USB Flash Drive still connected.
  11. At the command prompt, run Format by typing the following command: Format c: /s. Press ENTER.
  12. At the command prompt, run FDisk by typing following command: Fdisk /mbr. Press ENTER.
  13. Restart the computer without the bootable floppy disk or CD, and attempt to boot to the USB Flash Drive. If it works, it should go to a C:\> command prompt.
  14. Change the settings made in step 2 back so that the computer operates normally again.
on Mar 31, 2010 | Computers & Internet
How to fix bootmgr is compressed in Panasonic CF-52 ?
You will need a operatingsystem disk or a repair disk to fix it. Insert it in the drive then bootfrom it. You want to get to a dos command prompt (black screen with whitelettering) and type the following commands. Press ENTER after eachcommand.
bootrec.exe /fixmbr
bootrec.exe /fixboot
bootrec.exe /rebuildbcd
Reboot and see if the problem is solved. If not get back to the doscommand prompt and run the check disk utility.Torun the check disk utility you will need a repair disc or a operating systemdisc. Put the disc in the cd drive and boot from it. You want toget to the Dos Command Prompt (Black screen with white letters) and type thefollowing command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Jun 05, 2012 | Computers & Internet
How to format Toshiba Satellite L655- S5098
Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
May 18, 2012 | Computers & Internet
Non-System Disk or Disk Error Boot from CD
The error means that the CD you have in the drive is not a system disk. Remove it. Are you trying to boot from a CD, if so make sure it is a repair disk or operating system disk. If not, remove the disk and you system will then look to boot from the Hard Drive.
Run the Check Disk Utility.
Apr 30, 2012 | E-Machines eMachines Desktop PC
Wiped old PC clean with blanco.installed win xp on old pc got response.turned it off black screen stating, blanco starting_ How do I fix
Blanco is a data cleaner utility that erases everything from a hard drive so data cannot be recovered. Unfortunately, this includes the MBR - or Master Boot Record. The MBR tells the comptuer BIOS how to access the hard drive and use it to boot up.
I would suggest performing a full FORMAT of the hard drive so the MBR will be recreated. If you are installing Windows XP from an install CD, you will be given the option of which drive to install the OS to. Delete all partitions that show up, create a new partition and then choose the Full Format option (not the Quick format).
If you are using a restore disk, you may need to download a boot floppy or CD and format the drive first. Boot to DOS, type in
format c:/
Where C: your hard drive.
You can get a boot disk from...
http://www.bootdisk.com/
Apr 30, 2010 | Computers & Internet
Limited or no connectivity. No assign network Add. to comp.
Have you checked the cable?
Try this with a new cable installed:
Go to Start menu > Run > type "cmd" (without the quotes) and hit Enter or click OK.
In the black DOS-window type "ipconfig/release" (without the quotes) and press Enter.
Type "ipconfig/renew" (without the quotes)
and press Enter.
When the DOS windows displays an IP-number (e.g 192.168.1.2), close the DOS-window and try to connect.
Alternatively right click the network-connection icon down on the far right beside the clock and choose "Repair"
Apr 25, 2009 | Computers & Internet
RESET BIOS COM
1. Boot up your PC with a DOS Boot Disk or WINDOWS boot disc
2. At the DOS PROMPT or WINDOWS DOS PROMPT clear the master boot record with this command.
"fdisk /mbr" without the quotes.
This will remove the boot sector virus
3. Reinstall windows
azkeyz@fixya.com
Wizard Division
Sep 23, 2008 | HP Pavilion Slimline S3123W Desktop PC -...
24 people viewed this question
k24674
jasbo
jasbo
