Question about Minolta bizhub 250 Black and White Copier
Bizhub 250 toner recycling - Minolta bizhub 250 Black and White Copier
  • Maureen Feb 23, 2012
    where is the toner recycling box on the bizhub 250
  • 60 Answers
Toner recycling mechanism is located on the drum unit
The Cleaning Blade pressed up against the surface of the Photo Conductor scrapes residual toner off the surface. The toner is then conveyed by the Toner Conveying Rollers 1/2 to the Recycling Duct and eventually back to the Developer Mixing Chamber.Since the toner is thus recovered back to the Developer Mixing Chamber, there is no Waste Toner Bottle mounted in the machine.
Posted on Apr 14, 2012
BIZHUB 250 MANUAL ADD TONER
when toner finished than show add toner
Jun 12, 2014 | Minolta bizhub 250 Black and White Copier
Displays no yellow toner in the catride even after putting toner
There are electronic chips on the toner cartridge, when the cartridge is used up the chips tells the copier, you replacing the toner does not reset the chip, buy a new one
Feb 25, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
Konica minolta bizhub c250 error C-2AO3
magenta toner cartridge EEPROM access error, cleaned the connection between the toner cartridge and the machine once cleaned if the issue persists remove the toner cartridge and put back in again if again the error persists replace the toner cartridge with a new one and last resort if the issue is still not fixed then replace the mechanical control board.
Oct 04, 2012 | Konica Minolta Minolta Konica Bizhub C250...
ADDED TONER STILL ERROR ADD TONER
You can drop the toner cover and cheat the door sensor and watch the toner bottle to see if it spins or not. If it doesnt spin- the end result is not good especially if you have a grinding noise. or just the toner bottle not spinning and it asks to replace toner. The back of the machine will have to come off. You will have to remove all the covers and finisher off the front. Then get to the toner add mechanism and take it out. The one gear will probably be sideways because- if the customer put the toner in wrong or maybe the wrong toner in- it will bind and bend that back shaft. thereby screwing it up. It takes a lot of time and parts. First thing you need to do though- is to see if the bottle is spinning or not
Jul 25, 2012 | Minolta bizhub 250 Black and White Copier
Konicaminolta bizhub 600 machine dropping the toner. what is the solutions?
first toner must must and must be genuine, other wise it wont work in any conditions,
2nd toner density sensors and gamma sensor should be cleaned and all auto setting must be run .
third some time toner drops down the others side of the drum due to recycle clutch did't not work properly and all cleaned toner drops down after filled in recycle area,
Jan 11, 2012 | Konica Minolta bizhub 350 All-In-One Laser...
Konica bizhub 250 error c255c
there is no c255c code but if it is a c2555 c2556 c2557 or any other c255 code it may need a new image unit. please give more info
Oct 08, 2010 | Konica Minolta Bizhub c203 Copier
We have Konica Minolta Bizhub 250 What does error C2557 mean
Error code c2557 means "Auto Toner Density Control sensor abnormality" (ATDC)
Sep 20, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Bizhub 250: is the waste toner box at top of drum unit?
there is no waste toner box in bizhub 250/350.the thing which you are calling the waste box is not a waste box.that thing is "Toner Recycling".
Aug 04, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Our bizhub-250 receives a C2557
hi,
open and close front door cover to reset error.
If it persists you have to execute (TCR Toner SUPPLY)
Tell me if you need to execute it.
Bye.
Mar 05, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Minolta bizhub 250 Black and White Copier Logo
103 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
