Question about Cell Phones
I want to re-set my carrier return on Sharp PA-3110 11 typewriter back to the left
The auto return is stuck to the right
SOURCE: Swintec 7000 typewriter
Lo and behold, some light oil on the stainless bars solved the problem.
Posted on Apr 08, 2008
JayBlair
  • 328 Answers
SOURCE: return key is stuck
Need more info. Many different possibilities.
Posted on Aug 12, 2008
  • 3594 Answers
SOURCE: Carriage return problem
If it returns with the express key the latching mech. on the rt. side is probably gummy. Take off the case, get some WD40 and spray the mechinism that latches the ret on the rt. side below the platen.
DickyO
Posted on Dec 08, 2008
  • 14 Answers
SOURCE: My IBM selectric II typewriter carriage stuck in right margin
Sounds like the return lever arm is not putting enough pressure on the return clutch, or the clutch is slipping. The exp key uses the same clutch but the pressure comes from your finger. Theres no way you can fix this yourself. Get an IBM mechanic.
Posted on Oct 14, 2009
  • 125 Answers
SOURCE: IBM Lexmark typewriter carriage return won't return to left position
Hi:
Open the top cover and locate the shiny rod that the carrier moves back and forth across. Use some WD-40 on a rag to clean it well the apply a light coating of it to the entire shaft.
Posted on Jul 25, 2012
How do I increase the margins on the typewriter
To set a margin beyond the left or right margin, move the carrier (or cursor) to that margin, press the Margin Release key, then proceed to move the carrier (or cursor) to the desired position. Then, press the Left or Right margin key to set the new margin. A beep will sound indicating the new margin has been set. When you set a new left or right margin, the previous margin is automatically cleared.
Alternatively, you can type beyond the right margin by pressing the Margin Release key and then continue typing when the carrier (or cursor) stops at the right margin. To type beyond the left margin, press the Margin Release key and then the Backspace key to move the carrier (or cursor) to the position where you want to start typing.
Remember to always use genuine Swintec ribbons and lift-off tapes for your Swintec 7040, which can be found at Swintec Typewriter Supplies .
Aug 19, 2014 | Swintec 7040 Typewriter
Brother ml 500 memory typriter how do i move margin to right
Use your space bar to move carrier to desired location, hold down Alt key button on bottom left (next to space bar) and press the number 5 numeric key on top row. That should set your right margin.
Jul 30, 2014 | Brother ML-500 Typewriter
How can I get my typewriter back to its intial settings
There is no keystroke pattern to reset the EM series typewriter. There are two methods to reset this typewriter.
1.You can reset the daisywheel and remain on the same line of type, simply lift the top cover and then close it back down. The carrier will move to the left, reset the daisywheel and return to the last space typed.
NOTE: This will not affect the format settings (bold, underline, etc)
2.If you want to abandon the current typing position; turn off the typewriter, wait 10 seconds for the power supply to reset and then turn the typewriter back on. The typewriter will reset and the carrier will return to the beginning of the current line.
NOTE: Turning off the power will restore the format settings to standard default settings (bold, underline, etc).
Mar 15, 2013 | Brother EM-630 Typewriter
The return is stuck on 80 on the guide. I cannot
Turn the T/W off and slide the carrier back and forth. If it goes to the left then you have the L. margin set at 80.
Return to the margin, press and release the margin release key, backspace to the desired location, press the L. margin key.
DickyO
Mar 18, 2010 | Nakajima AE-710 Typewriter
How to set margins
after hitting the return key, the carrier goes all the way to the left margin. If you need the margin to move even more to the left, hit the margin rel key and backspace to the desired position and hit the mar left key. Same for the right margin, use the space bar to move the carrier all the way to the right margin and press the margin rel and move the carrier to the desired position and press the mar right key.
Jan 27, 2010 | Royal Satellite 40 Typewriter
IBM Wheelwriter 1000 wont Return everytime
Probably no cracking required. Spray a little WD40 on the silver shaft that the carrier slides on, if that dosen't do it there is the carrier motor in the left rear that the bearings dry up in a little WD40 will work there as well.
DickyO
Jul 08, 2009 | Lexmark Wheelwriter 1000 Typewriter
MARGINS
Try a little light oil on the silver shaft that the carrier slides on, if that doesn't do it then the carrier motor needs lubed, it is under the case on the R. rear corner.
DickyO
Apr 11, 2009 | IBM Wheelwriter 30 Typewriter
Typewriter problem
It could be a bad carrier return motor or the carrier is stuck . Turn it off and try to move the carrier left and right it should move with light pressure if it don't try wiping the round rail it slides on with a light oil then work it back and forth a few times repeat until it moves when turned on.
Jul 24, 2008 | Lexmark Wheelwriter 1000 Typewriter
Print wheel stuck at right side and won't return
Smith Corona has a carrier lock on the right side of the typewriter look for a red or blue part on the right side of the ribbon carrier and flip it back by pressing on the end of it and see if it unlocks.
Jan 26, 2008 | Smith Corona Wordsmith 200 Typewriter
CARRIER WON'T RETURN BACK TO THE CENTER
make it sure the cover of typewriter was lock ,self lock no movement of cover means good operation of typewriter.
Dec 20, 2007 | Brother GX-6750 Typewriter
Cell Phones Logo
20 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
