Question about Samsung HL-P6163W 61" TV
Samsung DLP problem
I've seen where you've advised people regarding problems with their DLP's and wanted your opinion on my problem. Basically when you're watching a DVD or a HD broadcast, the picture blacks out. There's still audio, the lamp is lit and the picture will come back. Once in awhile it will say that it's looking for a signal. I'm pretty confident that it's not the source. I can hook my Tivo box to it through the standard A/V cables and I'll never have a problem. I haven't tried hooking up my DVD in this manner but maybe I will just to check it. After doing some reading, I've come to the conclusion that it may be the digital board but my DVD is hooked up through component cables which are located on the analog board so now I'm not sure. Am I looking in the right place? I have another problem where once in awhile the TV will power off and the 3 lamps on the front will start blinking. It will do this a couple of times and then stay on. It hasn't done that in the last couple of days but I've decided that that may be a ballast problem which I did order a new one. Any help would be appreciated.
ctf1800
  • 4402 Answers
SOURCE: MY Samsung DLP TV Has Green/Purple Lines
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
Posted on Jan 16, 2008
ctf1800
  • 4402 Answers
SOURCE: Samsung HLS4266W 43" dlp
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
freetek
  • 5568 Answers
SOURCE: Samsung DLP TV Component Problem-HL61A750A1F
FYI only:
HDMI = High Definition Media Interface
DVI = Digital Video Interface
That kind of conflict (that's what it is) is tough for any one company to assist you on since it involves two manufacturers.
If you are very lucky, you might get help from a tech who has already stumbled across the same equipment complement.
Posted on May 21, 2008
Danmart
  • 291 Answers
SOURCE: Popping and fading of sound
The "popping" sound could be electricity jumping from one place to another.An internal SHORT in a transistor, an internal OPEN in a resistor.Intermittent [sometimes it does,sometimes it dose not] arcing electronic parts.
Dust [metal filings,very fine hair that burns like a fuse] & dirt [anything metal], arcing (shorted) capacitors.Bad connections on ANY ground connector.
Possible:: your surround sound MASKED the popping sounds by acting like a FILTER.Which lets me to think that your problem is in the audio section.
Posted on Jun 28, 2008
SOURCE: Samsung DLP TV time, temp and lamp lights blinking... won't turn
Les,
I'm not a TV repair guy but my owners manual states that when all three LED's or lights on the front of the TV are flashing, that the lamp needs to be replaced. Might want to look into this. Good luck!
Greg
Posted on Aug 31, 2009
Samsung dlp 5065w keeps blowing fuse
samsung motherboards are bad for going out. they are 125 dollars online, if you have the technical skills to replace them.. basically just plug and play, with LOTS of screws to take off.
Oct 06, 2012 | Samsung HLN5065W 50" DLP TV
My rear projection samsung tv dosent turn on it has just stopped it makes a squeaking noise and the light flashes then nothing.. # has any body seen this problem before
The color wheel is acommon fault with Samsung DLP TV's and cause the symptom you describe.
check the link below to see if your model# is listed.
Samsung Color Wheel
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
Nov 24, 2009 | Televison & Video
White spots on Samsung DLP
Hello the problem here is absolutely the DMD Board this is a commune problem with the Samsung DLP
are your spots like this picture?
try this link...
http://www.discount-merchant.com/
Jun 12, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Ballast or color wheel next?
The color wheel will normally spin-up even for a brief moment when the set is powered up. I have not seen a color wheel go out with a lamp. I have seen a ballast go bad with a lamp. I would replace the ballast first. You did not state wheather the color wheel was noisy or not. On the Samsung DLP, the color wheel is normally very noisy before it is gone. I hope this will help you.
Apr 29, 2009 | Televison & Video
Samsung DLP RL-P5056W 56" TV Problem
IT MAY BE SEVERAL THINGS TRY SOME OF THIS ONES ADJUST THE BACKGROUNG USUALLY BLACK LEVEL, MAYBE THE LAMPS ARE OLD AND FADING. TRY THIS TWO ITEMS.
Oct 03, 2008 | Samsung DLP HL-P5663W 56" TV
White lines on Samsung DLP
need the modle number to see if there is a service flash or fix/
Jul 29, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung dlp hl-r5078w picture problem
its a video out problem I have seen a million times and usualy a small capacitor like 10 microf/250 volt will fix it. the part will look bulged or a lead is ate off , its on the board that attaches to the CRT.
Dec 01, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung HL-P6163W 61" TV Logo
50 people viewed this question
Jerry Greenberg
Jerry Greenberg
