Question about HP Deskjet F4210 All-In-One InkJet Printer
My hp deskjet f4210 is all lights flashing/blinking just when conect to power, i did try to unplug many times but every time when plug automatly go all lights blinking, what can i do ? did try in hp solution center but nothing helps, and also metion that doesn't appears like conected in my computer. it may can be the problem due insert a new cartridge when was off and i did move the cartridges to position by hand so i can change the old one for the new one. the button for on and off it doesn't answer, just blink/flashes all light when conect to power. any help?
guide2u
  • 461 Answers
SOURCE: HP deskjet F4140 Error light on & I can"t print
please reset your printer. turn off your printer, leave it for 30 sec and turn it on again....
If you still have problem try to re install the catridges again, follow below instruction
http://etech.maiila.com/hp-deskjet-f4140-all-in-one-printer-catridges-installation
Good Luck
Posted on Nov 01, 2008
SOURCE: HP C3100 Printer, changed black
I did not get problem fixed by your expert, he did not know C3100 printer and how to fix the problem,
I had check all areas of the printer for screws he said to undo and there NO screws then the session ended and I did not get the answer. Please do not charge my American Express for a none solution and a person who did not know my printer.
Posted on Dec 17, 2008
bob_computer
  • 3153 Answers
SOURCE: I have constant blinking cartridge light on my hp
Read on and see if any applies to you.
Check that you removed the protective tape. some cartridges have two of these pieces of tape one over the head and possibly on on the contacts to the printer.
If you recently re-filled or had the cartridge refilled or even bought one of the many cheaper replacement cartridges you should read on
Most modern cartridges have an ink level chip built on to them.
Should the level drop below 25% then most of these chips lock up and will not reset.
Re-filling them will have no effect
If you are lucky you should be able to find either a
chip resetter
around on the INTERNET or maybe even local
OR
Even better empty cartridges that
never need to be reset.
The second option is my preference
I realise these are not for your specific printer but there are others listed on both those sites as well.
cheaper cartridge problems have been on the rise recently and that is for ALL makes of printer.
If you try to clean the contacts be VERY careful cleaning contacts and ONLY use isopropynol on a lint free bud or cloth.
Also be very gentle.
I have seen the contacts cleaned and cartridges ruined with other methods of cleaning.
Rubbing too hard can also cause a badly set chip to move making it inoprable.
I dont like full prices replacements either which is why I always provide the links
I usually reccomend that people take back any cartridge that does not work right from the get-go.
I dont know of anyone who has had a problem doing that be it a shop refill or otherwise.
No matter if I paid $1 or $100 for a cartrdige I would still expect it to work
Posted on Sep 18, 2009
anujbhatt
  • 66 Answers
SOURCE: HP DeskJet F4210 printer. Tricolour light
Try with another tri color cartridge, if that works fine, then the previous cartridge was faulty and if that does not work, printer is faulty, so, service the printer ..
Posted on Dec 11, 2009
Comp-U-Doc
  • 148 Answers
SOURCE: Blinking lights plus E sign for cartridge error -
Look carefully to make sure there is no paper jammed inside. Sometimes there can be a small piece of paper that tore-off in the gears causing a paper jam.
If you are satisfied with my answer, be sure to click on the "Thumbs-Up". If you have further questions, please feel free to ask them. Thanks for using our service!
Posted on May 11, 2010
Hp deskjet D4155...Both power and arrow lights are blinking and I have tryed turning it off and un-plugging the printer multiple times, Every time is comes on, they both are still blinking. Please help....
Please remove the ink cartridges, unplug the power cord. You may also remove the paper from the paper tray. Now, try inserting the cartridge as well.. after about 20 seconds, plug in the power..
put in the paper, and ensure that you have inserted the paper properly. Then insert the ink cartridge. This should resolve the problem.
But if the light is still blinking , try by replacing the ink cartridge.
Aug 12, 2010 | HP Deskjet D4160 InkJet Photo Printer
HP DeskJet F4210 printer. Tricolour light flashing. Checked HP manual for info. Checked door, seating, even replaced colour cartridge, still flashing. Other causes?
Dec 11, 2009 | HP Deskjet F4210 All-In-One InkJet Printer
Hhp deskjet 5550 - orange and green light keep
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.) 2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.) 3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons. 4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times. Finally press the Power button.
Jun 09, 2009 | HP DeskJet 5550 InkJet Printer
Lights flash on HP deskjet 6127
from what I read on line at HP forums unplugging the network cable may fix it. Others sat they had to buy a new printer
HP DJ 6127 after change of the cartridge blink lights nothing else happens
Jan 29, 2009 | HP DeskJet 6127 InkJet Printer
All three lights are flashing on my HP Deskjet 6127. I tried unplugging it from the power source and then plugging it back in. When I try to turn it on all three lights flash and it won't turn off with out...
Hi
The HP Deskjet 6127 has four buttons and three lights on the front panel
Flashing lights on the printer indicate the status of the printer
When all the lights are flashing, the printer may need to be restarted
try this 1st press the power button to turn off the printer, and then press the power button to it back on very quickly.
2nd press the power button to turn off the printer and hold it down.
Good luck
Re 870Cxi Lights do not stop blinking cant use the printer
You can check if the print spooling service is enabled. go to services.msc and locate print spooler, right click and select properties, select automatic as the start up type and start the service. see if it works.
Jan 27, 2009 | HP DeskJet 870cxi InkJet Printer
HP Deskjet F4210 All-In-One InkJet Printer Logo
182 people viewed this question
Seeker5211
Seeker5211
