Question about Five Star TPN535-BGSW Dual Fuel (Electric and Gas) Kitchen Range
Electric oven not coming on
Interior light bulb is working, light on dial says it's on, but nothing is happening - on regular or broil
  • Carla Branda
    Carla Branda Apr 02, 2013
    husband fixed it, not sure how, but he knew
RBS305 replaced thermal cutoff twice and again it won't come on bake or broil
Good Evening!
The self clean feature is causing your thermal fuses to fail or open. This is a safety mechanism that when open (bad) won't allow electricity to pass through any longer. The temperature in your oven exceeds what the components in your appliance can handle. If you want your oven to last it's longest, I would discontinue using that feature. If ever the control board or keypad on your oven by way of the self clean feature, we can help you with that. Fixyourboard.com can help. Send all inquiries to info@fixyourboard.com . Thank you!
Jun 05, 2017 | Whirlpool RBS305PD Electric Single Oven
Broil trips circuit breaker every time
I would start by replacing the breaker. They do become weak over time.
Dec 05, 2012 | GE JRP28 Electric Double Oven
My bake or broil will not work but my stovetop works fine, as well as the clock and oven light.
Does the oven indicator light come on when you turn the oven on? Does the baking element or the broil element work by themselves but just don't work together? If nothing at all works did they stop working at the same time? Need to know to troubleshoot. Please reply with more info.
Feb 16, 2011 | Frigidaire FEF336BC Electric Kitchen Range
Whirlpool GS563LXSS: bake and broil doesn't work.
Oven suddenly stopped to work.
After trying to turn on "bake" or "broil" I can hear couple clicks but nothing else happens.
No flame/no gas is coming out.
Mar 19, 2010 | Whirlpool GS563LXSS - stainless Steel Gas...
The oven is stuck at LOC.
The locking motor has gone bad on the range. Common for this to happen after self clean. You will have to replace or have the lock assembly replaced for the stove to work again
Mar 06, 2010 | GE JKP45 Electric Double Oven
When oven is in on postion oven element does not come on but broil element does;when in broil position nothing happens and indicator light is dim when in off position but burns bright when in oven...
sounds like you have a bad control board.or you have crossed the broil element wire witha bake element wire.these are the first things to check
Jan 22, 2010 | Microwave Ovens
Neither oven will come on
Hello kybattey
Welcome to Fixya.
You said, After coming on and preheating Saturday, the upper oven went off and the lower wouldn't work either. Control paned was blank, but interior lights were on and pushing control paned buttons resulted in beeps. Turned off breaker for 5 minutes to reset and upon retry, the fan came on for maybe 5 seconds and then went off. Nothing else changed. Any suggestions?
You say the ovens went on and then later cut off.
Does the clean mode work?
Try the clean mode and see if it goes on.
Assuming it will clean!
Since the Range will clean you have confirmation that the proper power is reaching the range. It also verifies that the elements are in working condition. You will need to check the high temperature limit switch and the door latch mechanism. If either of these is defective, the bake and broil function will not operate properly
Let me know how it goes.
Waiting your response.
Huuum
Please remember to leave a rating when done!
Oct 20, 2008 | Whirlpool RBD305PD Electric Double Oven
Five Star TPN535-BGSW Dual Fuel (Electric and Gas) Kitchen Range Logo
49 people viewed this question
Top Five Star Kitchen Ranges Experts
Oloyede Monsuru
ray gallant
Tom Chichester
Are you a Five Star Kitchen Range Expert? Answer questions, earn points and help others
