Question about Drills
Makita 24v battery drill, BHR200 wont charge
When you fit the battery to the charger, fan starts on the charger for a few seconds then stops, flashes different lights to what is suggested may be at fault from on the front of the charger, ie 2 red lights flash, not sure if its the batteries or the charger at fault
SOURCE: makita dc1804f charger will not charge new i-mh 1834 18v battery
I think your tryiong to charge NIMH batteries oon a charger designed for Lithium Ion batteries. With all the new style batteries such as NICAD, NIMH and LI-ION, charging becomes difficult. Most chargers pre NIMH and LI-ion, were designed for NICAD's. The best advise, match your batteries with the correct charger
Posted on May 23, 2008
radar001
  • 1051 Answers
SOURCE: My new Black Max 24v drill charger will not charge the battery
You indicate that the drill is new. I'd suggest you return it for a replacement. Seems to be a defective or wrong charger. If you have problems and If you paid by credit card call the card company and have them stop payment on that charge.
Posted on Feb 21, 2010
  • 165 Answers
SOURCE: Brand new Makita DC18RA charger wont charge the batteries.
Return to store for replacement.
Posted on Feb 27, 2010
  • 885 Answers
SOURCE: I have a Makita with 2 PA14 batteries and a
You stated you have a 12V Cordless Drill with PA14 batteries. The PA14 battery is 14.4V. The battery may fit in your tool and might work for a while but the motor isn't made for that battery. The way to check the batteries is to try them in another charger, any 14.4V to 18V pod/stick charger will work. The way to check the charger is to try another battery, any good 7.2v to 14.4V pod/stick battery will work. Unless the charger got wet or extremely hot the problem is usually the battery. Just check to make your tool and battery voltage is compatable.
Posted on Aug 19, 2010
  • 178 Answers
SOURCE: Have Makita drill with DC18 RA charger. Blinks
The Makita Factory may repair them, and then resell them in reconditioned kits, but they will only sell you a new one, or replace it under warranty.
Posted on Nov 27, 2010
Charger hy66-30 Makita drill
Is that with the 24v batteries? Where would you be? I'm in Australia, and Makita doesn't sell anything with 24v batteries here. however there seems to be a few going on the UK ebay site. I hope that helps.
Jan 14, 2014 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Sds bit snapped in my makita bhr200 chuck.on taking the drill apart,the chuck is on a gear rod,and wont allow me to push the chuck down
You have to remove the striker bolt from inside the spindle first. to do this remove the internal circlip (not always easy) then you can tap the striker bolt out and then press the broken bit out.
Mar 15, 2013 | Makita Drills
Makita battery charger wont charge
If both lights on the charger are flashing it is indicating you have a bad battery and the charger will not charge the battery. The charger has circuitry that tests the battery and if it 'thinks' the battery is defective it will not attempt to charge it. The only way to verify whether it's the battery or charger is to try charging your battery on another charger or try charging another battery on your charger. Most of the time it's a bad battery.
Aug 02, 2012 | Makita DC18RAX230 230-Volt LXT Lithium-Ion...
Wnat batterys will a Makita DC24SA charge
The DC24SA will charge 9.6V to 24V Ni-MH slide style batteries (1.7Ah to 3.3Ah)
Mar 28, 2011 | Makita DC24SA 24 Volt Makstar Battery...
My 24v new makita drill doesnt hold charge
the new batteries now have a little computer in them, so to speak. when you plug in the battery to the charger and you get the alternate flashing light the battery is bad. if the charger is working and the battery is just not lasting very long the battery may be going bad. there could be a problem in the motor causing your battery to drain too fast. does the drill work normal, no overheating or noise, bad bearing.
Apr 18, 2010 | Makita 6408K 3/8" Variable Speed,...
Feb 21, 2010 | Mx Black Max 24v Cordless 1/2 Inch Drill /...
When put on charge the green and red light flash
Yep, not the batteries, mine is doing the same thing but my second charger works fine with the same batteries
Jan 19, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Bought 2 no BTD142 impact drivers from Makita USA got drop down transformer they just start to charge then tones for broken battery are heard and stop charging, transformer new, batteries new have i done...
these newer chargers do make a tone that can be changed. when the batterys are initially inserted they will make a sound and then when they are fully charged they will make another usually longer sound. you can change it by removing the battery with 5 seconds and reinserting until you find the sound that you like.. I would look at the charging lights before deciding the charger or battery are bad.
Nov 22, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Battery wont charge
If it is under warranty you should take it back there is no way to repair the battery I would make sure it is the battery and not the charger before I trashed the battery
Nov 16, 2008 | Makita 3/8" Dr. 14.4V Cordless Drill Kit
Drills Logo
125 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
