Question about HP Compaq nx7010 Notebook
Display is wrong - only 3 resolutions available
The screen appears stretched - it is a square resolution setting stretched to fit the rectangular screen. No correct resolution is available - it is behaving as if a different monitor is installed and the laptop's one isn't.
The screen shot shows the display options, and this is not normal - normally it shows the two available monitors for the "multiple monitor" mode and many more different screen resolutions available. The absence of adapter information does not seem to be a good thing!
    Genius:
  • HP Master
  • 1,250 Answers
Install the display drivers, then check
Posted on Oct 28, 2008
After being on a few minutes, the text becomes very blurry I lowered the resolution, which makes the text bigger and helps some. There is an internal adjustment, but I don't know where??
Hi hamptonwhh,
Screen resolution refers to the clarity of the text and images on your screen. At higher resolutions, items appear sharper. They also appear smaller, so more items fit on the screen. At lower resolutions, fewer items fit on the screen, but they are larger and easier to see. At very low resolutions, however, images might have jagged edges. Please follow the steps below on how to adjust your screen resolution.
Windows XP
1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
2. On the Settings tab, under Screen resolution, drag the slider, and then click Apply.
3. When prompted to apply the settings, click OK. Your screen will turn black for a moment.
4. Once your screen resolution changes, you have 15 seconds to confirm the change. Click Yes to confirm the change; click No or do nothing to revert to your previous setting.
Windows Vista/7
1. Open Display Settings by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Display Settings.
2. Under Resolution, move the slider to the resolution you want, and then click Apply.
Notes : When you change the screen resolution, it affects all users who log on to the computer.
When you set your monitor to a screen resolution that it won't support, the screen will go black for a few seconds while the monitor reverts back to the original resolution.
Hope it helps.
Thank you for using FixYa.
Jul 04, 2011 | MPC Computers Envision EN 775e 17 in.CRT...
The display of my monitor (hp w1907) is widened. A circle looks like an elipse. How can i solve this. please help.
It might tvhat there are no video drivers on the PC or there screen resolution is too big or too low
Screen Resolution Issue
Windows XP
1. Click Start -> Control Panel -> Display
2. Display Properties should appear
3. Click on the Settings Tab
4. Slide the Bar to the Left or to the right Making the picture almost a square
Windows Vista/ Windows 7
1. Click Start -> Control Panel -> Personalization
2. Click on Screen Resolution
3. Move the bar up or down until the picture turns almost a square
Or else reinstall a new video driver configure the screen resolution again
Hope this helps
May 24, 2011 | HP w1907 LCD Monitor
My system is workin properly but the screen resolution is very dim it seems to be very light ..... even we can't read any thing on that. i checked my monitor with another cpu its working properly can...
IT IS NOT HARDWARE PROBLEM
Change screen resolution
For example, 640 × 480 is a lower screen resolution, and 1600 × 1200 is a higher one. CRT monitors generally display a resolution of 800 × 600 or 1024 × 768. LCD monitors can better support the higher resolutions. Whether you can increase your screen resolution depends on the size and capability of your monitor and the type of video card you have.
21b7b862-a70d-43aa-a281-e00c38a8078d.pngText and images are sharper and smaller at high screen resolutions
2aca9658-0ee7-4b8d-a582-cac335550f26.pngText is larger and easier to read at low screen resolutions, but images are blocky and fewer items fit on the screen
  1. Open Display Settings by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Display Settings.
Nov 13, 2010 | Intel D945GCCR Motherboard
Monitor screen display stretched center but squashed/narrow edges
On the monitor itself, I am guessing this is a desktop? There are buttons for adjustment. Look for the menu button around the bezel of the monitor and press it. Scroll through the settings for the default setting and press that. Once the default settings are made for the monitor, then you can go to the graphics settings available through windows to get the resolution straightened out.
Mar 26, 2010 | Computers & Internet
Everything on the screen appears stretched
If you can, set the Screen resolution to the maximum native resolution your monitor supports by adjusting the slider. to 1680x1050, if you can set it to that, then Windows will automatically display at the proper aspect ratio, and the monitor will not have to stretch anything. Setting your screen resolution to match your monitor's native resolution is, by far, the preferred solution to get you the best looking display.
If that specific resolution is not available, then you'll need to try resolutions that are smaller than that, but ideally with the same aspect ratio. 1512x945, for example, would maintain the same aspect ratio. Not all monitors handle running at less than their optimal resolution well, and it may result in a slightly fuzzy display, but it won't be horizontally stretched. If this fails to fix the problem it could be a problem with your video card
Jan 03, 2010 | Computers & Internet
Picture size/aspect ratio in HDTV and upconverting DVD
In the digital world, you can't have a 4:3 aspect ratio DVD title (720x480) on a 720p (1280 x 720) / 1080p (1920x1080) display without some kind of centering or stretching to some extent. (square vs rectangle) Now, on a 16:9 aspect ratio title (wide screen format) you should have any scaling issues regardless of the pixel resolution. Despite what the sales person told you, trans-coding ("upconverting") lower resolution titles to a higher resolution does not increase the quality of the image. Any attempt to do so would be only to try to reduce block noise and any kind pixelation at higher resolutions. (blurring square pixel blocks)
In the analog world, the quality of the image is based on the encoder and signal depth. If your TV excepts HD analog, you might be able to have your cake and eat it too. That would force your display to convert an analog signal into a digital resolution, letting the TV hardware do all the trans-coding. Manufactures are completely phasing out analog signal receiving, but might have the RGB RCA connectors for backwards compatibility. Eventually, it will not be supported and you will be forced to buy higher resolution content.
Mar 31, 2017 | Televison & Video
I have a u220w monitor which has a rectangular screen but the picture is square leaving both sides black for about 3 inches on each side. I want to fill the entire screen. I just had the windows vista...
Dear You need to adjust the computer resoultion to one of the following..
1088 x 612
1280 x 720
1360 x 768
you can increase it more; depends on your graphic card installed in system..
HOw to change the resoultion??
First right-click on the desktop and then left click on Properties from the menu that appears.
The display properties dialogue box will appear as shown in fig 1.1 below, click on the settings tab at the top right of the box.
Screen Resolution
This slide bar is what you use to change the resolution, the options you have will depend on your graphics card and monitor.
Changing the Resolution
To change your resolution simply slide the bar along to the resolution of your choice and then click the Apply button.
After clicking Apply your screen will resize to the new resolution and you will be presented with a confirm dialogue box (see left), if you are happy with the way your screen looks then simply click Yes, if you would like to try a different resolution click No.
When you have finished simply close the Display properties box.
Let me know if it helps...
rate me..
regards,
Dec 04, 2008 | Computers & Internet
2 problems: 1. Is there a way to make the images on my 19 inch acer lcd monitor not appear stretched? 2. How do I get a screen resolution of 1440 x 900 (It's not one of the options in my display...
1. The only way to avoid stretching of images is by increasing the resolution. Many 19-inch monitors with conventional (4:3) aspect ratios have 1600 x 1200 pixel resolution. The 1600 x 1200 resolution is ideal for graphic artists and those who work with photos, since it's close to the resolution of a 2-megapixel digital photo.
2. You can double check by going to the display properties - Settings- Advanced tab below the screen resolution slider, choosing the Adapter tab, click List all modes and that will settle it once and for all. If 1440 x 990 isn't listed you're likely going to have to buy a graphics card that can reproduce that resolution.
Also try and update the driver for your graphics card.
Jul 06, 2008 | Acer Computers & Internet
C840 resolution difficulties...
The type of screen you have is a UXGA screen. the optimal resolution for that is 1600 x 1200. changing the resolution for that will distort the screen causing black borders. If a computer has a 15.0+" SXGA+ screen with an optimized resolution of 1400x1050 and the screen's current resolution is set to 1280x1024 pixels, the display will shrink resulting in a black border surrounding the edges of the screen. Also, all other lower resolutions may be stretched to fit the screen. No border will be visible, but fonts may appear slightly fuzzy.
Oct 03, 2007 | Dell Inspiron 8200 Latitude C840 Laptop...
Oblong pictures
The issue here is that you have a low resolution picture and a high resolution display. Windows is "stretching" the smaller, low resolution picture so that it will fit across the larger area, thus distorting it. Right click on the desktop and select properties. Go to the Desktop tab. There should be an item there for position. Is it set to Stretch? If it is, then this is causing the problem. Set it to center, and it should appear fine. If you want to keep this from happening: 1) User higher resolution pictures. 2) Turn down the resolution on your screen (this can be done from the Settings tab of display properties).
Oct 01, 2006 | Samsung SyncMaster 940BE 19" LCD Monitor
HP Compaq nx7010 Notebook Logo
157 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
