Question about Sony PlayStation PS3 Slim 250GB Bundle with 2 Games, Blu-ray Remote and HDMI Cable
Sony playstation 3 display and color problem
We had a display problem which is during the connect of oridnary TV, the display is not comin from the TV, but if we will use plate screen tv it comes normal, kindly please advice us.
  • Abdi Ali Kassim Mar 03, 2012
    Already we have been adjusted the color and the contrast, but i hope the problem is the brightness, because when we marked the rate of the brightness in 100 you can play, but it is not as it was before and the other hand the only system our TV displaying the image of the games is Usager system toward the TV
  • 192 Answers
SOURCE: Sony KDL 46V2500
This set does have a video problem. If it was bought locally, then, the retailer may have a 30 day return policy. If bought online or cannot be returned, then, contact Sony, for a service center in your location: http://eservice.sony.com/webrma/web/index.do Either way the set is to new to have a problem and you should get it resolved as soon as possible.
Posted on Aug 05, 2007
  • 84 Answers
SOURCE: Can't remove AV Input display
Try setting hdmi control to off in tv menu
Posted on Apr 06, 2008
  • 4234 Answers
SOURCE: Sony Trinitron 29inch Color TV
The 2 blinks are an indication of over-current. This is usually because of a shorted component. The most common is the horizontal output transistor. This will be a 3-legged part attached to a heat sink close to the flyback transformer (part with red wire coming out the top). This transistor will be marked C4856 or something similar. Update this with the exact marking and I'll provide you with the full part number and approximate cost.
Dan
Posted on Jul 14, 2008
  • 18 Answers
SOURCE: Sony PS3 will not power up -
1. First check the power cable by removing it and then plugging it in again. You may find it is not pushed in far enough.
If that is good then follow these steps
  • The console might not be turned on. Turn on the console using the main power switch on the back of the console.
  • Make sure the AC power cord is securely connected.
  • Visually inspect the AC power cord for damage. Do not use if frayed, cut, or damaged in any way.
  • Confirm the wall power outlet is active (receiving power). Try a different power outlet.
  • If possible, test the power cord by connecting it to a different PLAYSTATION 3.
  • If possible, try another AC power cord on your PLAYSTATION 3.
  • If you experienced a power surge, shortage, or a lightning storm in your geographical area recently, this may have affected the PLAYSTATION 3 power supply and the PLAYSTATION 3 may need service.
  • Make sure the vents are not obstructed in anyway.
  • Make sure there is adequate ventilation for the PLAYSTATION 3. There should be at least four (4) inches of clearance between the air vents on the system and any walls, televisions, entertainment centers, etc. Otherwise the unit may not function properly due to what are actually environmental issues.
I hope this helped
cheers
John
Posted on Dec 02, 2008
  • 111 Answers
SOURCE: I connected my playstation 3 to another tv and it
If you attached your PS3 to an HDMI capable TV it asks you if you want to switch to HD Mode.
However, once you attach it back to a regular TV you get no picture.
Follow these steps to resolve:
1. Turn off the PS3 so it only shows a red light. You can flick the power switch in the back then back on again.
2. With your PS3 connected to the TV and the TV on, press and hold the power button.
3. Hold the power button until the screen "flickers" and then immediately release.
4. Wait a few seconds and the PS3 logo should appear.
Posted on Feb 10, 2010
When I connect to the TV nothing happens even though I have connected the system correctly
Please try my display tip to fix your problem -
Playstation 3 display reset
Hope this helps and thank you for using FixYa
Jan 07, 2011 | Sony Playstation 3 (PS3) Console
The playstation is comin on but i cant gat a picture on the tv why tried on different tv worked fine last nite
Ok, follow these simple steps and your PS3 should display properly on the TV.
Step 1. Turn your PS3 onto standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it then beep again 5 seconds later. Release the power button
Step 3. Wait for the PS3 to restart.
This resets your video resolution back to standard definition. You should now be able to setup your video settings correctly using the PS3.
Aug 15, 2010 | Sony Playstation 3 (PS3) Console
How do i connect the playstation 3 to tv, it was connected to hd tv then we have tryed to connect to normal tv and nothing. please help
You have to connect the wire that has 3 separate wires at the end into your television according to the color. Plug the red wire into the red slot, yellow in the yellow and white in the white. You will then have to take the other end of the wire and plug it into the back of your playstation. Also, make sure to plug your playstation into the electrical outlet.
Jan 08, 2010 | Sony PlayStation 3 40GB System
PS3 won't connect to TV with component video.
You need to connect the PS3 to the television with both connectors (HDMI and Component). Then in the display settings change it from HDMI to component and during the 30 seconds that the screen goes black you need to disconnect your HDMI cable from your playstation. Then switch to the input that the component cable is connected to on your television (ie. AV1, AV2, etc). From here you will see the countdown for the test and you can continue with these settings.
Nov 20, 2008 | Sony Playstation 3 (PS3) Console
PS3 video output on SD tv is wavy with discoloration and black line
when you switch the ps3 on if you hold down the power button for more than 4 seconds it runs the display setup. and sets the ps3 to run in the best possible option
Dec 25, 2007 | Sony Playstation 3 (PS3) Console
No color on Sony TV, all other tvs are great
check the av cables in back of your tv and also check the wires connected up to the xbox 60 it's self
Sep 01, 2007 | Microsoft Xbox 360 Console
Sony PlayStation PS3 Slim 250GB Bundle with 2 Games, Blu-ray Remote and HDMI Cable Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
