Is there a reset button ??? if yes were is it and how do I reset it?
SOURCE: grinding noise when washer starts
hi there,
the grinding noise may be coming from either the pump or you have something caught between the drums.
the f-33 error is the pump drive system error. it indicates that you have lost communication between the CCU board and the pump. the CCU board is the main control board that you see in the front of your washer.
i would recommend that you call a technician to check it out, as you will have to do some checks that require technical knowledge.
SOURCE: Cabrio won't spin
F then 50 flashes when the motor rotor
position sensor (RPS) senses no rotation.
➔ Does basket turn freely? If not, make sure
bottom shipping pack has been removed.
Determine cause of friction
its SD not 5D
Sd is displayed when the machine/motor control,
by analyzing drag on the basket, detects a
suds-lock condition, and is steady on while the
control then runs a mini-clean out cycle. If the
clean out cycle is unable to correct the
over-sudsing problem, the cycle ends and Sd
flashes in the display. This may signify:
➔ Load is bunched or twisted around agitator.
➔ Excessive detergent usage.
➔ Basket cannot engage during drain step.
➔ Mechanical friction on drive mechanism,
not allowing basket to engage.
SOURCE: whirlpool cabrio washer keeps flashing code F50
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$$$
SOURCE: f1 keeps flashing on my
The control board is shot. Whirlpool did a recall on those boards, so get in touch with them and see if your machine is covered. If it is, whirlpool will cover the parts and labor for free. Here is the number to call: 1-866-698-2538 Good Luck please accept the answer and please leave a testimonial
