Question about RCA P56923BL 56" Rear Projection Television
Convergence problem Had a RCA P56923BL model. The convergence setup on Menu was gone.
Hi Eds.
I may be a little late in posting this reply, but I had the exact same problem with my RCA 52in. rear projection. The reason the menu does not give you the option to set the convergence, is because of a simple blown fuse. If your board is similar to mine, the fuse is the center brown one located next to the flyback transformer, which is located on the left side, next to the rear as you view the circuitry from the back of the television, when the rear cover is removed. The flyback transformer can be identified by two thicker red wires leading towards the front. When you replace the center small brown fuse, you will be able to access your convergence menu again. Please use common sense when attempting this repair, by unplugging the tv for a few days prior to the repair. The voltage created by these components can cause serious injury, or even death.
Best regards, and good luck!
Hope this helps. Steve.
Posted on Feb 10, 2009
    Novelist:
    Champion:
  • 203 Answers
If the convergence is out on that set you most likely do not need to make an adjustment the circuit will need to be repaired. There is a stk on the convergence amp board that needs to be replaced. A good tv shop will run you somewhere between $300-$500 to do the repair
Posted on Oct 28, 2008
52" rca hdtv has a shadow ghost when it plays. It
convergence issue. Press menu and then scroll down to the setup option enter setup and scroll to Autoconvergence and activate the auto convergence feature that will realign the convergence . If that doesnt correct the issue you will need a Convergence power board, If the auto convergence feature is missing from the setup menu then you need the convergence option missing repair kit. Both the board and the repair kit are available from www.tvrepairworld.com
Jun 18, 2011 | RCA D52W23 52" HDTV CRT TV
How do I adjust the convergance? I have a shadowing problem
Press menu on the remote then scroll down to setup then enter setup. The auto convergence feature is listed there which will reset it automatically. If auto convergence disappeared from the setup menu then you will need the RCA convergence option missing repair kit from www.tvrepairworld.com which does contain the instructions.
Jun 10, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I cant find where to go to find the convergence option.. the manuel say's its under setup but on my tv thats not an option as it states in the pic can anyone tell me how to get in to convergence threw my...
That's a common problem with that model the auto convergence option would disappear from the setup menu. But it's a very easy and inexpensive repair that you can do yourself. You can get the RCA repair kit called the ITC 222 and ITC 222 A chassis convergence option missing repair kit. The kit contains the FL 231, DL 231, CL 030 and also has repair instructions on CD. Is $25 from www.tvrepairworld.com listed under their RCA repair kit category.
Jan 07, 2011 | RCA Televison & Video
Picture looks like 3d i have ajusted screen but keeps going back to 3d and picture is bowed
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Aug 25, 2010 | RCA P56923BL 56" Rear Projection...
Rca p56923bl chirping
Horizontal Output transistor looks like this attached to a heat sink near the Flyback transformer97bd027.jpg
Nov 28, 2008 | RCA P56923BL 56" Rear Projection...
My 52' rca tv started showing red,blue, and green double picture and i cannot find the converge in the menu what can i do ..
if this is a rca itc222 chasis then you might have the fl231 problem. check out the ariticle under the tips and tricks section under my profile. the convergence menu is under setup in the convergence menu. if it missing then it may be the fl231. depending on what the model is.
Nov 26, 2008 | Televison & Video
Convergence
Go to menu setup Look for convergence if you do not see convergence then you have open fuse on deflection board.FL231
Aug 31, 2008 | RCA D52W19 52" Rear Projection Television
Convergence
by the convergence menu i would assume you mean in the customer setup menu. although i have seen this at the shop on newer itc222 i guess it can happen with older sets...is the convergence gone...is it red green and blue.. if not it might be cut off in the service alignment menu...if that is true. how did it get cut off. has the set been worked on?
Feb 09, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Where is the convergence control?
Unplug the set wait five minutes then try again go to menu where closed caption is............
Dec 07, 2006 | RCA P56923BL 56" Rear Projection...
Convergence setup menu gone
No rest on this model other than unplugging to let it return to factory default. If your a tech .. Check R19722 and R19703 for open. Both 750 K. these open make the convergence menu to be gone.
Jul 13, 2006 | RCA P52929 52" Rear Projection Television
Televison & Video Logo
83 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
