Question about Sony KDF-E50A10 50 in. LCD HDTV
Red light flashing won't power on
When I attempt to turn on the tv the green standby light flashes for awhile and then a red light flashes 5 times then stops and flashes 5 times again etc....  please help me.  Is there any remedy that I can try on my own because I'm having an extremely hard time getting a sony repair person to come to my house.
  • blakebis Nov 02, 2008
    No I don't know how to use a meter or even know what a meter is for that matter. I was able to get a sony repair person to come. He is coming on Monday. Should I just let him handle it or is it something I could easily do myself? Keep in mind I know almost nothing about electronics. thanks
    Novelist:
    Champion:
  • 203 Answers
You have 2 good possibilities of what can be causing your problem. The first is the lamp, and the second is the ballast. You would need to be able to use a meter to determine what is wrong. Do you know how?
Posted on Oct 28, 2008
  • experttv
    experttv Nov 02, 2008
    I would just let him take care of it...it should run you somewhere between $400-$600 to have repaired
I have a 56' that wont show picture
Power board is bad.. I had the same issue.
Apr 13, 2010 | Samsung HL-S5679W 56" HDTV
Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
KP57WV600 SCREEN TURNS GREEN THEN BLANK
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
  • If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
  • If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
  1. Turn off the television. IMPORTANT: For a projection TV that uses an internal lamp, wait 5 minutes after turning off the TV to allow the lamp to cool before continuing with the following steps.
  2. Unplug the TV power cord from the electrical outlet.
  3. Let the TV remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the TV is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the TV.
  5. Turn on the television. NOTE: If the TV does not turn on immediately, the fan may need to finish its cycle. This is part of the cooling process for some projection TVs and is normal operation. After the fan turns off, attempt to turn the TV on again.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required . Please note the number of times the STANDBY light flashes and relay that information to the service center.
Sep 22, 2009 | Sony KP-57WV600 57" Rear Projection...
Sony 2004 KF-50WE610 power/standby button flash doesnt turn on
turn ur tv off for awhile turn it back on it should work,But ur video board it was bad now it dead.
Aug 12, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
SONY GRAND WEGA KF-50WE610 can't turn on TV screen.
Ths 5 blinks usually indicate an AKB problem. There is a break in the video path. I'll look up your specific model and post the results here. Please update this if you wish to attempt the repair yourself.
Thanks,
Dan
Mar 19, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony KF-50WE610 flashing power/standbylight
Its small board with few connectors and easy to replace.
You can buy required part from Part Store. You may see image of ballast supply there.
Jan 18, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Sony KDF-E50A10 50 in. LCD HDTV Logo
443 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
