Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Problem for Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Dishwasher does not stop filling and already replaced float switch...PLEASE HELP
By Harry4002 on Aug 31, 2006
I have had this problem with the dishwasher and I found out that that it would be a bad float or float switch. So I went on the net and ordered up a new float and float switch I replaced them both made sure everything was put back together the same way. Didn't work, still have the same problem also if I cut the power off from the breaker it still dosen't stop filling as crazy as that sounds it's true the red light on the control pannel goes out and every thing stops but the water. Any advice would be a major help. Thanks...
Same Problem
Dec 31, 2007
-   I have the reverse problem on my 587 Kenmore.
It doesn't want to fill up w/ water and I am unsure as to why
Any suggestions-   mattyb60
Solution #1
posted on Aug 31, 2006
Not Rated)
catriver
Rank: Guru  Kenmore Expert
Rating: 94%, 3210 votes
Harry, the float and float switch are only safety devices to cut the power to the valve in the event the control board fails. The fill is controlled by the board. It sounds to me like it may be the valve itself. You can verify this by taking a meter and checking the voltage during the fill cycle. If the voltage drops out and it's still filling, it's your valve. If the voltage stays constant until the float switch kills it, it's your board...Catriver...post back.
Was this helpful?
Yes
No
Popular Solutions for Kenmore 16602 / 16604 / 16609
Questions and Unsolved Problems for Kenmore 16602 / 16604 / 16609
Do you recommend Kenmore 16602 / 16604 / 16609 Built-in Dishwasher?
Answer
Answer
Pieces of food still stuck to some dishes, glasses not clear.
Answer
I can't figure out how to take apart the spray arm on my Kenmore dishwasher to see if there's... (More)
Answer
dishwasher not cleaning dishes as good as before. is there a filter that needs cleaned or changed... (More)
Describe your Dishwashers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
in Van Nuys, CA
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
