I HAVE AN LG WASHING MACHINE 7.2KG WD-10165F WHEN I PUT THE POWER BUTTONT IT SHOWED ME AN CL WHAT DOES THAT MEAN
I HAVE AN LG WASHING MACHINE 7.2 KG WD-10165F WHEN I PUT THE POWER BUTTON ON IT SOWED ME AN CL AND IT IS NOT SWICHING OF
  • 500 Answers
SOURCE: illamy lg wd-1238c washing mashine
CL Means Child Lock.
You may have put it on by accident.
Look for a child's face with to lines pointing to 2 buttons on your Facial Panel.
Press these to buttons for 3 to 5 seconds and the Child Lock will deactivate.
Good Luck :-) - J.Q
* If you found this solution helpful, please vote positively. A 4 four thumbs up, and a testimonial will do nicely :-)
Posted on Apr 02, 2011
  • 98 Answers
SOURCE: Washer won't drain.
It won't drain If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Apr 01, 2009
Kuwagata
  • 181 Answers
SOURCE: I HAVE WD-10165F LG WASHING MACHINE, BUT ITS DRUM IS NOT WORKING
Possibly the Main Capacitor is leaked/ burned.Try replacing it with new ones.
To locate it, you can follow the schematics diagram behind the machine.
It's look's like a mini can with cable, sometimes the color is white, and on the body written 25uF/400 VAC, or something like that.
Hope this work, if still won't, contact me for furthure assistant.
Posted on Oct 23, 2009
  • 136 Answers
SOURCE: LG washing machine intellowasher 7 kg wd-8050f
Please unplug or shut off the power at the fuse box...
The water inlet valve connects the hot and cold water lines from your home to the back of the washer. The solenoids on the valve open one or both valves to provide the proper water temperature for the wash cycle. If the valve The water inlet valve connects the hot and cold water lines from your home to the back of the washer. The solenoids on the valve open one or both valves to provide the proper water temperature for the wash cycle. If the valves are blocked or the solenoids do not activate, the symptoms may include no water, low water pressure, the wrong water temperature or water entering the tub even when the machine is off.
The water inlet valve can be identified by the water hoses connected to it at the back of the washer. Start by turning off the water supply at the valves on the wall. Disconnect both hoses from the back of the washer. Place the hoses into a bucket and turn them on to confirm that you are getting good water pressure and to clear out any debris from the line.
Inspect the filter screens on both the hoses and the inlet valve for debris build up. If you find any debris, clean it out. Use caution to avoid damaging the filter screens because the screens in the valve are not replaceable.
If debris was not present then proceed to the next step of testing the solenoids. Access to the valve may be easiest by opening the top or the back of the washer, depending upon make and model.There are two wires connected to each solenoid (aka coil) on the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip-on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Posted on Jan 19, 2010
  • 6277 Answers
SOURCE: my LG washing machine WD-10485TP
'CL' for LG washers stands for 'Child Lock'.
To release hold down 'temp' and 'eco/rapid' together, then release!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Jul 27, 2011
Hi my LG 7.5 kg (10165fu)front loader washer has just stopped functioning. It shows on screen a big "CL".What do i do? Pls help. Griffiths
CL means that your washing machine's CHILD LOCK is ON. You can find two buttons Temp and Options in the panel. Turn ON the machine, press these two buttons together for 3 seconds and thats it. It might have a little kids face above a lock key, inbetween the wash and rinse buttons, hold these for 3/5 seconds and it should work
Dec 03, 2016 | LG Washing Machines
I have a LG WD 1238C Front Loader Washing Machine and the display has a CL on it.
Remove power for some time , allow the power to drain off the memory and see if the display is clear. If not hold the start button and switch on power. Check the inlet and drain filter , free water flow, if not remove and clean.
Nov 01, 2013 | LG WD-1280FHD Front Load Washer
Lg tromm wd 85485 error code cl mean ?
Possible that the drain valve is clogged if the inlet line is working and so you need to remove the drain and back flush.Also check after the power plug is removed for few hours and see if the fault resets to start the machine only to show the error a few minutes later. if so clean the drain lines, check the inlet flow and the door switch.
Dec 15, 2011 | LG Washing Machines
Hi there My frontloader washing machine display
LG washing machines indicating error code CL may have the child lock activated. Try holding down the temperature and eco/rapid options together to turn off child lock.
Mar 08, 2011 | LG WD-1280FHD Front Load Washer
Washing machine LG Direct drive 7, 3.5kg WD 12331AD It has CL sign on it i cannot operate the machine how can i clear that nad get the machine to work?
CL means control lock should be a button or bottons on your machine that you press and HOLD to unlock the control panal...so the childern don't mess with your washer....Good luck
Feb 01, 2011 | LG Washing Machines
Our LG washing machine 5.5 Kg WD-85260 NP is having problem as it is showing IE on the screen and then stops. So we have to restart the machine again. What is IE?
IE on the screen of an LG washing machine can mean a lot of things.
1.It can mean that the washing machine can't fill up with enough water in 8 minutes time.
2.It can also mean that the water hose screens are clogged up with dirt and dust.
3.It can mean that you hoses are reversed. Your cold water hose might be connected to the hot water hose.
4.The water valves might not be screwed in completely.
If you need to reset your machine you can just unplug the machine and hold the start/pause buttons for a few seconds.
Jan 16, 2011 | Washing Machines
Message CL has appeared whch is child lcok. How
hold down the rinse and prewash buttons at the same time for 3 seconds , do the same to start it also.
Nov 12, 2009 | LG WD-1045FH Front Load Washer
Oct 23, 2009 | Washing Machines
Washing Machines Logo
136 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
