Question about Fujitsu fi Office Equipment & Supplies
A general fault of the msg_opends response code ds50171
I use this scanner in a prog. called emds also connected are a Topaz sig pad and a logitech web cam. too many twain devices??
5 Suggested Answers
SOURCE: Downloading software (Twain??)
The download website for your scanner is here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=8008
A TWAIN driver is simply a generic scanner software driver that your specific Canon software can hook into and use.
I recommend starting with this one and see if it installs the TWAIN driver you need:
"CanoScan Toolbox v2.2.3 for Windows 98/Me/2000/XP"
Posted on Dec 16, 2007
SOURCE: TWAIN ERROR AND CANOSCAN LIDE 20 SCANNER PROBLEMS
Select your operating system and download the driver "TWAIN Driver - LiDE 20 Scanner Driver Ver. 7.0.3.1a_xp" and then download the software "Canoscan toolbox" ...here is the link:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=6624
Posted on Jul 04, 2009
SOURCE: TWAIN Driver Error
If the windows image acquisition service is running, stop/disable it and see if this helps with the apparent concurrency problem.
Posted on Apr 16, 2010
Jeff Pogi
  • 62 Answers
SOURCE: Hi We have 3 Fujitsu scanners,
RE-install CD driver of your scanner
Posted on Feb 22, 2011
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
Auxilary emissions controls
OBD2 fault codes have no cut and dry fix for every car that has it in memory. Here is the general info on the code. This code refers to the EGR valve back pressure sensor called the "DPFE" sensor
P1401 - DPFE Circuit High Input
Symptoms - Engine Light ON (or Service Engine Soon Warning Light) Possible causes
  • DPF EGR circuit open.
  • VREF short to PWR.
  • Damaged DPF EGR sensor.
  • DPFEGR circuit short to PWR.
  • SIG RTN circuit open.
  • Damaged PCM.
  • Possible solution A DPF EGR PID reading greater than 4.5 volts with the key ON and engine OFF or running indicates a hard fault.
    Jan 21, 2012 | Cars & Trucks
    Kenmore electric stove model 95012102 displays EO-F2 the cooktop works.
    that code is a bad touchpad.
    F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
    2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
    Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Sears / Kenmore Fault Codes#ixzz1cHA0Nn50
    Oct 30, 2011 | Kitchen Ranges
    I need a new front panel for my Pro-2096 and I also need it programmed to my area
    Hi, my name is John. You can look on eBay for panel, here are the steps to program your unit. Press PROG. Select the channel you want to store the frequency, press PROG. use the number pad for the frequency number including ./DELAY for the decimal point, press ENT. Get the frequency,s you need here www.RadioReference.com or www.RadioFreq.com enjoy.....John
    Oct 25, 2010 | Radio Shack Pro-2096 Base Scanner
    Epson problem
    Here is the download page
    http://www.epson.co.uk/Store/Scanners/Epson-Perfection-4490-Photo/Drivers-Support?supportLandingPage=true
    To scan to PC you need to use a prog with twain support the basic one in XP is paint.(start/all progs /accessories/paint/file/from scanner or camera) the scan appears huge but that's just the way paint does it save and open with another prog for printing (eg windows fax and picture viewer) and it wil be printed normal size.
    When installing drivers do not connect scanner until told to do so by the install prog.
    Sep 16, 2009 | Epson Perfection 4490 Photo Scanner...
    Attempts to establish a http connection has failed Error Code: 8/11004/1/-1
    when i on my laptop acer crystal eye a window opend with a command and "camera not found"
    Mar 30, 2009 | Logitech Webcam
    SigLite 1x5 Model:T-S460-B (with serial connector)
    The problem was not the topaz pad but my laptop. I removed all software which needs the serial port and I finished all not necessary programs which were running in the back but the problem was still alive. Now I asked my administrator for more rights and I changed the name of the port from port "1" to port "3" (port "2" doesn't work). I've got the message "port 3 is already in use" but the pc accepted the exchange of the name. Afterwards I changed the portnumber in the ini.file of the Topaz Software and now it works without any problems... strange, strange.... my five colleagues who are using the same pad on the same type of laptop (Compaq nc 6120) haven't got any problems during installation of the pad.
    Thanks for your interest - kind: regards Ben Gun
    Apr 06, 2008 | Topaz Systems TOPAZ SIG.CAP PAD SIG.LITE...
    8,499 people viewed this question
    Top Fujitsu Office Equipment & Supplies Experts
    Chris Larocque
    Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
